danoj
  • Posts
    5
Everything posted by danoj
  1. Seems this works fine if I have a device in the scene. I used a KPL button and modified the Scene labels and Icon in Mobilinc to visually indicate state of the door. Would be nice not to tie up to KPL buttons if anyone has a better approach. Thanks
  2. Hello, I am new to the ISY994i. I have searched the forums and although there are many posts on garage door state/control, I have not found enough information to achieve my objective. I have the network module installed, and have access to the 32 zones monitored by my DSC alarm system. This includes door status on the two garage doors. Because I had this in place I purchased the iolink rather than the garage control set, hoping to use the existing variables rather than install additional sensors. The relay is working fine to open and close, but I have been unable to get something in place to monitor the state. My hope is to have a scene turn on and off for the state, or some other means to identify via Mobilinc if the door is open or closed. I do not plan on using a kpl button, although I do have one if required. Is it possible/relatively straight forward to do the above with a program? Is it easier or preferred for other reasons for me to simply run an additional wire from my existing door sensors to the inputs on the 2450? I have the following program which has the correct state of FALSE when the door is open, True when closed, however it does not change the scene in a way that is visible. Maybe I need to add a KPL button to the scene to reflect the state? ....did I just answer my own question? if $Shannon_Garage_door is 0 Then Set Scene 'Shani's Garage Door' Fast On Else Set Scene 'Shani's Garage Door' Fast Off Any direction is appreciated.
  • Create New...
