Mitch Mitchell
  1. I posted this in the main PolyGlot forum https://forum.universal-devices.com/topic/46340-elk-products-e27-alarm-engine-interface-library/ I have written a python library to talk to the Elk E27 Alarm Engine if anyone is interested in using it to create a PloyGlot interface. Mitch
  2. If anyone is interested in connecting to their E27 Alarm Engine, I’ve produced an interface library that handles the linking and encryption protocols so you can access the alarm panel API pretty simply. It handles all the low level interfacing so building a PolyGlot interface would be fairly simple. I wrote it to support my home assistant integration but it is stand alone so it can be reused to support other systems,s talking to the E27. It’s on PyPI.org here: https://pypi.org/project/elke27/ - the GitHub repository here:https://github.com/mitchmitchell/elke27.git I hope this proves useful to someone. Mitch
  3. Mitch Mitchell replied to DennisC's topic in eisy
    I’ve wired up OpenClaw to my home assistant and am looking at ways to use it with the eisy as well. I’m super impressed with how fast it’s progressed in a very short time. I’ve used codex to design and code an interface to my Elk Products E27 alarm system too. If I’d had this tech back when I was working I’d have been a hundred times more productive. I’m going to turn OpenClaw loose on my eisy logs to watch for issues and help troubleshooting. I want to introduce it to PolyGlot to see what it can do there too. My guess is that it will be able to produce custom plugs-ins on demand, it’s already authored a couple of appdaemon apps for home assistant to do some things I’ve needed for a while now but was too busy to write myself.
  4. down here too - two portal accounts.
  5. I noticed this too -- there need to be some printed instructions about the antenna colors included. If its just silk screened on the board, folks who purchase the assembled version will never see those.
  6. Something happened to mine, I reentered the credentials and it started working, no idea why that worked.
  7. I'm seeing the same issue within the last few days, the last eisy device update date in HS is 6/10/2023 10:21:44 PM an the log is full of the following message:
  8. I found several network related issues that essentially gave the eisy no chance to work right so I doubt this was specifically an eisy problem. That reminds me, I need to close my support ticket.
  9. Bob I sent you a PM with a link to the log files -- too large to attach. Please let me know if you can access them or need any other information to diagnose. Thanks! Mitch
