ggodding
  • Posts
    7
Everything posted by ggodding
  1. Hi, I am running ISY firmware version 2.6.13. I followed your instructions and it works perfectly now. Thank you very much
  2. I have a problem with the Remotelinc 2440 buttons not sending on/off commands. If you hold button the down it will brighten/dim the linked insteon device. When I first added remote linc, everything worked OK except buttons 4 and 6 (which had the on/off problem). I then removed the device from ISY, did a factory reset on the remotelinc. On/Off then stopped working for all buttons. The all off/all on buttons work as expected for the linked devices. My setup is using 6 scenes, making a remotelinc button a controller in each scene and setting the other devices as responders. Has anyone else seen this problem?
  • Create New...
