G W
Everything posted by G W
  1. No. The eMMC is gone, thus the need to revert back to it.
  2. The NVMe is bad. I know it is bad becasue it had issues before and it was replaced by Samsung. I should have destroyed it but i didn't and now I am paying for that error.
  3. It might be I'm hoping Michel has written a script by now. Or at least has a script to to revert to factory. I think I have used up all my tickect time for this month.
  4. @Michel Kohanim I just discovered an issue with my NVMe, it is defective, and need to revert back to eMMC. The eMMC is wiped out and does not exist. Do you have a script for this or a script to restore the eisy to factory. I am not worried about data as I have everything backed up on my computer. This is not my month for working with isy. Second time I have messed up. Best regards, Gary
  5. What are the plans for Matter? 1.3 is currently in Beta and has a few new items. Thread is 3.0 and still a pain until to new big fixes get fully implemented. Wi-Fi is already in place and I think it should be fairly easy to add Matter over Wi-Fi. So, @Michel Kohanim, can you give us any insight as to what your plans are for these items? Best regards, Gary
  6. I haven't had time to be active in much of anything. I finally got to a point that I could let go of several projects and relax.
  7. Darn. I was hoping it Matter over Wi-Fi.
  8. The Polisy is online. I gave it my best but in the end, the Polisy refused to play nice. My punishment for negotiating it over the years. I updated Michel on my lack of progress and the latest observations. Monday morning, through a remote session, Michel tickled the keys on his keyboard and convinced Polisy to accept a completely new set of updates. A few minutes later the system completed the updated and came online. The next step was to locate the serial cable which took a day to find. The actual backup and restore took less than four minutes. I was actually disappointed in the restore process. It happened so quick I didn't get to see it. Well, Blueboy is online and the system is happy. I need to check the system and ensure all the links are in order. Support from UDI is still 100% and I'm great full for this community and the UDI staff. Thank you, Michel.
  9. G W replied to jlamb's topic in Polisy
    I'd like to know this top. I tried holding the reset button but after 60 seconds, I gave up.
  10. I thought is was fixed. [admin@polisy ~]$ sudo pkg update && sudo pkg upgrade Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Checking for upgrades (0 candidates): 100% Processing candidates (0 candidates): 100% Checking integrity... done (0 conflicting) Your packages are up to date. [admin@polisy ~]$ pkg info udx pkg: No package(s) matching udx [admin@polisy ~]$ sudo service udx restart udx does not exist in /etc/rc.d or the local startup directories (/usr/local/etc/rc.d), or is not executable
  11. Yes, I did. It spent more time rebooting than most cities have boot. I think the issue was that 13.sh never didn't happen because the command failed. It's fixed now. Thank you, @Michel Kohanim
  12. Ticket 17382
  13. I tried that and more.
  14. That's exactly the steps I did and the results are in my post.
  15. I need help. I can't get past 12.2. The ISY Finder will not find the polisy. I have tried to Add it with https://192.168.2.45:8443/desc, http://192.168.2.45:8443/desc and all other variations. This is one of the original Beta units. [admin@polisy ~]$ sudo pkg update && sudo pkg upgrade Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Checking for upgrades (0 candidates): 100% Processing candidates (0 candidates): 100% Checking integrity... done (0 conflicting) Your packages are up to date. [admin@polisy ~]$ pkg info udx pkg: No package(s) matching udx [admin@polisy ~]$ pkg info isy pkg: No package(s) matching isy [admin@polisy ~]$ sudo uname -a FreeBSD polisy 12.2-RELEASE-p6 FreeBSD 12.2-RELEASE-p6 r369564 POLISY amd64 [admin@polisy ~]$ curl -s https://pkg.isy.io/script/update121.sh | sudo bash Password: Nothing to do. Installing FreeBSD-base updates Updating FreeBSD-base repository catalogue... Fetching meta.conf: 100% 163 B 0.2kB/s 00:01 Fetching packagesite.txz: 100% 20 KiB 20.4kB/s 00:01 Processing entries: 100% FreeBSD-base repository update completed. 284 packages processed. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Checking for upgrades (0 candidates): 100% Processing candidates (0 candidates): 100% Checking integrity... done (0 conflicting) Your packages are up to date. Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. All repositories are up to date. Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Checking integrity... done (0 conflicting) The most recent versions of packages are already installed lookig for .pkgnew files... Preserving files that are unique to Polisy lookig for any left over .pkgnew files... Upgrade complete, please reboot using: sudo shutdown -r now [admin@polisy ~]$ [admin@polisy ~]$ cat /usr/local/etc/udx.d/static/update13.sh | sudo bash cat: /usr/local/etc/udx.d/static/update13.sh: No such file or directory
  16. You're just not worth it. This entire forum isn't worth it.
  17. Go to any lumber store and ask for baseboard. You will be shown items that are no less than 1/2 inch thick. You can say the same thing to Larry but you didn't. The is no code in Canada that says it's 1/4 inch. Besides, Canada is metric. And you can't even quote me correctly.
  18. I didn't say there was a code. I've noticed you like to read into sentences what isn't stated.
  19. In US baseboard is 1/2 inch thick so that's not an issue.
  20. I don't wear shoes in my house.
  21. That's a reasonable thought. But having quarter round there is no guarantee that there is sufficient space. Mostly it all comes down to personal preference. Builders build as cheap as possible as they can unless told otherwise. The whole purpose of baseboard and molding is to hide flaws and imperfections.
  22. That's where you and I are different. My house is 12 years old and if looks like it was just built and we just moved in. I keep my house ready to sell in a week. I also don't take any short cuts. As for what most people like, neither of us are qualified nor have the facts to speak such.
  23. I don't know what to tell you. I suppose it's a way the builder can save money. As for the UK, that speaks for itself. LOL Let's ask the OP what he has.
  24. Wow. That's just sad. I've never seen that stunt on a house as built. Why such a large expansion space? I can only guess the builder didn't fit the floor to the wall and didn't cut the flooring to fit closer to the wall.
  25. Oh hell no. I just did and I removed all the old baseboard. I'm not so cheap or stupid as to pull that kind of BS stunt.