  10. Here is a more up to date list from the homeassistant sources: https://github.com/home-assistant/core/blob/dev/homeassistant/components/ambient_station/sensor.py TYPE_24HOURRAININ = "24hourrainin" TYPE_AQI_PM25 = "aqi_pm25" TYPE_AQI_PM25_24H = "aqi_pm25_24h" TYPE_AQI_PM25_IN = "aqi_pm25_in" TYPE_AQI_PM25_IN_24H = "aqi_pm25_in_24h" TYPE_BAROMABSIN = "baromabsin" TYPE_BAROMRELIN = "baromrelin" TYPE_CO2 = "co2" TYPE_DAILYRAININ = "dailyrainin" TYPE_DEWPOINT = "dewPoint" TYPE_EVENTRAININ = "eventrainin" TYPE_FEELSLIKE = "feelsLike" TYPE_HOURLYRAININ = "hourlyrainin" TYPE_HUMIDITY = "humidity" TYPE_HUMIDITY1 = "humidity1" TYPE_HUMIDITY10 = "humidity10" TYPE_HUMIDITY2 = "humidity2" TYPE_HUMIDITY3 = "humidity3" TYPE_HUMIDITY4 = "humidity4" TYPE_HUMIDITY5 = "humidity5" TYPE_HUMIDITY6 = "humidity6" TYPE_HUMIDITY7 = "humidity7" TYPE_HUMIDITY8 = "humidity8" TYPE_HUMIDITY9 = "humidity9" TYPE_HUMIDITYIN = "humidityin" TYPE_LASTRAIN = "lastRain" TYPE_LIGHTNING_PER_DAY = "lightning_day" TYPE_LIGHTNING_PER_HOUR = "lightning_hour" TYPE_MAXDAILYGUST = "maxdailygust" TYPE_MONTHLYRAININ = "monthlyrainin" TYPE_PM25 = "pm25" TYPE_PM25_24H = "pm25_24h" TYPE_PM25_IN = "pm25_in" TYPE_PM25_IN_24H = "pm25_in_24h" TYPE_SOILHUM1 = "soilhum1" TYPE_SOILHUM10 = "soilhum10" TYPE_SOILHUM2 = "soilhum2" TYPE_SOILHUM3 = "soilhum3" TYPE_SOILHUM4 = "soilhum4" TYPE_SOILHUM5 = "soilhum5" TYPE_SOILHUM6 = "soilhum6" TYPE_SOILHUM7 = "soilhum7" TYPE_SOILHUM8 = "soilhum8" TYPE_SOILHUM9 = "soilhum9" TYPE_SOILTEMP1F = "soiltemp1f" TYPE_SOILTEMP10F = "soiltemp10f" TYPE_SOILTEMP2F = "soiltemp2f" TYPE_SOILTEMP3F = "soiltemp3f" TYPE_SOILTEMP4F = "soiltemp4f" TYPE_SOILTEMP5F = "soiltemp5f" TYPE_SOILTEMP6F = "soiltemp6f" TYPE_SOILTEMP7F = "soiltemp7f" TYPE_SOILTEMP8F = "soiltemp8f" TYPE_SOILTEMP9F = "soiltemp9f" TYPE_TEMP10F = "temp10f" TYPE_TEMP1F = "temp1f" TYPE_TEMP2F = "temp2f" TYPE_TEMP3F = "temp3f" TYPE_TEMP4F = "temp4f" TYPE_TEMP5F = "temp5f" TYPE_TEMP6F = "temp6f" TYPE_TEMP7F = "temp7f" TYPE_TEMP8F = "temp8f" TYPE_TEMP9F = "temp9f" TYPE_TEMPF = "tempf" TYPE_TEMPINF = "tempinf" TYPE_TOTALRAININ = "totalrainin" TYPE_UV = "uv" TYPE_WEEKLYRAININ = "weeklyrainin" TYPE_WINDDIR = "winddir" TYPE_WINDDIR_AVG10M = "winddir_avg10m" TYPE_WINDDIR_AVG2M = "winddir_avg2m" TYPE_WINDGUSTDIR = "windgustdir" TYPE_WINDGUSTMPH = "windgustmph" TYPE_WINDSPDMPH_AVG10M = "windspdmph_avg10m" TYPE_WINDSPDMPH_AVG2M = "windspdmph_avg2m" TYPE_WINDSPEEDMPH = "windspeedmph" TYPE_YEARLYRAININ = "yearlyrainin"
