leonpc
  1. I am sorry I had to step away for a bit but am back in the country now. I uploaded your latest v2.0.14 and now it is connecting to my eisy but it is not creating the nodes for them after discovering them. I notice Lore already uploaded log files. If you need another set I can upload my logs as well but if you do not need it I don't want to overload you.
  2. I have updated my roomba plugin to v2.0.9. However since the update I cannot get the roomba plugin to connect and I cannot get any logs to display.
  3. Thanks will test it and let you know... Appreciate your trouble!
  4. Thanks for the update. I have tried to update the plugin but it never really updated the roomba plugin. Finally just deleted the old one and reinstalled. that worked and now I am running 2.0.8. However when trying to connect the Roomba device I still see the following error in the log: 2025-10-09 22:01:25.678 Thread-5 (handleConfigDone) udi_interface INFO roomba-poly:getPassword: start password discovery 2025-10-09 22:01:25.679 Thread-5 (handleConfigDone) udi_interface INFO roomba-poly:getPassword: Connecting to 10.100.100.142 on port 8883 2025-10-09 22:01:26.150 Thread-5 (handleConfigDone) udi_interface ERROR roomba-poly:getPassword: Failed to connect to robot: [SSL: UNSAFE_LEGACY_RENEGOTIATION_DISABLED] unsafe legacy renegotiation disabled (_ssl.c:1016)
  5. Noticing that Matter is now in beta I also tried to connect a matter device to my eisy. The device is a tube lamp from LiFX:| Model: LFX/T10L/OP After scanning the QR from the UD Mobile app I get prompted to add the device to an app and I am shown 3 apps on my phone that does support (Google Home, Lifx App, Tuya smart) but UD Mobile is not one of the apps to pick. I get a message to restart the lamp but then only see messages the bluetooth devices without matter was found. I forced an update on the system to see if there are any updates available but it is still the same as from March 2oth: ************ IoX ************ isy-5.9.1_18 Name : isy Version : 5.9.1_18 Installed on : Thu Mar 20 19:21:25 2025 MST Origin : misc/isy I am running UD mobile on Android
  6. Hi Bumbershoot Thanks for pointing out this post. I have tried some of the solutions mentioned in here. I get error message when running these commands. As it is I already had the dev packages installed but tried to install them again just in case those were not updated when upgrading from 5.8.3 to 5.8.4. It goes very quick. I have restarted EISY after that but still no luck.
  7. I was having issues connecting to my Bond devices. While troubleshooting I noticed that Eisy updated to v5.8.4 back in June. I followed the instructions and upgrade to v5.8.4 and now all my bond devices are active and working but I cannot connect to any of the LIFX and Roomba devices. In the PG3 dashboard I see both node servers show as disconnected. Looking at the Lifx log I see the following: 2024-10-20 12:43:39.342 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.3.14 Starting... 2024-10-20 12:43:39.343 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2024-10-20 12:43:39.343 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b90266f4_2/lifx-poly.py", line 10, in <module> 2024-10-20 12:43:39.343 MainThread udi_interface ERROR udi_interface:write: import lifxlan 2024-10-20 12:43:39.343 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError 2024-10-20 12:43:39.343 MainThread udi_interface ERROR udi_interface:write: : 2024-10-20 12:43:39.343 MainThread udi_interface ERROR udi_interface:write: No module named 'lifxlan' Looking at the Roomba log I see a slightly different message: 2024-10-20 12:46:20.198 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.3.14 Starting... 2024-10-20 12:46:20.218 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2024-10-20 12:46:20.218 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b90266f4_5/roomba-poly.py", line 19, in <module> 2024-10-20 12:46:20.219 MainThread udi_interface ERROR udi_interface:write: from roomba import Roomba 2024-10-20 12:46:20.219 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b90266f4_5/roomba.py", line 42, in <module> 2024-10-20 12:46:20.219 MainThread udi_interface ERROR udi_interface:write: from collections import Mapping 2024-10-20 12:46:20.220 MainThread udi_interface ERROR udi_interface:write: ImportError 2024-10-20 12:46:20.220 MainThread udi_interface ERROR udi_interface:write: : 2024-10-20 12:46:20.220 MainThread udi_interface ERROR udi_interface:write: cannot import name 'Mapping' from 'collections' (/usr/local/lib/python3.11/collections/__init__.py) In both cases it is just looping through these messages. I have restarted the eisy and power cycled it. I have reinstalled the plugins for both Lifx and Roomba After the upgrade to v5.8.4, I installed the Developer Packages. still no luck to get these to work. Any ideas would be appreciated
  8. I think I have found the answers to my questions is this excellent post of @Bumbershoot
  9. @gviliunas I have read the various posts from you surrounding the LIFX firmware v3.90. I am a little confused and would like some clarification. In your post it looks like you are saying you should use the serial number of the bulb when setting up the devlist. But elsewhere you say that you should use the MAC address of the bulb. Since you used the documented serial number in the devlist which stopped working with the change that started with the firmware update, it seems like you should be using the MAC address. Am I correct? @xKing when you set up the devlist, what are you looking for? the serial number of the bulb or the MAC address of the bulb? Thanks Leon
  10. Thanks for all the good input... I started down the road to figure this all out and then got pulled into a project at work that has consumed all my time. I have not looked at anything HA related and my wife has been creating a backlog of things to be fixed. Starting today I have some time available and I will go back and setup the devlist.txt. I already assign ip addresses to the lights so that the ip addresses do not change. Thank you @gviliunas and @bigDvette.
  11. @Michel Kohanim When i restart the node server I see the following error: 2024-02-01 16:49:05,629 MQTT udi_interface.interface INFO interface:_message: Profile installation finished 2024-02-01 16:49:10,719 Thread-4 udi_interface ERROR lifx-poly:_discovery_process: discovery Error: WorkflowException: Did not receive [<class 'lifxlan.msgtypes.StateVersion'>] from d0:73:d5:39:e8:51 (Name: None) in response to <class 'lifxlan.msgtypes.GetVersion'> Once I get this error none of the LIFX bulbs are discovered and none of the controls work. I have added a devlist.yaml and when I do that it looks like the bulbs are discovered until the last few lines when I get a a series of messages that manual discovery failed. I have now removed the devlist.yaml I am opening a ticket... thanks
  12. Have you found any solution to this. Lifx was working for me until about a week ago... and then it stopped. I have the same errors in my logs and was considering using the devlist.yml but if that does not work... Where t now?
  13. What happens if you only have the eisy? How do i setup the Python dev environment on eisy. Obviously I am missing it in the docs. Thanks
  14. Yes the devices it is complaining about are 4 light bulbs and the switch is off. I can grab a trace with the switch on if it will help.
  15. I have updated IoX to the latest and then restarted the eisy. After that I updated the Kasa module to v3.1.4.. I now am getting an error during startup that discovery is not working. Eventhough the devices are displayed in the ac it is not working. I have tried to update across the board twice and am still seeing the same issue. Kasa_12-21-2023_34154_PM.zip
