Best way to remove zwave device with broken button?
Thanks for replying - the ghost devices showing up in the neighbors list, for the most part, are not going away - I had 7 of 30 devices with at least one ghost neighbor - one of them with a single ghost neighbor updated and now has no ghost neighbors, but the other 6 still have one or more ghosts - I was hoping that there was a way to SSH into the eisy and do something to purge all of the ghosts - it's looking like I may have to exclude and re-include some devices - this seems like a bug with ZMatter, but at least all of the devices seem to be working
I took a total of 7 Minoston ZP21D's out of service, 5 by excluding - I was finally able to get Zwave->Remove Failed Node to work for the other two, at least the AC did something and they went away, but an error message appeared at the end - Now, unfortunately, I have some of the removed devices appearing in the list of neighbors for some of my remaining z-wave devices - heal network does not make them go away - any advice on how to remove devices from the neighbors list? Is this a problem, or should I just ignore?
I have two Minoston ZP21D on off plugs where the button has seized up - I want to take them out of service, but I can't press the button 3X to exclude them - I tried Zwave->Remove Failed Node and get an error message - I want to remove these without leaving any ghost devices - what is the best way to remove them? right click->delete?
EISY 6.0.5
Let us know where you end up - I also had problems and Michel remotely fixed my eisy, but I am now on version 6.0.4 - he also asked me for my Z-wave device count and briefly mentioned a z-wave issue (but I don't know specifically what that was) - so I'm wondering when it will be safe to attempt a future update - I am not going to try until I hear that the issues, whatever they are, are fixed
EISY 6.0.5
I think it was 6.0.3 based on the name of the backup file - now, thanks to Michael K I am back up and running, but not on the latest version - now on 6.0.4
EISY 6.0.5
After re-reading this - I think that I'm in the same state - opened a ticket UPDATE: was able to access AC after pasting "https://eisy.local:8443/desc" into IoX finder because it wouldn't find the eisy, programs would not load, did a "restart IoX" from the Config page, but now I seem to be in an infinite loop where the AC says "Initializing System going from 0-100%" with a dialog box indicating "Completing Initialization" and this just repeats indefintely
EISY 6.0.5
Tried to update and now the admin console says "Completing Initialization" for a long time, followed by something like unable to load IoX nodes and then prompted to exit the AC -followed by the AC not being detected/accessible at all - cycled power multiple times but it leads to the same state and the eisy is not working - I can ssh into the eisy, though but don't know what to do to recover wish I didn't attempt this software update
IoX always ask to verify DSK at startup
I guess I'll answer my own question - re-booting the eisy seems to have fixed the problem, but I still have some zwave and zigbee "ghost devices" that I cannot figure out how to delete - these show up under zwave->xray->DH All devices
Whenever I start up the IoX admin console, I get prompted to verify the DSK for a zwave device that I have previously excluded and should otherwise not exist - it is acting as if the inclusion/add device process is still in-progress - the device cannot be found anywhere in the IoX admin console and does not show up under Z-wave->xray->DH All Devices - the device in question is a Enbrighten ceiling fan control switch - I have another one of these which does not exhibit this problem - does anyone have any idea how to fix this?
Cannot remove ghost devices (ZWave and Zigbee)
I have 3 ZWave and 2 Zigbee ghost devices that I cannot remove - for the Zigbee devices, I have tried "Synchronize New and Deleted with Interview" then select the devices and do "remove from Zigbee Network", then "delete" but that doesn't work - for the ZWave devices I did "Synchronize New and Deleted with Interview" then select the devices and "remove failed node" - that results in the following error "LIB_DRIVERS-UYZ_GEN_ERR_9_BODY" - is there another way to delete these ghost devices? (BTW - performing a "delete" when selecting the device will make it disappear from the admin console, but I can see that all the devices still exist under xray->DH ALL DEVICES and the zwave devices show up when doing a "heal network", then "Synchronize New and Deleted" will make them re-appear)
How do I remove bogus zwave devices?
In my case, the devices are not present where other devices are located in the admin panel - they appear to exist in the debug window when doing (1) Heal Network and also (2) when you select a z-wave device and do Xray->DH All Devices - then they also show up - so I just can't right click and delete - that is the problem
I've got at least 3 Zwave devices that show up when trying to do a heal network that are not there - ZY033, ZY035, ZY044 - they also show up doing a DH All Devices under XRay, but other than that there don't show up anywhere else - how do I go about deleting these without having to reset the ZMatter dongle?
Zooz ZEN05 8800LR Outdoor Plug
Oh no - I recently added 3 Zooz devices and left the secure inclusion checkboxes enabled - when prompted for the PIN, I just made one up - all 3 devices seem to work fine, but I did see that pop-up one time - is there any way to check which z-wave devices were included securely vs. unsecurely? If secure inclusion is going to cause problems, then I'm good with non-secure as I just want things to work...
- Thermostat Recommendation Needed
IOX 6 Upgrade Risks or Issues?
I upgraded a couple of weeks ago with no issues - the only minor thing is that the admin console login method changes to your isy portal login - unless you manually add a URL to IoX finder to login the old way
