Everything posted by Dodger
- ISY99I
ISY99I
Does this mean that you are not getting prompted for userid/password? Correct just a blue screen If so, would you please reboot ISY, observe the pattern of LEDs on the front of the unit and let me know what the pattern is? i.e. do you see any of the lights continuously blinking especially error/mem or both?Power on RX TX M blink then stay on for w few seconds then off Power on. Dodger
ISY99I
-Xathros What exactly seems to be the problem? When I start the program I get to the place were you ad the user name and password but the blue screen is blue What version of MAC OS are you using? OSX Verision 10.8.3 Do you have Java 7 installed? were do I find that information What version of the ISY firmware do you have running on your ISY?were is that -Dodger
ISY99I
I just changed over my PC to a MAC But I can not get the ISY99I to work on the MAC. I also use a Remotelinc And it still works. Is there a program that I can control items on the ISY99I? Is there a Mac program that will work Thanks for the help Dodger
Scene help
How do I add a item to a scene I have a wall plug I would like to add to a bed room Scene. How do I do that ? I will install the plug in the wall then what? Ant one know of a windows based software program that would make programing drag and drop? On that I do not have to leave the computer on all the time? Thanks for the help Dodger
ISY 99 I
I had to reformat my hard drive today. So when I went to set up my ISY 99 I and Power line Modem Module. I go into the Admin Console All devices current state is blank I can not control anything from the computer All my devices are present in the network My remotelinc works fine. The RX light is always on for the universal Device How can I get it back so I can turn things off and on from the computer? Thanks for the help Dodger
windows based program
I like this system. But for me it is difficult to program and make changes. Is there a windows based program that is very easy to use to program all my devices. Mostly lights , switches, but would like to add security, and maybe some cameras. Dodger
Automatic shut off
How would I set up items to turn off at a certain time of day?
What is the simplest program to use ?
I was wondering if there is a windows based program that is easy to use ,and program? I presently use the ISY 99I Home Automation Controller with PLM. I have insteon lighting products and am going to add cameras, door and window security. Would like a program that is very easy to use and be able to make changes to. Thanks for the help _________________ Dodger
ISY 99I
ISY 99I
isy99i
Before I had to do a format I had an Icon on my desk top that I could click on and it would take me to the universal device. Now I have no Icon I can get to the device but now I have to put in the ip address. How can I get the icon back so it is easer to get to the device?
- isy99i
Proper setup
I am new at this and this is the set up I have . It works most of the time but looses conection some times. Network Mylighting Light bulb josh tv light buld josh computer light bulb josh dvd player Remotelinc Josh room Scene josh bedroom Light bulb josh tv light buld josh computer light bulb josh dvd player Remotelinc Josh room I did this for every room and button on remotelinc Is this the correct set up Dodger
isy99i
Rand, The system has been working great. But now I have been having some problems. How do you set up a KPL button for each scene? That is one thing I never set up. I do not understand how to do it. Please explain. Simple terms. Remember I am very new at this. I have one device that started to give me problems. It is a light socket and when I pushed button 2 once on the KPL it started to blink. If I pushed it twice very quickly it would shut the device off or on. Now it does not communicate with the device and when I do a reset. It times out. On that same computer when I try to access this forum it says has no connection. It says some thing about needing a PHP what ever that is. John
isy99i
Rand, I would like to add a keypadlinc 8 key to the system to do the same thing the remotelinc does. 1 turn conected light on/off 2 living room 3 bed room 1 4 bed room 2 5 bed room 3 6 bed room 4 7 office 8 all on/ all off I have the Keypadlinc Dimmer 8 key. I do not need the dimmer, all I want the device to do is turn on or off. Can I still use the dimmer keypadlinc ? How would I set it up in my system? Thanks
- isy99i
isy99i
Rand, This is what I have now Network My lighting All have light bulbs next to it Living room light Living room TV Living room fan Living room Has a box next to it , in the box has 3 round green dots, two blue triangles and one red square Living room setup Has a pie with three circles in it In that are All have light bulbs next to it Living room light Living room TV Living room fan I was able to drag devices to the scene. Should I have all this other stuff? Thanks for your help
isy99i
Rand, This what it shows Network My lighting Living room light Living room TV Living room fan Living room Their is nothing in living room When I try to drag and drop it gives me O with an / threw it will not let me drag and drop. Is the system setup wrong? I am new at this trying to learn
isy99i
Mike, The protection against web threat was off. Seems to be working good today. No error message When I press a button on remotelinc the status shows up on the scene section. It changes from on to off or off to on. The individual device stays the same does not change until I change it in the computer. Is this how it should work? I wish there was a way to save the main menu so you could see how I have it set up. Under network my lighting it is something like this Network My lighting Living room light Living room TV Living room fan Living room, which is button 1 that has all three above devices linc to it This is how I set up every room, when I push button 1 on remotelinc the following happens in status Living room light OFF Living room TV OFF Living room fan OFF Living room ON Is this how it should work? I am able to change each separate device in the computer Living room light on Living room TV off Living room fan on Living room off Sorry for the long note but this is my first set up
isy99i
Sorry I said perfect to soon. Two things are now happening. 1, When I go to the icon that has the sq. with five green and one red dot at Mynetwork my lighting it has the names I used to setup remote link and also the names of all deivices in each room ,single device. When I press the remotelinc the status will change. But when I go to each device I can not do anything turn off or on with the computer . Example I have a outletlinc and appliancelinc in a room called kitchen, I can turn the whole room on or off using the remotelinc. But I can not turn on or off just one item on the computer. Everything only runs off remotelinc. 2. I started to get this error message at start up Socket open failed jave.net.socket.timeout exception. Did I program everything wrong? Should I start over? What should I do first? Please help
- isy99i
- updates
- updates
isy99i
Sorry people I must be explaining something wrong. When I started doing the setup. I pluged in all the devices 3 appliancelincs 14 outlet lincs 4 access points 3 appiancelincs I linked everything in groups of rooms. so on my universal Devices Adminstrative Console it reads like Network My lighting Then the names I gave the six rooms I use. over in the Membership window it has the name of the room just like it is to the left but it has a + sign and under that it has is managed by. Everything works great current State shows device on when on and off when off. So I decided to program the remoteLinc. Button one programed to room one and all devices in that room , Button two programed to room two and all the devices in that room, and so on. Worked great and all buttons work great. The current state never changed when I turned off or on anything but the remote linc did turn things off and on like I programed. Then I went to Link management to link the remotelinc I followed the directions and it sets up six colored squares with the right window now has number 55.33.dc.1 and so on then it has manages then is managed by. but the current status never changed 55.33.dc.1 55.22.dc.2 55.22.dc.3 And so on for all six rooms For those six things their is nothing in the current status window. But remotelinc does work. But when I get on the computer I can not tell if it is on or off. Dodger
