KenUD
Everything posted by KenUD
  1. i installed 5.xx and now see the siren is supported. I added it to ISY but I am confused by all the settings. Is there some description on how to set it up?
  2. My test messages stopped working. When I click on test the address the test message is received but the program alerts using the same address do not. THoughts? Everything had been working fine for years. I am using default at the server
  3. Michel, Great to hear from you. Well yesterday I found the problem with my network. I thought I would share it. At the same time I was having problems with home control network, I had a lot of static on my AM radios in the house. I wanted to see if something in the house was causing the static so I turned off each breaker in the house one by one. I found when I turned off the breaker to one of the bedrooms the static went away. It turns out a 6V power supply to my SlingBox was causing the static. I replaced the power supply and have now found my Insteon network is now working again. The power supply was putting out enough RF noise to create a serious problem with the Insteon network. It would be nice if there was a tool to see the qualilty of the Insteon network. Anyway maybe this will help others if they see a problem with their network. Take care. Ken
  4. It seems to big a bigger problem with Keypads and Controlinc. My house is falling apart. Any fix would be appreciated
  5. KenUD replied to KenUD's topic in ISY994
    Regarding the noise it is present thoughout the house. I can see the Insteon traffic by looking at the light on a Control Linc. It looks like something is ccontinually polling the network. Therefore, when you listen to AM 790 you hear a heartbeat. Any thoughts on what could be generating the Insteon traffic?
  6. KenUD posted a topic in ISY994
    I am unable to listen to the radio station 790 because of the Insteon noise in the house. I notice that ISY continuously generates traffic. Can I disable this?
  7. KenUD replied to KenUD's topic in ISY994
    Well you were right. I replaced the PLM and everything is working well. Too bad I had to waste your time because the Smarthome device wasnt working. Thanks for your outstanding and prompt help
  8. KenUD replied to KenUD's topic in ISY994
    I am running v79 on the PLM and no I dont see any links in the PLM
  9. KenUD replied to KenUD's topic in ISY994
    Well I did the event viewer. I dont see any of the traffic from any of my RemoteLincs. I just tried several other SwitchLincs and I dont see any traffic. Yet my timed events work fine and I can communicate to the devices. I did do a restore on the RL but no change.
  10. I have setup a program to tun on and off some lights. The event is triggered by a button on the remotelinc. The remotelinc button is not linked to anything. The program never sees the trigger. THoughts
  11. KenUD posted a topic in ISY994
    What are the specifications on the power supply (Voltage, Amps, Polarity)?
