reisender
Everything posted by reisender
  1. stusviews - I'm not sure I follow. But I deleted the original routines before migrating to V3 and then re-created them after migrating to V3. Yes, I forgot all of the devices before the migration. Benoit - I'll send you my information.
  2. I am able to operate the item I put in the routine manually by asking Alexa to turn it on or off. Agreed that if that works then it should work in a routine. But it doesn't. They worked on V2. I followed the steps to migrate to V3. And, as I previously alluded to, I have, several times, completed deleted everything in Alexa and on the ISY portal and started from scratch with the same result. My next step is going to be to go back to V2 and see if that works.
  3. I have no problem creating a routine. But whatever ISY-related item I have in a routine just doesn’t do anything. Anything else (Alexa saying something) works.
  4. Yes, I had tried that too.
  5. I had the same thing happen to me, when I upgraded from V2 to V3 my routines would no longer work. I've gone through all of the steps mentioned here and they still do not work. I even went through and deleted and re-linked everything for Echo connectivity in the ISY portal. Still doesn't work. When I ask Alexa to turn on whatever scene, program, or state variable directly it works. But when I create a routine with that same scene, program, or state variable, it doesn't work.