  11. I think the limit of 4 soil moisture sensors is out dated as they can support 8 I believe.
  12. Here are all the field names possible in the data: https://github.com/ambient-weather/api-docs/wiki/Device-Data-Specs This lists all the parameters that a device might send. Note: Not all devices send all the parameters. winddir - instantaneous wind direction, 0-360º windspeedmph - instantaneous wind speed, mph windgustmph - max wind speed in the last 10 minutes, mph maxdailygust - Maximum wind speed in last day, mph windgustdir - Wind direction at which the wind gust occurred, 0-360º windspdmph_avg2m - Average wind speed, 2 minute average, mph winddir_avg2m - Average wind direction, 2 minute average, mph windspdmph_avg10m - Average wind speed, 10 minute average, mph winddir_avg10m - Average wind direction, 10 minute average, 0-360º humidity - Outdoor Humidity, 0-100% humidity1...humidity10 - humidity 1...10, 0-100% humidityin - Indoor Humidity, 0-100% tempf - Outdoor Temperature, ºF temp1f...temp10f - Temperature 1...10, ºF soiltemp1f...soiltemp10f - Temperature 1...10, ºF soilhum1...soilhum10 - Temperature 1...10, % leafwetness1...leafwetness8 - Leaf Wetness 1...8, Int, % soiltens1...soiltens4 - Soil Tension 1...4, Float, cb gdd - Growing Degree Days, Int, days etos - Evapotranspiration short, Float, in/day etrs - Evapotranspiration, tall, Float, in/day tempinf - Indoor Temperature, ºF leak1...leak4 - Leak Detection 1...4, 0=OK, 1=LEAK, 2=OFFLINEle battout - Outdoor Battery - OK/Low indication, Int, 1=OK, 0=Low (Meteobridge Users 1=Low, 0=OK) battin - Indoor Battery - OK/Low indication, Int, 1=OK, 0=Low (Meteobridge Users 1=Low, 0=OK) batt1...batt10 - OK/Low indication, Int, 1=OK, 0=Low (Meteobridge Users 1=Low, 0=OK) batt_25 - PM2.5 Air Quality Sensor Battery indication, OK/Low indication, Int, 1=OK, 0=Low (Meteobridge Users 1=Low, 0=OK) batt_lightning - Lightning Detector Battery - 1=Low 0=OK batleak1...batleak4 - Leak Detector Battery - 1=Low 0=OK battsm1...battsm4 - Soil Moisture Battery - 1=OK, 0=Low batt_co2 - CO2 battery - 1=OK, 0=Low batt_cellgateway - Cellular Gateway - 1=OK, 0=Low hourlyrainin - Hourly Rain Rate, in/hr dailyrainin - Daily Rain, in 24hourrainin - 24 Hour Rain, in weeklyrainin - Weekly Rain, in monthlyrainin - Monthly Rain, in yearlyrainin - Yearly Rain, in eventrainin - Event Rain, in totalrainin - Total Rain, in (since last factory reset) baromrelin - Relative Pressure, inHg baromabsin - Absolute Pressure, inHg uv - Ultra-Violet Radiation Index, integer on all devices EXCEPT WS-8478. solarradiation - Solar Radiation, W/m^2 co2 - CO2 Meter, ppm relay1...relay10 - Relay 1...10, 0 or 1 pm25 - PM2.5 Air Quality, Float, µg/m^3 pm25_24h - PM2.5 Air Quality 24 hour average, Float, µg/m^3 pm25_in - PM2.5 Air Quality, Indoor, Float, µg/m^3 pm25_in_24h - PM2.5 Air Quality 24 hour average, Indoor, Float, µg/m^3 pm25_in_aqin - PM2.5 Air Quality Sensor indoor, AQIN sensor, Float, µg/m^3 pm25_in_24h_aqin - PM2.5 Air Quality Sensor indoor, 24 hour running average, AQIN sensor, Float, µg/m^3 pm10_in_aqin - PM10 Air Quality Sensor, Float, µg/m^3 pm10_in_24h_aqin - PM10 Air Quality Sensor, 24 hour running average, Float, µg/m^3 co2_in_aqin - Indoor CO2 from AQIN, Int, ppm co2_in_24h_aqin - Indoor CO2 from AQIN, 24 hour running average, Int, ppm pm_in_temp_aqin - Indoor PM sensor temperature, Float, ºF pm_in_humidity_aqin - Indoor PM sensor humidity, Int, % aqi_pm25_aqin - AQI derived from PM25, AQIN sensor, Int aqi_pm25_24h_aqin - AQI derived from PM25 Indoor, 24 hour running average, AQIN sensor, Int aqi_pm10_aqin - AQI derived from PM10 Indoor, AQIN sensor, Int aqi_pm10_24h_aqin - AQI derived from PM10 Indoor, 24 hour running average, AQIN sensor, Int aqi_pm25 - AQI derived from PM25, Int aqi_pm25_24h - AQI derived from PM25, 24 hour running average, Int aqi_pm25_in - AQI derived from PM25 IN, Int aqi_pm25_in_24h - AQI derived from PM25 IN, 24 hour running average, Int lightning_day - Lightning strikes per day, int lightning_hour - Lightning strikes per hour, int lightning_time - Last strike time, Datetime lightning_distance - Distance of last lightning strike, Float, miles tz - IANA Time Zone, String dateutc - Datetime, int (milliseconds from 01-01-1970, rounded down to nearest minute on server) Server calculated fields: lastRain - Last time hourlyrainin > 0, date (calculated on server) dewPoint - Dew Point, ºF (calculated on server) feelsLike - if < 50ºF => Wind Chill, if > 68ºF => Heat Index (calculated on server) date - Human Readable Date, string (converted on server from dateutc) feelsLike1...feelsLike10 - feelsLike for sensors dewPoint1...dewPoint10 - dewPoint for sensors feelsLikein - Indoor Feels Like dewPointin = Indoor dew Point
  13. we have the main kits plus 5 soil sensors, a few extra temp/hum sensors, and a ground temp sensor. I’ll get the list and see if I can tie it to the data as well.
