GPG
  1. GPG replied to GPG's topic in ZMatter
    I opened a ticket and received word back from Michel that this does not work with the Zooz stick. and the zwave devices with have to be included manually.
  2. GPG replied to GPG's topic in ZMatter
    The Polisy has a Zooz Stick and the EISY has the UD Zwave/Matter USB board
  3. I am migrating from Polisy Pro to EISY Rev2. After restoring from polisy migration backup, my Zwave nodes came across but are all flagged with the red circle and hash icon. On the MY DEVICES screen they are all showing type of "Placeholder". At this point I'm not sure how to proceed next. I'm considering doing a factory reset on the EISY and starting over. I still have access to my Polisy. Suggestions?
  4. Had to submit ticket to resolve. Issue fixed.
  5. @DennisC My above response was to @Techman. I have powered down polisy, PLM, Router, and PC previously. I used http://MY IP:8080/desc to add my polisy to the launcher. That's when I noticed that my uuid had changed. I have never see that happen before. I also get the same uuid returned if I use https://MY IP:8443/desc. I'll take a fresh look at this in the morning.
  6. I had already done that, but I just did it again and I still have the same problem.
  7. After upgrading to 5.6.0 my polisy was no longer listed in the ioX launcher. Using my IP address I was able to get to the Admin Console, but I am unable to make changes or control any devices. In addition my uuid changed. I also lost portal operation. I added the new uuid to the portal and received a message to go to the AC and approve the access request. I logged into the AC Configuration/Portal and I see 5 requested services listed (my name is on the top one). When I click on the +Approve button, I receive the message "Bad Request". Has anyone else had this issue and solved it, or is it time to submit a ticket?
  8. Hi @kewashiThis is great news. Thank you very much.
  9. Is there any information on whether a PG3 node server will be available for Hubitat.
  10. I am having this same problem. I first noticed it yesterday. This morning I was able to use a voice command to turn on some lights, but now it is not working again. All my devices are showing up in the Alexa app. I have rebooted all devices: cable modem, router, echos etc. I am now getting the verbal error message from Alexa that the "device is not responding", but after a few minutes it device turns on. This happened earlier today also, but the delay was more like 20 minutes. I am thinking this may be a problem with the Alexa server.
  11. Finally it is working. I'm not sure why the logs were not showing up. I went back to the initial NodeLink setup and started from scratch. The log then showed up, which helped a lot. I'm sure part of the problem was me being new to the raspberry pi. Thanks much for your help. Looking forward to setting up my sprinkler programs now.
  12. Are the log files supposed to appear in the node folder?
  13. Options are: Emergency, Alert, Critical, Error, Warning, Notice, Information and Debug
  14. Which nodelink log level should I set? Is a restart from within nodelink sufficient?
  15. There is no plus in front of RainMachine. I did reboot the ISY. No change.
