starhome
  1. Thanks for the quick reply - that seems to do the job!!
  2. I migrated from the ISY994 to Eisy and i'm working on the fall-out of this migration. One issues is wrt PG3 - The nodes in PG3 are listed as "unmanaged" - I was able to resolve some of this by re-installing them from the new Node Store - but others I simply want to delete - but I'm unable to find a way to do this from the GUI. What's the process for this?
  3. https://radiora3.lutron.com/us/en/whats-new https://radiora3.lutron.com/us/en/whats-new
  4. starhome posted a topic in ISY994
    I'm trying to configure a Wake on LAN device, i enter MAC Address (with dashes, all upper-case), IP Address (in my case 10.10.1.115), Subnet (255.255.255.0) and Press Calculate and click "OK". When I open the settings again, the IP Address is always "10.10.1.126"... i'm i doing something wrong? I'm running 4.2.2
  5. What't the best way to detect the length of a power outage and send out a notification? (with ISY and Router both on a UPS and both without a UPS)? Wondering if there are variables build in ISY for this?
  6. So tag motion does not use something like basic auth and thus adding a basic auth header to the POST request from ISY does not work? I was hoping to get this working without an additional server -Angelo
  7. Gary, would you mind explaining how you would use eventghost? Can I not send a REST command directly into ISY?
  8. This is EXACTLY what I was looking for!! Ordering right now. Thanks so much!!
  9. starhome posted a topic in ISY994
    I'm trying to figure out how to detect if my cars are parked on my driveway/garage and was hoping there would be a easy solution like placing an RFID tag in my car and somehow detect this.. seems very straightforward, but have not been able to find anything that will integrate with ISY.. anybody has implemented something like this?
  10. Works!!! Thank you so much!!!
  11. So just added a KeypadLinc (V.43) and a FanLinc and followed the instructions above to program Low/Medium/High/Off using the secondary buttons but I'm running in the following issue: When I press a button on the Keypadlinc (for example A to turn the fan to Low), all other button turn on as well (B,C,D). But when I select the scene and press "On", only the A button lights up and the other turn off as expected... For the scene (Low) above, I made A a controller and B,C,D a responder.. Any idea what i'm doing wrong?
  12. Lee/Xathros/EircK thanks for the help so far. Tricky part is that they KPL button is also part of a scene (in order to turn the button off) and in that case there is no "On" value available.. I tried "Not Off", but this does not seem to work. I will post the event logs tonight once I'm home.
  13. starhome replied to danncas's topic in ISY994
    I have several Philips LED flood lights and they dim without any problem.
  14. I want to have the "house" wake me up (lights on, music on) by enabling this using a keypadlinc button. So what I really want is to have a program with the following condition if 'bedroom - keypad button A' is turned on and Time is 6:30:00AM then run program 'Music on (then Path)' but it never trigger the program.I assume you cannot simply look for a keypad button state (as it doesn't show up in the device status) so I'm looking for the proper/recommended what of doing this.. Thanks!! btw, I installed my ISY994 about 2 weeks ago and it's been pretty awesome so far. Got the network module and weather module as well. Support on the forum here has been top notch!!!
  15. I got it to work, I had an AND condition in the trigger. Thanks for your help!