  14. Bob if you look at the JSON returned from the API I think the sensors will be clearer -- fyi there is an indoor and outdoor PM25 sensor so there are two (with different names) but I don't see the multiple battery issues in the data returned from ambientweather.net. [ { "macAddress": "E8:DB:84:E3:CA:4A", "lastData": { "dateutc": 1685851680000, "tempinf": 76.8, "battin": 1, "humidityin": 54, "baromrelin": 29.888, "baromabsin": 29.235, "tempf": 71.8, "battout": 1, "humidity": 77, "winddir": 180, "winddir_avg10m": 99, "windspeedmph": 0, "windspdmph_avg10m": 0, "windgustmph": 1.1, "maxdailygust": 12.5, "hourlyrainin": 0, "eventrainin": 0, "dailyrainin": 0.024, "weeklyrainin": 0.067, "monthlyrainin": 0.024, "yearlyrainin": 8.858, "lightning_day": 0, "lightning_time": 1675866562000, "lightning_distance": 24.85, "batt_lightning": 0, "solarradiation": 0, "uv": 0, "soilhum1": 13, "soilhum2": 4, "soilhum3": 11, "soilhum4": 3, "soilhum5": 11, "battsm1": 1, "battsm2": 1, "battsm3": 1, "battsm4": 1, "battsm5": "1", "temp1f": 84.9, "humidity1": 48, "temp2f": 77.7, "humidity2": 40, "temp4f": 84.4, "batt1": 1, "batt2": 1, "batt3": 1, "batt4": 1, "pm25": 6, "pm25_24h": 9.8, "aqi_pm25": 25, "aqi_pm25_24h": 41, "batt_25": 0, "pm25_in": 2, "pm25_in_24h": 2.5, "aqi_pm25_in": 8, "aqi_pm25_in_24h": 10, "batt_25in": 1, "batt_co2": 1, "feelsLike": 72.3, "dewPoint": 64.19, "feelsLike1": 85.8, "dewPoint1": 63, "feelsLike2": 77, "dewPoint2": 51.4, "feelsLikein": 76.7, "dewPointin": 58.9, "lastRain": "2023-06-03T23:43:00.000Z", "lightning_hour": 0, "tz": "America/Chicago", "date": "2023-06-04T04:08:00.000Z" }, "info": { "name": "Magnolia Manor Weather Station", "coords": { "coords": { "lon": -97.052743, "lat": 33.0110917 }, "address": "1616 Shadywood Ln, Flower Mound, TX 75028, USA", "location": "Flower Mound", "elevation": 177.010009765625, "geo": { "type": "Point", "coordinates": [ -97.052743, 33.0110917 ] }
  15. Yep, I see a addnodedefs invalid entry: addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_1" NLS="sensor"> <sts> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="CLIHUM" EDITOR="I_HUMIDITY"/> <st ID="WINDDIR" EDITOR="I_DEGREES"/> <st ID="GV6" EDITOR="I_DEGREES"/> <st ID="SPEED" EDITOR="I_SPEED"/> <st ID="GV7" EDITOR="I_SPEED"/> <st ID="GUST" EDITOR="I_SPEED"/> <st ID="GV5" EDITOR="I_SPEED"/> <st ID="RAINRT" EDITOR="I_RATE"/> <st ID="GV1" EDITOR="I_RAIN"/> <st ID="GV2" EDITOR="I_RAIN"/> <st ID="GV3" EDITOR="I_RAIN"/> <st ID="GV4" EDITOR="I_RAIN"/> <st ID="DISTANC" EDITOR="I_DISTANCE"/> <st ID="GV11" EDITOR="I_BATTERY"/> <st ID="SOLRAD" EDITOR="I_RADIATION"/> <st ID="UV" EDITOR="I_UV"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="GV8" EDITOR="I_BATTERY"/> <st ID="GV9" EDITOR="I_BATTERY"/> <st ID="CLITEMP" EDITOR="I_TEMP"/> <st ID="DEWPT" EDITOR="I_TEMP"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> that sure looks like the weather info Here is the whole log: Java Web Start 11.371.2.11 Using JRE version 1.8.0_371-b11 Java HotSpot(TM) Client VM JRE expiration date: 8/18/23 12:00 AM