ChadS
Everything posted by ChadS
  1. ChadS replied to xKing's topic in Hue
    Works great now… thank you!!!
  2. ChadS replied to xKing's topic in Hue
    As requested . . . Hue_10-22-2025_70005_PM.zip
  3. ChadS replied to xKing's topic in Hue
    Running into a problem with Hue Ambiance White bulbs. I only have 2 of the White Ambiance bulbs, but as soon as the plugin gets to the first White Ambiance bulb, it stops loading any more lights. The plugin still runs, but in my case it leaves me with only have 12 of my 22 hue lights available in eisy. 2025-10-21 23:13:48.713 Thread-3 (parameter_handler) udi_interface INFO hue:_discover: Hub 192.168.51.145 22 bulbs found. Checking status and adding to ISY if necessary. 2025-10-21 23:13:48.713 Thread-3 (parameter_handler) udi_interface INFO hue:_discover: Hub 192.168.51.145 Found Extended Color Bulb: Hue Econic outdoor wall 2(c0a632e0cfe273) 2025-10-21 23:13:48.713 Thread-3 (parameter_handler) udi_interface.interface INFO interface:addNode: Adding node Hue Econic outdoor wall 2(c0a632e0cfe273) [None] 2025-10-21 23:13:48.713 Thread-3 (parameter_handler) udi_interface INFO hue:_discover: Hub 192.168.51.145 Found Extended Color Bulb: Rear downlight 1(d59400e73527b4) 2025-10-21 23:13:48.714 Thread-3 (parameter_handler) udi_interface.interface INFO interface:addNode: Adding node Rear downlight 1(d59400e73527b4) [None] 2025-10-21 23:13:48.714 Thread-3 (parameter_handler) udi_interface INFO hue:_discover: Hub 192.168.51.145 Found Extended Color Bulb: SW Pool light(a949cabae2020c) 2025-10-21 23:13:48.714 Thread-3 (parameter_handler) udi_interface.interface WARNING interface:db_getNodeDrivers: a949cabae2020c not found in database. 2025-10-21 23:13:48.714 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Exception in thread 2025-10-21 23:13:48.715 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Thread-3 (parameter_handler) 2025-10-21 23:13:48.715 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: : 2025-10-21 23:13:48.715 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2025-10-21 23:13:48.715 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 1045, in bootstrapinner 2025-10-21 23:13:48.715 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.run() 2025-10-21 23:13:48.715 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 982, in run 2025-10-21 23:13:48.716 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2025-10-21 23:13:48.716 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b90262a7_12/hue.py", line 65, in parameter_handler 2025-10-21 23:13:48.716 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.discover() 2025-10-21 23:13:48.716 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b90262a7_12/hue.py", line 188, in discover 2025-10-21 23:13:48.717 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self._discover(idx) 2025-10-21 23:13:48.717 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b90262a7_12/hue.py", line 222, in _discover 2025-10-21 23:13:48.717 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: self.poly.addNode(HueEColorLight(self.poly, self.address, address, name, light['id'], light, hub_idx, parent_dev, zb_conn)) 2025-10-21 23:13:48.717 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^ 2025-10-21 23:13:48.717 Thread-3 (parameter_handler) udi_interface ERROR udi_interface:write: ^
  4. How are devices with multiple association groups handled? For example, with the GE Z-Wave Plus switches and dimmers, Group 1 is status, Group 2 is for directly controlling other devices (I.e. virtual 3-way, 4-way, 5-way, etc circuits), and Group 3 is for directly controlling other devices by double tapping the device. Just above every other Z-Wave controller I’ve used includes an option to turn off management of Z-Wave associations.
  5. I’ve found that starting with 5.12 (I think), if the ISY is added into an existing network, it will erase any existing associations in all the nodes and create new associations to just the ISY. Needless to say nobody in the house was happy when all of a sudden none of the virtual 3 way switches using the GoControl WT00Z-1 switches would control any lights anymore nor did any of the lights controlled using the double tap feature of the GE ZWave Plus switches function either. I’m not happy that I now need to rebuild all those direct associations on every switch (30+ switches total)! The ISY never touched those associations before and only removed associations that existed to nodes not on the network. Until either this “feature” can be disabled or it’s rolled back to the way it functioned before, the ISY just isn’t an option for me now for Z-Wave and I’ve had to exclude it from my Z-Wave network. Doesn’t seem like much thought was put into this change in functionality or the impact it would have.
