BelWave
  1. Ok, deleted the scene and recreated it, but this time made the KPL button and the switch controllers vs. responders. That seems to work. Looks like I need to start creating scenes and stop using the devices screen. Thanks, Brad
  2. Hey Michel, Thanks for the link. I think I might be generally setting up my entire ISY - MobiLinc incorrectly. Should most if not all my "Devices" be under a "Scene" vs. controlling my automation system via the Devices directly? When I use MobiLinc I never use the "Scenes" (because there is basically nothing in there) and always use the "Devices" button and scroll to whatever Device I want to control. So, I created a "Scene" and put the KPL button along with the device switch that has the load into the Scene both as "Responders". Now turning the "Scene" off & on controls the load (in this case a pump), but only physically pressing the load switch turns on the pump. Pressing the KPL button does not turn on the pump. What am I missing? Thanks! Brad
  3. So, I never used a KPL before now and must be doing something very wrong. The larger top and bottom "load" buttons work as expected, but the four smaller middle buttons don't seem to be able to control anything and only show up in the Admin Console and MobiLinc as a "Status Only Device". How do I make one of the four smaller buttons control another wall switch? Why do the four small buttons only show up as "Status Only Devices"? Thanks, Brad
