mattfisher
  1. I finally opened a ticket and got all sorted! Thank you Benoit and Michel! its all working now.
  2. iox launcher does not appear in that list to enable it
  3. This is what I get when I run it from javaws: <?xml version="1.0" encoding="utf-8"?> <jnlp spec="1.0+" codebase="https://localip:8443" href="/admin.jnlp"><information><title>IoX Admin Console</title><vendor>Universal Devices</vendor><description>IoX Admin Console</description><homepage href="https://www.universal-devices.com"/><description kind="short">IoX Admin Console</description><shortcut online="false"><desktop/><menu submenu="(5226) eisy"/></shortcut><icon href="https://localip:8443/web/isy.jpg"/><icon kind="splash" href="https://localip:8443/WEB/udlogo.jpg"/></information><security><all-permissions/></security><update check="background" policy="prompt-update"/><resources><jar href="/WEB/iox.jar" download="eager"/><jar href="/WEB/ce.jar" download="lazy"/><jar href="/WEB/bc.jar" download="lazy"/><jar href="/WEB/chart.jar" download="lazy"/><j2se version="1.8+"/></resources><application-desc main-class="com.universaldevices.client.ui.UDClientApplet"><argument>urn:udi-com:device:X_IoX_Device:1</argument><argument>uuid:00:21:b9:02:60:c4</argument><argument>https://localip:8443/desc</argument></application-desc></jnlp> exception com.sun.deploy.net.FailedDownloadException: Unable to load resource: https://1localip:8443/WEB/iox.jar at com.sun.deploy.net.DownloadEngine.actionDownload(Unknown Source) at com.sun.deploy.net.DownloadEngine.downloadResource(Unknown Source) at com.sun.deploy.cache.ResourceProviderImpl.getResource(Unknown Source) at com.sun.deploy.cache.ResourceProviderImpl.getResource(Unknown Source) at com.sun.javaws.LaunchDownload$DownloadTask.call(Unknown Source) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:750) I'm totally confused.
  4. Thank you. I will keep playing with it.
  5. if I use local ip and port 8443 and admin.jlp, I get keep this window open, but then java 2+ required. for some reason I cannot open with eisy.local, it downloads admin.jnlp on a Mac, if I click it, after I have told privacy and security that I actually want to open it, I get unable to open iox launcher I know enough to mess it all up if I am not careful
  6. I upgraded my Eisy through local Admin Console , it all seems to be running well, but I cannot run Admin Console unless it's through the portal. I have tried it on a Mac and a PC and get the same result. I also get this when I try to run desc from its local IP. I am not sure if they are related. is there an easy fix to this? This XML file does not appear to have any style information associated with it. The document tree is shown below. <root xmlns="urn:schemas-upnp-org:device-1-0"> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <URLBase>http://1localip</URLBase> <device> <deviceType>urn:udi-com:device:X_IoX_Device:1</deviceType> <friendlyName>Crosscut</friendlyName> <manufacturer>Universal Devices</manufacturer> <manufacturerURL>https://www.universal-devices.com/</manufacturerURL> <modelDescription>X_IoX_Device:1</modelDescription> <modelName>eisy</modelName> <modelNumber>5226</modelNumber> <modelVersion>6.0.0</modelVersion> <UDN>uuid:00:21:b9:02:60:c4</UDN> <UPC>uuid:00:21:b9:02:60:c4</UPC> <serviceList> <service> <serviceType>urn:udi-com:service:X_IoX_Service:1</serviceType> <serviceId>urn:udi-com:serviceId:uuid:00:21:b9:02:60:c4</serviceId> <SCPDURL>/services.wsdl</SCPDURL> <controlURL>/services</controlURL> <eventSubURL>/eventing</eventSubURL> </service> </serviceList> <interfaceIP>localip</interfaceIP> <upgradeStatus>inactive</upgradeStatus> <iotProvisioned>true</iotProvisioned> <currOSVersion>1403003</currOSVersion> <upgradeOSVersion>1403000</upgradeOSVersion> <presentationURL>/</presentationURL> </device> <isUnifiedBackend>true</isUnifiedBackend> </root>
  7. I was able to update my Policy and restore a backup of my 994 I apologize if this has been asked before, is there a way to use my existing PLM cable which appears to be a CAT 5 on one of the other Ethernet jacks? I have a CAT5 to DB9 cable coming at some point if not. Thanks
