mrbudin
  1. mrbudin replied to hart2hart's topic in ISY994
    Hart2hart Can it be control via Mobilinc, and fully support by scense control, program of ÍY?
  2. Anyone has solution for this integration?
  3. Which Z-Wave thermostat would you recommend?
  4. Dear All, I am preparing to work on a very interesting demo project that use ISY 994i/ IR Pro with the following functions: Devices need to be controlled: - 8 lighting circuit - 1 DAIKIN FXDQ32PBVE air-con - 1 indoor panel button with four buttons : DND ( Do not disturb), Door bell, Cleaning Room and Bathroom that allows it to control LED Display Status Panel outdoor. - 1 key card switch to control some lighting. Project Requirement: - Smart Home design, using only 1 handy remote to control each light bulb, adjust temperature and DND and Make up room button integrated. - When guest press DND button, a DND notification light up and mute the ringtone when someone ring the bell. - When guest press Make up room button, a Make up room notification light up. - When guest enter and insert key card into card holder, some light which is programmed will light up. I am planning to use ISY 994i/ IR Pro with the following insteon devices - 8 x Switchlinc on/of to control 8 lighting circuits. - 1 x Insteon Thermostat or Nest Thermostat to control Daikin FXDQ32PBVE air-con - 1 x KeypadLinc - 6 buttons to control four LED Status Display Panel Outdoors (DND, Doorbell, Cleaning Room, Bathroom). - 1 Mini Remote or One Harmony Universal Device to control everything above remotely. Since this kind of project is very new to me, i have a few questions and need your help. - Can i use Harmony Universal Device Remote to control everything above including: switchlinc, keypadlinc, thermostat...? - Which Harmony Remote can work with ISY 994i IR Pro. I found many products from this link: http://www.logitech.com/en-us/harmony-remotes. Which products are suitable for me: Harmony 650, Harmony 350 or Harmony 700... - Could you recommend one Harmony remote for me? - Can Insteon Thermostat or Nest Thermostat can control singe split air-con like Daikin? If you've got any idea to share, i would be grateful to you. Regards,
  5. Dear All, I've been using an ISY 994i IR/Pro for 1-2 months. It worked fine until today. I can not access ISY, MEMORY and ERROR LED keep Blinking. Anyone could help fix this problem or should i return it to the seller?
  6. Yes, i've purchase this PLM since september.
  7. My ISY 994i information Firmware: 4.2.17 UI: 4.2.17 PLM: v9C Here are the error code: Mon 11/10/2014 10:03:22 PM : [27 17 6 ] Added to list of devices to link to ISY Mon 11/10/2014 10:03:22 PM : [iNST-TX-I1 ] 02 62 27 17 06 0F 0D 00 Mon 11/10/2014 10:03:22 PM : [iNST-ACK ] 02 62 27.17.06 0F 0D 00 06 (00) Mon 11/10/2014 10:03:22 PM : [iNST-SRX ] 02 50 27.17.06 2B.50.EA 2B 0D 02 (02) Mon 11/10/2014 10:03:22 PM : [std-Direct Ack] 27.17.06-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 11/10/2014 10:03:22 PM : [iNST-TX-I1 ] 02 62 27 17 06 0F 10 00 Mon 11/10/2014 10:03:22 PM : [iNST-ACK ] 02 62 27.17.06 0F 10 00 06 ID-REQ (00) Mon 11/10/2014 10:03:23 PM : [iNST-SRX ] 02 50 27.17.06 2B.50.EA 2F 10 00 ID-REQ (00) Mon 11/10/2014 10:03:23 PM : [std-Direct Ack] 27.17.06-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Mon 11/10/2014 10:03:23 PM : [iNST-SRX ] 02 50 27.17.06 00.12.37 87 02 15 (15) Mon 11/10/2014 10:03:23 PM : [std-Broadcast] 27.17.06-->00.12.37, Max Hops=3, Hops Left=1 Mon 11/10/2014 10:03:23 PM : [27 17 6 0 ] Calibrating engine version Mon 11/10/2014 10:03:23 PM : [iNST-TX-I2CS] 02 62 27 17 06 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 Mon 11/10/2014 10:03:32 PM : [iNST-TX-I2CS] 02 62 27 17 06 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 Mon 11/10/2014 10:03:32 PM : [iNST-ACK ] 02 62 27.17.06 1F 2F 00 00 00 00 00 01 00 00 00 00 02 62 27 17 06 1F (00) Mon 11/10/2014 10:03:33 PM : [iNST-SRX ] 02 50 27.17.06 2B.50.EA 2F 2F 00 (00) Mon 11/10/2014 10:03:33 PM : [std-Direct Ack] 27.17.06-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Mon 11/10/2014 10:03:33 PM : [iNST-DUP ] Previous message ignored. Mon 11/10/2014 10:03:42 PM : [iNST-TX-I2CS] 02 62 27 17 06 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 Mon 11/10/2014 10:03:42 PM : [iNST-ACK ] 02 62 27.17.06 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06 (00) Mon 11/10/2014 10:03:42 PM : [iNST-SRX ] 02 50 27.17.06 2B.50.EA 2F 2F 00 (00) Mon 11/10/2014 10:03:42 PM : [std-Direct Ack] 27.17.06-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Mon 11/10/2014 10:03:46 PM : [27 17 6 0 ] Failed to add device, reason 9 Mon 11/10/2014 10:03:46 PM : [All ] Writing 0 bytes to devices
  8. I can not add most of my insteon RF-only (None dual band) devices such as: Motion Sensor, Remote Linc, LED Bulb. Every time it happens "Can not add insteon engine" Very frustrated
  9. In my opinion, ISY development is limited since they are separate.
  10. There's a lot of thing to be done for Insteon/Smarthome. They should go global. - Fully support international user for all of their products include IO Linc, PLM... - New management software (They should buy ISY and develop it) - Improve mobile app
  11. Already done what you said above but it still doesn't work. Fri 10/31/2014 11:18:32 AM : [ 27 40 1E 1] ST 0 Fri 10/31/2014 11:18:33 AM : [ 27 40 1E 1] ST 255 Fri 10/31/2014 11:18:36 AM : [ 27 3F 24 1] ST 255 Fri 10/31/2014 11:25:19 AM : [27 17 6 ] Added to list of devices to link to ISY Fri 10/31/2014 11:25:44 AM : [27 17 6 0 ] Failed to add device, reason 9 Fri 10/31/2014 11:25:45 AM : [All ] Writing 0 bytes to devices Fri 10/31/2014 11:28:15 AM : [27 14 FB ] Added to list of devices to link to ISY Fri 10/31/2014 11:28:40 AM : [27 14 FB 0 ] Failed to add device, reason 9 Fri 10/31/2014 11:28:40 AM : [All ] Writing 0 bytes to devices
  12. I am running ISY 994i IR/Pro with PLM v9C (Firmware: 4.2.16). I've got the following errors when trying to add Motion Sensor and Mini Remote: - Cannot determine Insteon Engine - Cannot determine device link table addres With other dual-band devices like Switch Linc or Open Close, my ISY 994i and PLM work fine. I know someone has posted the same problems on this forum but i still need a help to solve my issue. Thanks
  13. mrbudin replied to sanders2222's topic in ISY994
    I am facing the same problem. What's the best solution to fix this?
  14. Dear LeeG, I've just submit my ticket. My timezone is different 12Hrs with yours so that i need your support urgently. Thanks
  15. I can not make my ISY 994i work remotely with Mobilinc. I need tech support from ISY. Anyone could help, please?
