BamBamF16
  1. How do i get it to stop notifying me I have an upgrade available? I'm on 6.0.3 but I wants me to upgrade to 6.0.0 Thanks.
  2. Folder auto opening is fixed. Clicking on Node column to sort does not. Just a random sort order. Consistently the same incorrect order.
  3. Control is an event caused by actuation of a device only (not from a program or the AC). It may not necessarily cause a status change (switch is already on and you turn it on again). So it really depends do you want the program fired on an actuation event or only when status changes. So in this case the motion actuation is a control event and you want the program firing on the motion control is appropriate.
  4. Post the actual program from the AC.
  5. The admin console is correct. The eisy ui has the correct value options in the drop downs. But the upper status display is only showing True/False.
  6. For i3 Paddles (and i3 Dial) on the flag node the options are: Mode - Relay or Dimmer Program Lock, Resume Dim, Relay at Full On, Key Beep, Disable RF and Error Blink are all On or Off. The selection drop downs are correct with the right options. It is only the current status on the top half of the screen that show True/False incorrectly.
  7. I can't attach SS for some reason. But in the AC there is "Move to Temperature", "Move Temperature" and "Step Temperature". In the new UI "Move to Temperature" is not present.
  8. Also, one of the flags, Relay at Full On, has incorrect data. It shows as True/False but should be On/Off. This is for an i3 paddle on the flag node. See SS. Also, the Mode should be showing "Relay" not True.
  9. 4.2 fixed my insteon node issues. Except I don't have any scenes. I don't see any option to "Move to Temperature" like the AC has. And it works fine in the AC.
  10. Hue bulbs added via zigbee direct have some issues. There is no way to direct set a color temperature. Also the stepping is backwards (to me). If you set it to step "Down" in temp, the K increases (4000K to 4016K). "Up" does the opposite.
  11. Add one more to the tally of users that have nodedef issues for insteon only items. ZWave and zigbee things seem to work OK.
  12. It should have added more than 1 node. I got 4 for each bulb. One didn't do anything and I deleted it. The other three were groupable. The 2 sub groups allow color changes etc.
  13. My direct connect hue bulbs work fine. Can set any parameter.
  14. So I upgraded as per the directions. I am on 5.9.1 now but the OS did not upgrade. Not sure what to do now.
  15. BamBamF16 replied to BamBamF16's topic in Insteon
    I have factory reset them multiple times. Then restore device. They actually work better PRIOR to the restore device. And the devices work great when the scene is activated by the AC.
