lotsofdevs
Everything posted by lotsofdevs
  1. Ok. I think I finally found the root cause. It also fixed issues with backing up the configuration: - In Safari, go to Preferences -> Security -> "Website Settings" (next to "Plug-Ins") -> Select Java on the left -> on the right, you will see a list of web sites that you trust. For the IP address of your ISY device, change "Allow" to "Run in Unsafe Mode". Once you have done it, open the admin app again and it should work.
  2. still having that problem. The "Finder" window only shows some directory names, and no directory icons as well as no file names. Can't select the update file I did try witching between view modes, as well as finding the file by name and dragging dropping the file into the finder window. No luck. Almost looks like a permission issue.
