Carey737
  1. Thank you. I will look into that.
  2. Should have said everything I have in lighting is insteon. No zwave lights.
  3. Is there a way to have my vivint cameras trigger events like lights etc.?
  4. Thanks everyone for the info. 994i is on the way. Stand by for more newbie questions.
  5. Ok. Thank you so much. Ill try upgrading to 994 and go from there.
  6. Sorry for the ignorance, but shouldn't an I2CS device be compatible with the isy99i running 3.3.10? Will upgrading to the 994i fix this specific issue? Or is there possibly something else going on? Once again, I appreciate the responses, Carey
  7. I called Insteon tech support and they said that particular switch should still work with the 99i Can someone take a look at the event log and give me any more insight? I would really like to use the 99i for a bit longer to see if this is something I want to continue before I drop the cash for a new isy. Thanks in advance, Carey Sat 08/23/2014 11:52:15 AM : [20 8B C4 ] Added to list of devices to link to ISY Sat 08/23/2014 11:52:15 AM : [iNST-TX-I1 ] 02 62 20 8B C4 0F 0D 00 Sat 08/23/2014 11:52:15 AM : [iNST-ACK ] 02 62 20.8B.C4 0F 0D 00 06 (00) Sat 08/23/2014 11:52:15 AM : [iNST-SRX ] 02 50 20.8B.C4 2F.BA.C4 AB 0D FF (FF) Sat 08/23/2014 11:52:15 AM : [std-Direct Nack] 20.8B.C4-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 08/23/2014 11:52:15 AM : [iNST-TX-I2CS] 02 62 20 8B C4 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 Sat 08/23/2014 11:52:15 AM : [iNST-ACK ] 02 62 20.8B.C4 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01) Sat 08/23/2014 11:52:24 AM : [iNST-TX-I2CS] 02 62 20 8B C4 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 Sat 08/23/2014 11:52:24 AM : [iNST-ACK ] 02 62 20.8B.C4 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01) Sat 08/23/2014 11:52:33 AM : [iNST-TX-I2CS] 02 62 20 8B C4 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 Sat 08/23/2014 11:52:33 AM : [iNST-ACK ] 02 62 20.8B.C4 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01) Sat 08/23/2014 11:52:33 AM : [ Time] 11:52:34 1(0) Sat 08/23/2014 11:52:33 AM : [iNST-SRX ] 02 50 20.8B.C4 2F.BA.C4 2B 09 01 LNK-ON (01) Sat 08/23/2014 11:52:33 AM : [std-Direct Ack] 20.8B.C4-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 08/23/2014 11:52:33 AM : [LNK-BGN ] 02 64 01 00 06 Sat 08/23/2014 11:52:34 AM : [LNK-STAT ] 02 53 M(01) gid=00 20.8B.C4 022A 42 Sat 08/23/2014 11:52:34 AM : [iNST-TX-I1 ] 02 62 20 8B C4 0F 0D 00 Sat 08/23/2014 11:52:34 AM : [LNK-END ] 02 65 06 Sat 08/23/2014 11:52:34 AM : [std MH ] Unexpected Ack imCmd=65 cmd1= 0xC4 Sat 08/23/2014 11:52:35 AM : [iNST-ACK ] 02 62 20.8B.C4 0F 0D 00 06 (00) Sat 08/23/2014 11:52:36 AM : [iNST-SRX ] 02 50 20.8B.C4 2F.BA.C4 2B 0D 02 (02) Sat 08/23/2014 11:52:36 AM : [std-Direct Ack] 20.8B.C4-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 08/23/2014 11:52:39 AM : [iNST-TX-I1 ] 02 62 20 8B C4 0F 0D 00 Sat 08/23/2014 11:52:39 AM : [iNST-ACK ] 02 62 20.8B.C4 0F 0D 00 06 (00) Sat 08/23/2014 11:52:39 AM : [iNST-SRX ] 02 50 20.8B.C4 2F.BA.C4 2B 0D 02 (02) Sat 08/23/2014 11:52:39 AM : [std-Direct Ack] 20.8B.C4-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 08/23/2014 11:52:39 AM : [iNST-TX-I1 ] 02 62 20 8B C4 0F 10 00 Sat 08/23/2014 11:52:39 AM : [iNST-ACK ] 02 62 20.8B.C4 0F 10 00 06 ID-REQ (00) Sat 08/23/2014 11:52:48 AM : [iNST-TX-I1 ] 02 62 20 8B C4 0F 10 00 Sat 08/23/2014 11:52:48 AM : [iNST-ACK ] 02 62 20.8B.C4 0F 10 00 06 ID-REQ (00) Sat 08/23/2014 11:52:57 AM : [iNST-TX-I1 ] 02 62 20 8B C4 0F 10 00 Sat 08/23/2014 11:52:57 AM : [iNST-ACK ] 02 62 20.8B.C4 0F 10 00 06 ID-REQ (00) Sat 08/23/2014 11:53:01 AM : [20 8B C4 0 ] Cannot determine device type Sat 08/23/2014 11:53:01 AM : [20 8B C4 0 ] Failed to add device
  8. That's what I thought. Thanks for the reply. Ordering 994i now.
  9. Hi, New to isy. I have an isy99i loaned to me to try out the system. I purchased a couple of 2744S light switches to get started. When I try to link switch to isy I get the error message "can not determine insteon engine". The firmware for the isy99i is 3.3.10. Is this a compatibility with the switch and the 99i? I have been able to link a motion sensor, and the switch is fairly close to PLM (25'). Thanks for any assistance, Carey
