Grizzy
  1. Grizzy replied to Grizzy's topic in ISY994
    In the ISY what does the status of the motion sensor indicate when you have the off function disabled and there is no motion. Example: motion sensor detects motion, then motion sensor timer resets. Does ISY know status has changed from sensing motion to now none?
  2. Grizzy replied to Grizzy's topic in ISY994
    Option 1: I have included this in the program such that the lights are turned off. My issue comes in MobiLinc where my dashboard icons provide a quick visual indication on all my sensors. When one does not clear the on status MobiLinc lndicates a false trigger. Option 2: Good suggestion, I will give it a try. Do you have an idea how MobiLinc will handle this ? Thanks Donald
  3. Grizzy replied to Grizzy's topic in ISY994
    I have a motion sensor that is not 100% communicating. It will send a motion detected but the motion rest is not alway captured by the ISY, leaving some programs stuck. I have tried the query, write device updates and the only way I have found to reset the status indication was to disable and re-enable the device. I know the comm link cannot talk with the motion sensor unless it is placed in program mode locally. Due to its location that's just not feasible. I'm just hoping their is an easier way to force the ISY to toggle the motion sensor status to off. Someday I will have to improve the link path , but that is a ways off, so I'm hoping to find a quick fix. Any suggestions are much welcomed. Thanks
  4. Grizzy posted a topic in ISY994
    Hello, Is there a way to disable a device inside a program ? I'm running v4.5.4 Thanks
  5. Grizzy replied to Grizzy's topic in ISY994
    THANK YOU GARY ..........
  6. Grizzy posted a topic in ISY994
    Hello, Well my PLM bit the dust at a little over 2 years. I have seen somewhere a post with the Digi-Key part numbers of all the replacement caps. Looking in the catalog makes me cross eyed at all the different possibilities. Naturally I cannot find the list now. I would appreciate is someone could give the part numbers or a link where I can find them. Many thanks Donald
  7. So glad you have taken the time and effort to take this on. I do have a couple questions prior to purchase. Does it matter which model PLM I have ? Are the caps the correct physical size so that I will not have to make modifications ? Are the caps rated at the higher temps as noted throughout this discussion ? Again Thanks
  8. Hello, Can anyone give me good / bad feedback on the Insteon 2993-222 Diagnostics Keypad. Thanks Don
  9. Grizzy replied to Grizzy's topic in ISY994
    Are the older versions still available ? Where ? From reports UI has a good record on new releases, so I feel good there. I kinda believe if it's not broke don,t fix it. I'm sort of slow to jump at every new thing that emerges from a rapid changing technology. Gee I still use a DOS & win95 not to mention the TRS80 MOD III Although I,m really excited and waiting to see the release of version 5. ( hint, hint ) I see you point and agree. Don
  10. Grizzy replied to Grizzy's topic in ISY994
    Hi Teken, I cleared the cache and it deleted the ISY Icon on my desktop. Is this expected ? I reloaded the admin Console from the file I used on the original install. (Darn, can't remember where I got it, but at least I saved it after the install) Every thing has returned to normal ) Checked UI version and nothing changed there, so I'm not sure what happened or caused the problem .. gremlins ? Thank You All for your help. Don
  11. Grizzy replied to Grizzy's topic in ISY994
    Hi Michel, I tried the above link. It caused Java to do an upgrade to v8.40 Afterwards it was slower to load from the above link. Loading from the desktop icon still displays Java and a progress bar and it still slow to start the admin console (now The Java Logo is blue, before it was a red logo) Don
  12. Grizzy replied to Grizzy's topic in ISY994
    No
  13. Grizzy replied to Grizzy's topic in ISY994
    I did not have Java prior to buying the ISY. After reading install procedure, I installed Java 8 and then installed the admin console and everything was working fine. I did the original install about 6 months ago. I am using win7. I have not seen anything else unusual with my computer. Don
  14. Since I installed the admin console , updated Java 6 months ago it has functioned without a problem. I have always started it from an desktop icon on windows 7 Yesterday it began acting strange, after clicking the icon there was a delay, then the JAVA logo appeared and a progress bar started running. After about 15 sec. the admin console finally came up. This happens now every time I run the admin console. I have not changed anything or done any updates to explain the possible cause. I have rebooted win7 several times with same results. Although it still works, the delay is getting very frustrating. I would appreciate any suggestions on how I can get my admin console back the way it was. Thanks Everyone Don
