espann
Everything posted by espann
  1. Ok, so if I buy the Mobilinc Pro, how long do I have to try it and if I don't like it will I be able to return it? And is there no other method of controlling lights thru ISY and my cell phone, without paying more money?
  2. Thanks Sanders, where can I get the UD Ajax program? Actually the Ajax GUI, I found some source code for Ajax but that looks rather daunting!
  3. Thanks, I had downloaded the mobilinc trial a few months ago, didn't try it, and now it has expired. Guess I'll have to pay the $19.99 to see if it works on my system
  4. Hello experts, this may have covered somewhere in the forum but I didn't find it yet. I want to be able to control my lighting with my android cell phone. I have ISY-994i and can control lights from the administrative console but I want to control on/off, dimming, etc, from my cell phone. I've heard of the Insteon HUB but people here have said that this could be done with the ISY and some other apps? If so I'd like some help finding the app for this that will work with ISY-994 Thanks all, Ed Spann
  5. espann replied to flsenior's topic in ISY994
    Thanks Michel. I'm at my router configuration page. My next question is, of the options listed on the wiki page, I think the best one for me is: "On your router, make ISY's IP lease permanent (DHCP Reservation)," So under "DHCP Lease time" should I choose "Make Lease Permanent", and will this effect other devices connected to my computer (my web cameras for example)? I've tried most of the other suggestions and I still get Not Able to Connect to Internet from ISY. I think I have the router configured for port forwarding correctly, as I see the address in ISY as 10.0.0.11
  6. espann replied to flsenior's topic in ISY994
    Ok, I'm at the port forwarding window in my router, and I added a new service(TCP & UDP), called it ISY but I'm not sure how to configure the port, it's asking for port number so I put in 10.0.0.11 for the server port, and 11 for the Start and End ports. The router administration recognized it finally but still no internet connection in ISY! This is where I previously had to add porting service for my Swann camera access on my smartphone.
  7. espann replied to flsenior's topic in ISY994
    Hi Michel, I also have an issue with trying to install the Mobilinc software. From the Admin console I get the same error message: "Failed enabling internet access". And I don't see an option to disable internet access, so my Mobilinc Lite program cant register the software! when I log into my local router IP it shows I'm connected to 10.0.0.11. and the mac address is the same as shown on the admin console "about" window.
  8. thanks for your reply stusviews, they are CFL's not LED's but I'm assuming these are not dimmable. I'll try to find those next
  9. Thanks LeeG, now my only problem is with the 60 watt CFL light bulbs I have. When I turn a device on at full power through a LampLinc device, it lights OK. But when I set the control for less than 100% brightness it doesn't change the brightness, or starts to flicker. Is there a solution for this or just an incompatibility with Insteon and this kind of light bulb?
  10. Thanks LeeG, that seems to have done it. I deleted the old profile for that device, added it again and now I see 8 separate addresses, I assume these are for each button.
  11. Hi guys, I upgraded to the ISY994i, so now I need to know how to get the buttons to show up in the tree. My KeypadLinc shows up in the administrative console but there are no buttons that I can see. At the buttom of the window there are several buttons, such as "Buttons Grouping" and "Buttons Toggle mode), but I don't know what to do with these
  12. Thanks EricK, I'll check it out.
  13. Hi LeeG. I think I solved this thanks to you and Jimbo. I don't know how to send my reply to Jimbo in the later post but here it is, quoted: I think I figured out what I was doing wrong. I did not add the second button, the one with the LampLinc load button B as a responder to the Main button on the KPL. I added that button, as described under "Advanced Features, Add Multiple Scene Responders" in the Keypad Dimmer Owners manual, and now the Main Button on the KPL does indeed turn on both devices and to the On Level set in the ISY. Thanks to LeeG and Jimbo for your help!
  14. I finally figured out what I was doing wrong. I did not add the second button, the one with the LampLinc load button B as a responder to the Main button on the KPL. I added that button, as described under "Advanced Features, Add Multiple Scene Responders" in the Keypad Dimmer Owners manual, and now the Main Button on the KPL does indeed turn on both devices and to the On Level set in the ISY. Thanks to LeeG and Jimbo for your help!
  15. Hi LeeG, my problem now seems to be that the MAIN button on the KPL only controls the load connected to it, but not the LampLinc which is connected to button "B". Button B will turn on its load but the main button does not. How do I get the Main button on the KPL to turn on the scene? I have both responders setup in the scene in my ISY and their On Levels set to 20% Thanks, Ed Spann
  16. Sorry, Jimbo, my mistake. I was thinking that the picture box that looks like a traffic light was supposed to be red, not the description itself. That is "red" as you said. I'm still working on getting both the responders to come on but I'm resetting both devices and I'll see it that gets them to respond in the scene. Thanks for your help!
  17. Hi Jimbo, my scenes button is expanded, but my controllers are not red. But my bigger concern is that the lampLinc doesn't come on at all when I press the main button on the KPL! Maybe I have to reset the LampLinc, I'll try that.
  18. Hi LeeG, I set the levels both to 35%, but when I press the Main button on the KPL the KPL load goes to 100% and the LampLinc doesn't come on at all. (btw, I don't see the "Red controller nodes" as such; I just have what looks like a traffic light but its not red. But I did set the Local On Levels there.)
  19. I'm trying to have my KPL 8 button to setup a scene that would control 2 devices, one is the lamp which is on the "Button Main" by default, and the other device is a LampLinc dimmer. I want the 2 devices to go to 35% brightness when the scene is initiated but I don't know how to do that. I've tried searching here but nothing seems to spell it out for me. I have the ISY994i/IR and I created a new scene called Front Room, and added these 2 devices, but from there I am lost. I don't know how to assign the scene to a button in the KPL and finish the scene. I see at the button of the KPL window the "Buttons Grouping" and "Buttons Toggle" buttons, but I'm lost from there. Should I create a "Program" first? Please help! Thanks, Ed Spann
  20. Thanks LeeG, never noticed that refresh button
  21. Thanks LeeG. Once again the forum comes thru! After changing the settings to what you posted above, the program runs every time, even after as few as 5-10 seconds. The Programs>Summary window still shows Running 'Then' in the activity column long after it finishes, but I can live with that..
  22. The options show: Timeout=1 min As motion is sensed is not checked LED brightness=100 On only mode is checked Night mode Always is checked
  23. Thanks, LeeG. How do I check the motion sensor options?
  24. Ok, here is the program: If Control '2D.3E.42-Sensor' is switched On Then Repeat 3 times Set 'OfficeLamp' On Wait 2 seconds Set 'OfficeLamp' Off Wait 2 seconds Else - No Actions - (To add one, press 'Action') However, there is another program that gets triggered by the MS also: If Control '2D.3E.42-Sensor' is switched On Then Repeat 3 times Set 'MBedrm' On Wait 2 seconds Set 'MBedrm' Off Wait 2 seconds Else - No Actions - (To add one, press 'Action') So could this be the problem, that it triggers 2 programs?
  25. When my programs are triggered by the motion sensor and the "IF THEN" program starts, the program runs ok and flashes my lights 3 times then stops. The problem is that if another motion is sensed by the ms, it doesn't always trigger the program, especially if it is within a minute or so of the 1st event. And when I look at the Administrative console under Programs>Summary, it shows the "IF THEN" is still running and does so for several minutes. How do I get the "IF THEN" program to stop sooner, like within 5-10 seconds of the finish of the event?
