saninberg
  1. Did anyone figure out the JSON file format. I have a PLC I would like to try and talk to. I can open ticket. I didn't want to bother them if someone else has already got this to work and can pass the information on to the rest of us. thanks
  2. I could not get 1st gen zcombo units to display on Polisy or Eisy like they did on the ISY994. Only the zcombo 2nd generation would display correctly.
  3. Have you checked out this video on youtube. Some settings on camera side need to be changed.
  4. Jimbo.Automates I have the FGRGBW-442 Fibaro controller. It was first added to ISY-994 and then migrated to polisy. It is working on the polisy with zmatter internal board, but I have not been able to get it to complete interview.
  5. saninberg replied to Techman's topic in IoX Support
    I selected the device ( in this case a Zooz Zen 32 ) right click and it brings up menu. I only have couple devices out of 72 that support OTA. FYI next screen that comes up.
  6. saninberg replied to Techman's topic in IoX Support
    Found it. but have not tried it yet.
  7. @Riggins44 When I added the Sengled ( E11-N1EAW_2PK ) it added 2 devices for the bulb. Color Hue-Sat device & On / Off Switch device I do not have any separate Zigbee switches; The bulb is the only Zigbee device I have purchased so far.
  8. ShawnW I just got the 2 bulbs ( no hub ). I just added the 2nd bulb. I did it within 5 feet of the polisy. It added without and issue. Observation .....the addressing doesn't seem to be following any order and this one listed the switch first and then the Hue/Saturation.
  9. I am using the internal ZMatter module
  10. I ordered Sengled ( E11-N1EAW_2PK ) from Amazon for testing. I needed replacement for zwave color bulb. It added to Polisy without any issues. Light fixture was within 30 ft of the polisy. I am just using Green and Red for indication for all doors closed. Just an observation: The Hue and Saturation settings only show in the action area. ( not in the program line ) The zwave bulb would show settings in the progam line. Example : Set 'Door Status Dimmer Light / Door Status Color Light' Warm White 0, Cold White 0, Red 0, Green 255, Blue 0,
  11. MrMike...........This was the reply I received from support. If you have Insteon then ZMatter Z-Wave may be using either port cuaU0 or cuaU1 If you only have ZMatter Z-Wave installed with no other USB connected then it is using port cuaU0 Please do the following: On the configuration tab, choose "Upgrade Packages" to get the latest update After ISY restarts, do this from a browser (if you use Help | About in Admin Console it will show your IP address e.g. something like 192.168.0.51) http://<your_polisy>:8080/rest/zmatter/zwave/port/name/override/set/cuaU0 You should get this back (its important you see the 200) <RestResponse succeeded="true"> <status>200</status> </RestResponse> Restart IoX and it should connect properly to you ZMatter Z-Wave board / dongle If it doesn't reconnect, try again using cuaU1 To remove this override do the following: http://<your_polisy>:8080/rest/zmatter/zwave/port/name/override/clear
  12. I have the same condition. Do you have details for this workaround?
  13. But what is confusing, these are listed on the notify sensor page. But do not work and I had forgotten about using other method.
  14. I got a Zooz ZSE29 motion sensor today and was trying to set parameters from the notify sensor page, even with pressing the tamper switch 3 times to wake up the sensor. I could not query or set parameters. But when I right click, select zwave and then select set configuration parameters from this small window I can query and set parameters when waking up the sensor.
  15. I sent email to Michel, My issue was an hardware issue. it is resolved. thanks Michel thanks to everyone who replied Larry
