jackiemeck
  1. Brian: The SD card info is very helpful. Thank you. I have a 128MB card, with 75MB free. Should I upgrade the firmware to the present card first, and then install a 2GB card, or backup/restore to a new 2GB card. Didn't I see something that said ISY didn't like the larger size until it got to version 3?
  2. Michel: I've had my ISY99 since August 2008 (Love it!). I'm on v2.8.16. I'd like to upgrade, but see this thread about the older SD cards. How do I know what size my SD card is and whether I need to replace it before upgrading and messing everything up. I have an extra SD card, but will I lose my settings if I swap it out? Is there an article somewhere to address upgrading the SD card? I just want to proceed carefully...I have over 100 devices. Thanks, Jackie
  3. Thanks! I got the fix and all is well. The HomeSeer ISYInsteon plugin is a great addition to the power and reliability of the ISY.
  4. Michel: I really like the new enhancements in 2.7.7 and 2.7.8. Really solid work. I've upgraded my Pro to 2.7.8. Is it possible that the Homeseer "Plug-in for Universal Devices Insteon ISY" would no longer work due to changes in for 2.7.8? Homeseer previously would read in all the devices under 2.7.7 and communicate back and forth via this interface. Now, I'm getting an "ISY configuration query attempt failed" message and it won't link. I'm checking with isyinsteon@bobsplace.com, but thought I would also check with you. Thanks...keep up the good work. Jackie
