mykanderson
  1. mykanderson posted a topic in ISY994
    I have over 2 dozen devices that I would like if any of them are on it will light a button on a 6 button controller. I would also like to be able to press the button if it's on to turn everything off in the house. I have been able to achieve this with varying amounts of success. But to date I have yet to get it to work 100% of the time. These devices are a mix of Insteon and Z-Wave devices. I am running version 5.0.4. Any suggestion would be appreciated. Thanks
  2. I had this exact problem. I fixed it by making it a momentary A. I also had to change the hold time to 10 seconds to get a wireless switch to work properly in the car.
  3. If you want use tablets around the house to control things think about using Tasker also. I use this with MobiLinc and wall mount them and it works great. Sent from my SCH-I545 using Tapatalk
  4. I had to upgrade my isy system to the version 5. After doing this all was good.
  5. Does the query all have to b be at 3am or can it be another time?
  6. mykanderson posted a topic in ISY994
    I have multiple Fanlinc with 6 button combos in my house. They all work great except one. It will turn off at 3am on random days. I have yet to find out why. Anyone else have this issue?
  7. How would I get a hold of Wes?
  8. That's what I thought. I'm still having the issue of its hit and miss whether or not the entire display shows up on the thermostat in MobiLinc. I hope I don't have a bad thermostat. Sent from my SCH-I545 using Tapatalk
  9. The only way I get those options is if I add it to a scene and add a z-wave Smoke detector in the scene with it. No this does not fix the issue. I did find a work around by setting up multiple scenes with just the thermostat in it. Then I turn scenes on through program 'then' statements. Sent from my SCH-I545 using Tapatalk
  10. That is what mine looks like Sent from my SCH-I545 using Tapatalk
  11. New insteon device then I put in the address and let it auto discover. Sent from my SCH-I545 using Tapatalk
  12. That's why I'm confused. I don't have the settings you are talking about. When I add the thermostat to my program then statement I get the following options: On Off Fast On Fast Off Query (Beep Duration) (Backlight Level) If I add a scene with only the thermostat in it I get the following options: On Off Fast On Fast Off Bright Dim Beep Fade up Fade down Fade stop Query It's acting like a light. Sent from my SCH-I545 using Tapatalk
  13. Yeah, I'm as confused as you are. I'd assume that's what's supposed to be there but it's not. That's why I'm wondering if it supports the new thermostat. Sent from my SCH-I545 using Tapatalk
  14. INSTEON 2732-242 Thermostat For Heat Pump Sent from my SCH-I545 using Tapatalk
  15. This is not in a scene. I've tried putting it in a scene and I still get the same options as I stated above. I've also tried putting it in a scene with the 'cold control' and 'heat control'. Sent from my SCH-I545 using Tapatalk
