Clif
  1. For me, I have to turn off the Secure VPN on my Norton Antivirus software so I can access my ISY994i. Hopefully this will help someone else.
  2. Thank you everyone! I finally got it working tonight! What I did for the light switch, was pit the system in the 'Start Linking' mode, then held the button on the light switch for a couple of seconds until it beeped. They system then found it and added it! As for my new motion sensor, I had to add it, by going to the Link Management, then Add a Sensor, then select Motion Sensor II. It added itself then as well. I appreciate all the people on this forum who help out!
  3. My light switch ID is 52.81.01. When I put that ID in the address field, that is when I get the message that it cannot determine the Insteon Engine. it then just goes away without adding it.
  4. The problem is not with t he new light switch. It is with the Admin Console not having the Device Type anymore!
  5. This is my version. Let me know if there is something else:
  6. I did a little more research on this. What I see, in the Admin Console, I tried once more to add the New Insteon Device. I then went through the list of supported devices, and my 2 new devices are no longer there. I have 2 other sets of these devices running for years. Why are they no longer available to add?
  7. I just received a new Insteon Dimmer Switch, Model 2477D, along wit the Insteon Motion Sensor. When trying to add them into my system, I m getting this error on both devices: Well, that number is the Dimmer Switch, but, both get the same error. I am running the OS Version 5.3.0 Any ideas on what is wrong?
  8. Yes, I did clear my Java cache before trying to log in. I don't think that is my issue.
  9. After upgrading to the new 5.2.0 build, my Insteon FanLinks do not work. I get this error: Is there any help with this issue?
  10. Thanks for all the help! I finally got in!!!
  11. I do have plenty of backups, but after I held the reset button for over 30 seconds, the red error light still blinks at me, and I cant access the device.
  12. Well, I did this procedure, and now my error light is constantly flashing. I then tried holding the reset button for 30+ seconds, but no luck. My ISY is a brick now. Is there any hope?
  13. My ISY-994I stopped letting me log in today! I can pull up the ISY Finder When I try to log in with the Admin portal, the admin/admin does not work. hen, I tried to log into the ISY Dashboard, and it failed: Help! How can I get in?
  14. I have upgraded my ISY to this latest build, with no issues, except for my z wave module. When I tell it to upgrade, I get this error:
  15. Clif replied to Clif's topic in ISY994
    Thanks for all the good advice. I will see if I can clear my java cache today to see if that helps.
