me23
  1. me23 posted a topic in ISY994
    Have someone ring doorbell, and the video from Panasonic cameras pop up on tv and/or computer. Can this be done with insteon and the isy?
  2. Oh, ok good. Thanks for all your help.
  3. Ok dont know why Im having a hard time with this Tried Momentary B per LeeG suggestion. Opens with a on command. Does not close with an off command. So the circuit is getting closed with the on command but not the off. What Im I doing wrong here guys?
  4. I gotcha. Just need to the off to work, like I said to initiate an all off program which would then close the door if it was open.
  5. Hey thanks for the response. I not worrying about scenes or programs right now, I guess I just want to know what to expect. Maybe I dont know, but I just thought after I open the garage door by pressing on under the relay in the ISY, if I press off it should close. Thats all my expectations are at the moment. The sensor works fine. I eventually want to run an all off program, but if the garage door wont close by pressing off, i guess this is a problem. I have black and red wires to the I/O. The led is off when the garage door closes and when it is open under relay and sensor it says on. I am using momentary A at the moment and it is not responding to the off button being pushed under relay in the ISY. Im using the smarthome i/o linc garage kit. Thanks for any advice and help
  6. Ok, now my turn. I just got this. Im having the same issue, the off command on the relay will not close the garage. Ok, what I want are the usual, On and off by the isy and when manually turned on or off by the door opener, i can also close or open with the isy. I have factory reset it, The sensor works fine, on wihen its open and off when its not. I can open the door with on command with isy and close it by pressing on again. Just cant use the off command. I tried messing with the set options, but would like a little guidance. Is it supposed to be in momentary c? I tried using the relay follows input, but I couldnt open manually with the opener. Thanks
  7. Anyone have issues running two ezfloras. I've got 10 zones. Also, can you just leave your current controller hooked up and off, and just splice to the ezfloras. That way you could always have the pro-c for backup
  8. Michel, Any chance of supporting the EZUIRT.
  9. me23 replied to me23's topic in ISY994
    Sound advice for sure!
  10. me23 replied to me23's topic in ISY994
    Yeah, I wished I hadn't formatted it either. Oh well, live and learn. I'm good now, just re-adding my devices. Besides, it gave me an opportunity to clean up some stuff. Thanks for help.
  11. me23 replied to me23's topic in ISY994
    Any advice on the other issues am having?
  12. me23 replied to me23's topic in ISY994
    Well it turns out those 2 blinking in tandom means its not connecting to the network. So replaced a cable and its working again. Of course I couldnt find my isy backup anywhere and have to start over since i formatted the card. Since some of my scenes still work and I presume still in the PLM, no way to get them over to the isy? If I have to redo things, do I need factory default the PLM or the switches? Or can I just re add the devices. Also not able to access the isy through my lightning, have to use universal-devices.com isy link to get to it. Thanks for the help guys
  13. me23 replied to me23's topic in ISY994
    No, I haven't been able to access it at all. I cant get into the isy to check anything.
  14. me23 posted a topic in ISY994
    Have ISY 99i pro with 2.7.15. I couldnt access it at all today. Looked at it and see the mem and error lights blinking in tandom every 5 seconds. I have scenes that are still responding and working. PLM is 2412S ver 2.9 I powered down both plm and isy and waited like 30 seconds, still doing the same and also took out the sd card and formatted it. Still the same Is it hosed, anything else to try?
  15. me23 replied to me23's topic in ISY994
    Yep, that was it. I moved to another place and bam, linked fine. Had to unplug an ethernet device to use it, so great now got to figure what to do with that other device. Isnt that weird though, how it used to work in this one location, and now it doesnt. Thanks for the help guys.