console.user.home = C:\Users\mitch ---------------------------------------------------- 😄 clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message m: print memory usage o: trigger logging p: reload proxy configuration q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack 0-5: set trace level to <n> ---------------------------------------------------- Trace level set to 5: all ... completed.network: Cache entry not found [url: https://eisy.local:8443/admin.jnlp, version: null] network: Connecting https://eisy.local:8443/admin.jnlp with proxy=DIRECT network: Connecting socket://eisy.local:8443 with proxy=DIRECT https://eisy.local:8443/WEB/iox.jar https://eisy.local:8443/WEB/ce.jar https://eisy.local:8443/WEB/chart.jar network: Cache entry found [url: https://eisy.local:8443/WEB/iox.jar, version: null] cache: Adding MemoryCache entry: https://eisy.local:8443/WEB/iox.jar cache: Resource https://eisy.local:8443/WEB/iox.jar has future expires: Sat Jun 03 13:10:06 CDT 2023 update check skipped. cache: registerReference: com.sun.deploy.cache.MemoryCache$CachedResourceReference@26b5cd34: 1 addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_1" NLS="sensor"> <sts> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="CLIHUM" EDITOR="I_HUMIDITY"/> <st ID="WINDDIR" EDITOR="I_DEGREES"/> <st ID="GV6" EDITOR="I_DEGREES"/> <st ID="SPEED" EDITOR="I_SPEED"/> <st ID="GV7" EDITOR="I_SPEED"/> <st ID="GUST" EDITOR="I_SPEED"/> <st ID="GV5" EDITOR="I_SPEED"/> <st ID="RAINRT" EDITOR="I_RATE"/> <st ID="GV1" EDITOR="I_RAIN"/> <st ID="GV2" EDITOR="I_RAIN"/> <st ID="GV3" EDITOR="I_RAIN"/> <st ID="GV4" EDITOR="I_RAIN"/> <st ID="DISTANC" EDITOR="I_DISTANCE"/> <st ID="GV11" EDITOR="I_BATTERY"/> <st ID="SOLRAD" EDITOR="I_RADIATION"/> <st ID="UV" EDITOR="I_UV"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="GV8" EDITOR="I_BATTERY"/> <st ID="GV9" EDITOR="I_BATTERY"/> <st ID="CLITEMP" EDITOR="I_TEMP"/> <st ID="DEWPT" EDITOR="I_TEMP"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [PM25] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_2" NLS="sensor"> <sts> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="CLIHUM" EDITOR="I_HUMIDITY"/> <st ID="BARPRES" EDITOR="I_PRESSURE"/> <st ID="ATMPRES" EDITOR="I_PRESSURE"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="GV8" EDITOR="I_BATTERY"/> <st ID="CLITEMP" EDITOR="I_TEMP"/> <st ID="DEWPT" EDITOR="I_TEMP"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [PM25] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_3" NLS="sensor"> <sts> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="CLIHUM" EDITOR="I_HUMIDITY"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="CLITEMP" EDITOR="I_TEMP"/> <st ID="DEWPT" EDITOR="I_TEMP"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [BATLVL] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_4" NLS="sensor"> <sts> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="CLIHUM" EDITOR="I_HUMIDITY"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="CLITEMP" EDITOR="I_TEMP"/> <st