Sunrise/Sunset Off w/ Time Change
Though not related to software. My Radio Shack Atomic Clock did not change on 11/01/2027 but was correct this morning
Dumbing down to Insteon hub at vacation home
I am using Windows 10 on a laptop.
I do not believe the ISY994i will be obsolete in December. It has been no longer supported for years. Mine sill works fine and the java console should work just fine even when the non java console is available for the EISY.
Ezflora Utility?
The easflora is a power line only device. Could be a new noise maker or signal sucker is now effecting the communicating to it, the device has started to fail or your PLM is starting to go bad. There are some tests you can do if you care too.
Sunset of Java Admin Console is Premature
I am on an ISY994i and the UDI support of it is tons of better and longer than most manufacturers these days. Costs money to support old devices. I am very happy with their support as long as was provided.
Mass failure: IoX-Insteon Devices
Right now X10 is showing sold out. Sign up to be notified when back in stock. The users information is on the XPF sales page if you want to look at it.
You want one that is designee for X10 or Insteon. Many others think Insteon and X10 power line commands are noise and have a capacitor on its input and outputs that absorbs the signals as noise. 120V or 220V and how many amp draw? Big and bulky. X10 XPF. 120VAC 20 amps. For 240VAC you wire two filters. One on each hot wire and neutral to the load being filtered. They do make noise absorbers for noise around X10 and Insteon but I have no data on how they worked for users.
Programs fail to activate Insteon
Working devices for even years. Can deteriorate and cause all kinds of problems. I have seen phone chargers working for years age and start making power line noise. Causing problems.
Status of Insteon Switchlink Dimmers is not updating
One of the symptoms of a failing PLM was the Link Database having no or very small entries. It does not sound like yours had the issues.
I'm going nuts! Can't find my problem!!!
I also have seen older power line only devices have X10 issues. Especially the I1 devices that take 8 messages to program one line in a link database.
Polisy stopped working and made clicking sounds
Good to see you are again working.
Ecobee Temperature precision
Now they want to mess with keeping Daylight Saving time. Every time some politicization tries to do what they think I need the short end of the stick is all get. ☹️
I would also try a replacement power supply. I have similar issues with both my ISY99i and ISY994i. Try to boot,supply shut down tried to start again in an endless cycle.New supply fixed the issue.
I'm a bit rusty...
Even when a 2477D is set to 100%. There is a short time near zero crossing. There is a time before it conducts. If the fan is inductive. That short no conduction can also lead to issues. Can't say about a I3 paddle. 2477S is also an on-off style.
Wondering if I have to do a factory reset?
I agree it maybe the power supply. Though your post seems to point more to the SD card. Maybe it got slightly corrupted at power loss or the accidental incorrect ZWave file messed something up. I have had a few over the years. One was weak and my ISY994i was fine until the power went out and then it refused to start. Just a loop of trying to boot, supply shut down and then it tried again.
Brian H
Joined
Last visited
