LeeG
  1. Illusion started following LeeG
  2. LeeG replied to Bill Morrow's topic in ISY994
    The EZIO8SA connects to the Insteon network using its own PLM. Perhaps you are seeing what would be comm to its own PLM.
  3. Last column on right (ID) of the Summary screen has the Scene number.
  4. MrWorf What are you using to remove the link and from what device? A Motion Sensor sleeps (being battery powered) so removing a link from a MS takes additional effort.
  5. MrWorf The 62 is an inactive record. The AA is valid for the SwitchLinc Relay device. SmartLabs use to have a link that showed the possible values in bits 3 & 4. The SmartLabs page has changed making it more difficult to find the document. I may have a copy locally which I will post if available.
  6. MrWorf The AA flag is a valid active record. Bits 3 & 4 are now used and can change over time.
  7. LeeG replied to MarioLanning's topic in ISY994
    Suggest restoring PLM. There is a deleted record in the small portion displayed. Likely more deleted entries exist.
  8. LeeG replied to ds7771's topic in ISY994
    Ignore the difference. Bits 3 & 4 were added some time ago to control hops. Although physically different from an E2 link record, an EA and other values can exist in bits 3 & 4 .
  9. Should be no problem turning On Zones, only one zone at time. What were you expecting to happen beside the zone showing On in Admin Console?
  10. LeeG replied to binaryman's topic in ISY994
    A State variable change in value will trigger a Program.
  11. LeeG replied to binaryman's topic in ISY994
    Is $iDay.xxxx an Integer or State variable? Integer variables do not trigger a Program.
  12. LeeG replied to hum099's topic in ISY994
    Thanks for the feedback. Great news.
  13. LeeG replied to hum099's topic in ISY994
    "When I add the lines to the then statement I select adjust scene and select the scene then select the device inside the scene is this correct." The Adjust Scene statement that specifies a Scene name as the first parameter is setting "Scene" level information. Controllers/Responders values being set are based on Scene which is not setting the correct values. The Adjust Scene is not setting the On Level values that affect when the switches are operated. That is why the devices are reacting to a 100% On Level rather the the desired 30% On Level. The On Level values being set are based on the Scene Group number rather than the Group number of the individual switch. The Group number of each switch is 01. The Group number of the Scene depends on how many Scenes have been defined, always outside Group number of the switches.
  14. The Motion Sensor is asleep because it is battery powered. Press Motion Sensor Set button for approx 4 seconds. Motion Sensor Red LED should now be blinking. Now the Motion Sensor is awake and the Options can be set for approx 4 minutes..
  15. LeeG replied to hum099's topic in ISY994
    The ISY creates the two Insteon Scenes automatically when the following definition is used. Stair Light - ISY Scene Stair Upper Switch Stair Lower Switch Stair Upper Switch is Controller, Stair Lower Switch is Responder Stair Lower Switch is Controller, Stair Upper Switch is Responder. Suggest running Event Viewer at LEVEL 3. Run the Program Then clause that sets the 30% values in the switches. Post the event trace. Operate both switches with event 30% values set. Post event viewer trace.
  16. LeeG replied to hum099's topic in ISY994
    If you want to debug your new approach please post the new Programs for evaluation.