ID="DEWPT" EDITOR="I_TEMP"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [BATLVL] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_5" NLS="sensor"> <sts> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [BATLVL] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_6" NLS="sensor"> <sts> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [BATLVL] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) Z-Wave event: control=[_25] action=[1.3] -- Extended Info -- <eventInfo> <zwave CBP="false" CONNECTED="false" RELAXDELAY="0" INTERVIEWTIMEOUT="0" SECUREINC="2" HOMEID="0" NODEID="0" RELAXDELAYDEFAULT="15"/> </eventInfo> -- Z-Wave event: control=[_25] action=[7.1] -- Extended Info -- <eventInfo> <options> <files ZMATTER="true"/> <dongle ZMATTER="false" ZWAVEOTHER="false"/> </options> </eventInfo> -- Z-Wave Backup Options: - zmatterFile= true - 500SeriesFile=false - zmatter connected=false - other connected=false network: Cache entry found [url: https://www.universal-devices.com/auto_update/updates_config, version: null] cache: Adding MemoryCache entry: https://www.universal-devices.com/auto_update/updates_config cache: Resource https://www.universal-devices.com/auto_update/updates_config has expired. network: Connecting https://www.universal-devices.com/auto_update/updates_config with proxy=DIRECT network: Connecting socket://www.universal-devices.com:443 with proxy=DIRECT network: ResponseCode for https://www.universal-devices.com/auto_update/updates_config : 304 network: Encoding for https://www.universal-devices.com/auto_update/updates_config : null network: Disconnect connection to https://www.universal-devices.com/auto_update/updates_config cache: registerReference: com.sun.deploy.cache.MemoryCache$CachedResourceReference@562a3ad4: 1 network: Cache entry found [url: https://www.universal-devices.com/auto_update/prod-updates.xml, version: null] cache: Adding MemoryCache entry: https://www.universal-devices.com/auto_update/prod-updates.xml cache: Resource https://www.universal-devices.com/auto_update/prod-updates.xml has expired. network: Connecting https://www.universal-devices.com/auto_update/prod-updates.xml with proxy=DIRECT network: ResponseCode for https://www.universal-devices.com/auto_update/prod-updates.xml : 304 network: Encoding for https://www.universal-devices.com/auto_update/prod-updates.xml : null network: Disconnect connection to https://www.universal-devices.com/auto_update/prod-updates.xml cache: registerReference: com.sun.deploy.cache.MemoryCache$CachedResourceReference@9ef316ba: 1 network: Cache entry not found [url: https://www.universal-devices.com/sales/modules/status?uuid=uuid:00:21:b9:02:64:1c, version: null] network: Connecting https://www.universal-devices.com/sales/modules/status?uuid=uuid:00:21:b9:02:64:1c with proxy=DIRECT cache: https://www.universal-devices.com/sales/modules/status?uuid=uuid:00:21:b9:02:64:1c is not cacheable. cache: MemoryCache: removed entry https://isy.universal-devices.com/launcher/udlogo.png cache: MemoryCache: removed entry https://isy.universal-devices.com/launcher/isy.jnlp
