Todd C
  1. Hi Stu, Model: ISY 994i 1024 IR Platform: ISY-C-994 Version: 4.2.30 Build Timestamp: 2015-04-02-09:09:20 I am presented with the web interface and am able to use it without issue. Thanks, Todd
  2. Hello, My Administrative Console disconnects consistently after 15 seconds and I am prompted with the login screen. Logging back in resumes the session but the disconnect happens again consistently after 15 seconds. This issue was happening on my older computer so I setup the admin console on my new computer with fresh install, java client and clear cache. My ISY is up to date with the latest release. Thanks for your help. Todd
  3. Problem solved. It came down to the UI version was not the most recent so my views were not updating everything. Once it was updated, the green/red data and program information on the program summary screens reflected the program activity. Thanks everyone for their input. Appreciate the support call on this UDI!!!!
  4. Michel, This is true for programs that are not in any folders and also in folders that are true. For example, I tried running the programs in the folder "daytime" which is true from sunrise to sunset. I'm not seeing consistent results at this point - they're not doing anything. I moved them out of that folder to the root and ran them again but nothing is happening. I'm going to call in a ticket becuase there have been other odd issues I've experienced that I assumed were due to my learning but now I'm convinced something is wrong with this unit. Todd
  5. Thanks for the feedback. I think there is something wrong with my ISY. My conclusion is based on the following: 1) I have triggered several programs to execute - I did this by going to doors and opening and closing them to trigger various programs. The programs ran but but did not indicate a "green" status before, during, or after the program completed. All of the programs on the details tab are still white. 2) I selected all of my programs from the summary page and ran them - my details tab still does not show anything as green or red. Oberkc: Although I can call programs in a folder who's condition is set to false and it technically "executes" the programs as noted in the last start/finish times - the action in the programs does not occur. Is this normal or related to my bigger ISY issues? Thanks, Todd
  6. Hello, Can someone help me confirm the programming behaviors on my ISY994i? My unit is a PRO with upgraded IR and also Z-Wave Module. I am enclosing a screen shot of my programs screen with the green and red status indicators reflecting what is true and false at the current time. Focus on the section for C. Evening which is currently red because the time restriction is to run from about Sunset until 11:30 PM. The programs under the C. Evening folder appear some white and some green. What I am trying to figure out is why any of them would be green given the time restriction for the C. Evening folder which is not currently active. In addition, I see inconsistent results in terms of what is white and green within that folder. I am pasting two programs below - one that is showing as white (M: Guest Bath) and another program that is showing as green (M: MBR Lamps). These two programs are identical in nature (as far as I can tell) yet yield different status results. The program content of the two programs in the C. Evening folder are: M: Guest Bath If Control '4. Guest Bed and Bath / Bath Sensor / Guest Bath-Sensor' is switched On Then Set '4. Guest Bed and Bath / Guest Bath Light' On Set '4. Guest Bed and Bath / Guest Bath Fan' On Wait 20 minutes Set '4. Guest Bed and Bath / Guest Bath Fan' Off Set '4. Guest Bed and Bath / Guest Bath Light' Off Else - No Actions - (To add one, press 'Action') M: MBR Lamps If Control '5. Master Bedroom / MBR - Motion / M: MBR Lamps-Sensor' is switched On Then Set '5. Master Bedroom / MBR Lamps' 49% Wait 20 minutes Set '5. Master Bedroom / MBR Lamps' Off Else - No Actions - (To add one, press 'Action') After looking at both of these, my admin console became unresponsive (this happens frequently). When I connected back to it the programming screen has stopped showing any green or red status indicators. I rebooted my ISY and connected to it a few minutes ago and again - nothing is showing green or red AND the programs are now all showing as FALSE with the exception of one folder - but none of the programs beneath it are showing as true. What is going on? Am I doing something wrong? HELP! Thanks much in advance for any feedback. Thanks, Todd Czajka
  7. Thank you for posting these programs! I'm still not 100% sure of how the logic works - but it perfectly handles those exceptions when local lighting adjustments are made after the MS initially triggers the event.
