someguy
  1. I found and posted the solution here: solution thread in this forum
  2. if you have the problem where alexa says "I found more than one device with the name (xyz). please give them unique names and run discovery again or create a group if you want to control them simultaneously" but you cannot find or delete the devices then I found a solution: use the chrome browser plug called "alexa device manager". Alexa Device Manager then once installed, go to "alexa.amazon.com" and click on the plug in and it lists ALL DEVICES, even the "ghost devices" that you normally can't delete!!!
  3. I am trying to fix my redundant voice connections from Alexa to Eisy. I have some that I get the dreaded "I found more than one device with the name (xyz). please give them unique names and run discovery again or create a group if you want to control them simultaneously" message from alexa. I have tried disabling the skill in alexa and I get the same message for the ones that had duplicates. the ones that don't have duplicates are still working but alexa replies after the request works with "hmm, (xyz) is not responding". I'm trapped. suggestions?
  4. someguy replied to dbwarner5's topic in ELK
    I get the same type of error message with Ecobee.
  5. this post forum thread says to read and review the release, but doesn't mention what to read and which release it is talking about. this forum post "BEFORE YOU START" BUT THEN CUTS OFF so it isn't helpful. is it this one? forum thread
  6. someguy started following Amazon Echo
  7. someguy replied to someguy's topic in Ecobee
    I have bought the homekithub and the ecobee plug ins for PG3x. I currently have the Ecobees connected to my Home Assistant but am happy to change this if necessary. I've tried to work through the process of connecting the three thermostats to PG3x and I can't make it work. I do not have the developer API. suggestions?
  8. someguy posted a topic in Ecobee
    I’m about 5 hours in and still cannot get my 3 ecobee thermostats connected to my Eisy. I need a tutorial that is straightforward. Can someone help please?
  9. someguy started following Alexa+ again and Tutorial
  10. someguy replied to balli's topic in Amazon Echo
    I am having major trouble with the Alexa+. I like the function of this alexa+ but it is still causing me to get the error message "I am not quite sure what when wrong with the (xxx)" even though the (xxx) went on or off just fine. I tried setting up some voice controls inside of Home Assistant and they do the same thing!!! some of you have alexa+ working, it appears by this thread. any suggestions? (I've asked Claude AI and it wasn't helpful.)
  11. someguy replied to balli's topic in Amazon Echo
    I tried enabling Alex Plus and now all of my devices get this reply from Alexa: "I can't control the device because its skill is disabled. you can find the skill and enable it again in the alexa app". I tried diabling and re-enabling the v3 universal devices skill and it still doesn't work. suggestions?
  12. someguy replied to balli's topic in Amazon Echo
    are we saying it is "safe" to upgrade to alexa plus? by safe, I mean that it no longer causes all of the problems that it used to cause as noted here: https://forum.universal-devices.com/topic/45665-don%E2%80%99t-upgrade-to-alexa/
  13. I just got confirmation from Benoit who said that the problem is the PiHole is giving such slow DNS resolution. How could I speed up my SNS resolution from the pi hole?
  14. @maxnorth : I have a pi-hole so this may be my problem. I have my eisy set as exempt from any of the filtering that the pi-hole does, so I don't know how it could be the problem though. I do have a question: if I power down my pi-hole, which is running on a raspberry pi by the way, my network doesn't work because I am using it for DNS and filtering. to truly temporarily remove my pi-hole I'd had to reset the settings in my router but I don't want to do that because I want all three: pi-hole, IPv6, and Portal!! 😁
  15. @maxnorth here is my problem: my Eisy connects to the portal with IPv6 on and won’t contect with it off. I believe you may have to reboot your Eisy after you change the IPv6 settings for it to try again If you have the same situation then let me know and we can message each other to try to figure out what else we have in common that could be the cause The solution has not yet come to fruition. After about a dozen messages back and forth with support, they’ve moved to doing an online session to try to work it out. I was told that I am the only person (yet) having this problem.
  16. I was on 6.0.3. I tried the power cycle and it didn't solve the problem. I tried upgrading package (again) and rebooting and it still hasn't come up. (when I login to my.isy.io it shows that my Eisy hasn't connected since just before I upgraded to 6.0.3) I'll open a ticket but I'd appreciate any other suggestions that anyone might have.
  17. I used "upgrade packages" inside of the Admin Console and then when it later said to "reboot", I did so. after a long time I rebooted again, but I still cannot get the portal connect. when I go to: https://eisy.local/settings/portal my browser switches that to http://eisy.local/settings/plugins so I cannot even get to the portal part of eisy. I'd appreciate any help.
