wacvmd
Everything posted by wacvmd
  1. When upgrading to 5.9.1 on eisy using UD Mobile it asks 'Force Upgrade'. Should I do it not?
  2. Install Dev. Packages is right next to Upgrade Packages in configuration setting
  3. What is the difference between upgrade packages and install Dev. Packages? When should each be used? Thanks in advance for any answers. Thanks, wac
  4. no, i added it to a scene.
  5. I have a question about Yolink Remote. None of the sub nodes show up on my program. I am currently on PG3 3.1.23, 10x 5.59 and Yolink 0.8.41. What am I doing wrong? all 4 of the nodes show up for the key presses.
  6. wacvmd posted a topic in eisy
    I was migrating from994 to eisy. It went fine initially but after after restoring isy from a back-up, I went to restore a new a 2513U PLM. It took a while a while and while during the update the eisy shut down. After opening the administrative console I tried to restart restore plm and nothing happened. I closed the eisy and went back to running Isy. I tried doing a factory restore by clicking the button 10 times and waiting 10 minutes and when I look at the administrative console my insteon system is all there with green marks at all the devices. Any advice what to do now? Thanks: Bill Crane
  7. wacvmd posted a topic in eisy
    Does it matter which USB port you plug the plm into?
  8. I have received my new eisy and I want to upgrade from an isy 994. I am running 5.0.16c firmware on the ISY and have the Z-Wave 2100 board installed. I received the Z-Wave Dongle REV E. and never installed it. I only have 8 Z-Wave devices installed. In order to upgrade to 5.3.4 would you recommend I uninstall the Z-Wave Board, install the Z-Wave + board, or not back up Z-Wave devices in the backup? With only 8 Z-Wave devices I assume it would be easier to add them after installing Z-Wave/matter Dongle. Any help would be appreciated: wacvmd
  9. wacvmd posted a topic in eisy
    Can you use a 2412UH modem with eisy?
  10. wacvmd posted a topic in ISY994
    I need help in writing a program. I have a space heater controlled by an appliancelinc and a IOlinc controlled by a high low thermometer. If I set it up a scene the heater cycles on and off frequently. I wrote the following program: If Control 'Workshop Thermometer-Sensor' is switched On Then Set 'Workshop Heater' On Wait 10 minutes Set 'Workshop Heater' Off Else - No Actions - (To add one, press 'Action') The problem is if the sensor is still on after 10 minutes the program will not restart. Any suggestions to finish this would be greatly appreciated.
  11. wacvmd replied to wacvmd's topic in ISY994
    Thank You: I was trying to add it be adding new device, when I used the linking menu no problem. Thanks again.
  12. wacvmd replied to wacvmd's topic in ISY994
    Does it mater if I use the 2412S or a new dual band plm?
  13. wacvmd posted a topic in ISY994
    I am unable to add MorningLinc to isy. I am running 2.84. I believe when I loaded 2.84, I got the agreement form and clicked accept and a message that it was not accepted. It doesn't matter if I hold the MorningLinc button down the whole time or reset as instructions for reset. I do get a message" -200000 Node not added-failed restoring device". Any suggestions? Thanks:wacvmd
  14. wacvmd posted a topic in ISY994
    Is the morning linc module supported in ISY?
  15. Hi Michel. I've cleared the java cache and still get the error with the suggested urls.
  16. Thanks Michel for your reply. I did upgrade 2.7.11 and I get the same dialog. Any suggestions?
  17. I have a problem with opening the log in Excel. I have a ISY 99i Pro using 2.7.7 and Office 97 and Windows 7 64 bit. When I open Excel and click the security macro message I get a Microsoft Visual Basic dialog box with the Runtime Error 1004 stating UDReport txt. could not be found. Check the spelling of the file name and verify that the location is correct. I doubt that the problem is with the ISY because I am able to open the log fine on another computer using excel. Any Suggestions? Thanks: wacvmd
  18. wacvmd posted a topic in ISY994
    I have 7 Switchlincs V.35. All 7 are relays. Is there a difference if its a relay or dimmer? Four of the Switchlinks are causing intermittent communication problems. Three Switchlins seem stable. Would you recommend replacing all seven? Also, how probable they would cause communication problems on other devices on the same leg but not linked to the Switchlinks? Thanks wacvmd
  19. wacvmd replied to wacvmd's topic in ISY994
    I now have no trouble disabling the motion timer with: If Control 'Mud Room Slave' is switched Fast On Then Disable Program 'Mudroom Timer' Else - No Actions - (To add one, press 'Action') I have no difficulty enabelling program with: If Control 'Mud Room Slave' is switched Off Then Enable Program 'Mudroom Timer' Else - No Actions - (To add one, press 'Action') What I have difficulty with enabling or disabling the program with using either of the two other switchlinc relays. Do I write four other programs as above? Will that work? Is there a better way. I read Darrell Peters excellent article on the wiki and also the Scope, Precedence and Execution Order which I didn't understand. I never had any programming experience and feel like I'm struggling. Any help would be appreciated.
  20. wacvmd posted a topic in ISY994
    ! have three switchlink relays controlling a light, I have set up programs to turn the light on with a motion sensor. The motion sensor turns the lights on fine and turns them off fine. However when i press fast on it does not inactivate the timer. I unfortunatelly have trouble understanding programs. Any suggestions or help would be kindly appreciated. If Control 'Mudroom Sensor' is switched On And Status 'Mud Room' is not On And Status 'Mud Room Slave' is not On And Status 'Mud Room Slave' is not On Then Set Scene 'Mud Room' On Else - No Actions - (To add one, press 'Action') If Status 'Mudroom Sensor' is Off Then Wait 2 minutes Set Scene 'Mud Room' Off Else - No Actions - (To add one, press 'Action') If Control 'Mud Room' is switched Fast On Or Control 'Mud Room Slave' is switched Fast On Or Control 'Mud Room Slave' is switched Fast On Then Disable Program 'Mudroom Timer' Else - No Actions - (To add one, press 'Action') If Control 'Mud Room' is switched Off Or Control 'Mud Room Slave' is switched Off Or Control 'Mud Room Slave' is switched Off Then Enable Program 'Mudroom Timer' Else - No Actions - (To add one, press 'Action') Thanks
  21. Michel, I also would be willing to help in a beta test for the Davis Perception. I have had them running now for 8 years. They delver data to my desktop wirlesly and are very reliable. Weather is certainly a local phenomen and ever the closest weatherbug station is 5 miles away my local conditions are quite different. If I can be of any help just ask. I feel adding support for the Davis Stations would be great for isy. Thenks: Bill Crane
  22. wacvmd posted a topic in ISY994
    I noticed a question about Network Magic and internet access with Isy. Is there a issue? Thanks
  23. will rand's program work for a kpl button and a garage door i/o
  24. I'm sorry for such a simple question. What I am trying to do is control a scene with a motion sensor. The sensor is in a work area of a barn which is controlled by a scene. It is not unusal to be out of view of the sensor for 10 minutes. If I try to control the scene by adding the motion sensor I can only set the delay to 8.5 minutes. So, I want to control it by program. Program for Barn General If Status 'BarnGeneral Motion' is ON Then Set Scene 'Barn General' On Else No Actions Program for Barn General If Control 'Barn General Motion' is switched off And Control ' Barn General Motion' is switched On Then Wait 10 minutes Set Scene 'Barn General' Off Else No Actions. The only problen is it does not work. Any help would be appreciated. Than You.
  25. wacvmd posted a topic in ISY994
    I don't know how to do this. Can I set up a single KPL buton to indicate the status of a garage door and close or open it with the same button?
