Eclypse
  1. I just switched over to the EISY and i may have screwed up not sure it's been so long since I connected to Alexa or google. Not sure if its something I did or didn't do. I have two accounts on the portal one is for the old home we had years ago and it has no devices. The other portal login shows my eisy when I try to add spoken voice commands to alexa I get this error This user profile @gmail.com cannot manage this ISY. If Alexa is linked with another user profile in this account, then you can ask Alexa "Discover my devices" to reflect the changes you made in Alexa. If on the other hand Alexa is linked with this user profile and you want it to control this ISY, then click on My Profile to change the preferred ISY to this ISY. I am concerned that I tied the wrong email when I set it up is there any way to tell? or did I miss something in the setup? The discover devices just found a tv.
  2. Sorry It took so long to get back to dbuss. Yea trying that gives me a not found error in the admin console. I think I will reach out to support and see if they can't point me in the right direction.
  3. That was a excellent thought, I disabled the Windows firewall and unfortunately that didn't help. I even tried uninstalling and reinstalling Java thinking the security update may have done something to the Java settings. This is maddening, however I did find a backup I did. So Maybe if I have to load it I will.
  4. I did notice a change when reloaded the JLP file from the website and it also explains why the text got large enough for me to read without glasses, but yes I have tried that one. Thanks dbuss
  5. Hi all, I am hoping can point out what I haven't thought of yet. I know its something stupid. I am unable to find the ISY on my network via the admin console / Java app. I can reach the Ajax webpage via IP and control devices, the unit works with Agave, I can reach the portal and the portal can see me. I thought it might be Java security setting so I did all the usual to Java, cleared temp files and added ISY URL to security settings. This is a new home for us and I haven’t backed up my ISY settings so I don't want to reset the ISY (yea I know). ISY and PC are plugged into the same switch. I am running Java 8 and update 181 Oh and thanks in advance!
  6. This topic has been touched on many times and there are some great examples posted. However I can't make my bedroom light only come on 50% at night. I have tried multiple variations all without success. Can somebody Please take a look at the program and tell me what I did wrong? Thanks in advance! Night Dim scene - [ID 0007][Parent 0001] If From Sunset + 2 hours and 30 minutes To 6:00:00AM (next day) Then In Scene 'Master Bedroom' Set 'MB Light' 6.5 Sec (Ramp Rate) In Scene 'Master Bedroom' Set 'MB Light' 50% (On Level) In Scene 'Master Bedroom' Set 'MB light Bath Side' 50% (On Level) Else In Scene 'Master Bedroom' Set 'MB Light' 100% (On Level)
  7. As usual, after I made the post, I figured it out.
  8. I have followed the step by step. The portal is enabled the Alexa app shows the ISY skill is enabled, however when i attempt to add the Echo to the user account thru the portal I continue to get the same skills error message. I have cleared and waited 60 seconds, 5 minutes, rebooted the ISY, Logged and re-logged into both apps a few times and I continue to get the same error. Any one have any thoughts? The ISY skill is not linked to your portal user profile. Please go to your echo app, enable the ISY skill, and link the skill with this user profile.
  9. There is no fan speed control with current setup. I looked at the keypadlincs it just seems like overkill. There was one post somewhere that mentioned double taps to a switchlinc, but I can't find it. I am also not sure how well something like that can work.
  10. I have a fan and lamp both controlled from one wall switch using X10 that I would like to switch to insteon. These switches are in my kids rooms. The Leviton two scene switches send on and off command to a x10 outlet or inline x10 module. I have been slowly migrating my x10 stuff to insteon but some devices are more difficult to migrate. I have looked at the Fanlinc and the reviews on how it controls the motor make me reluctant to purchase. I had hoped the remotelinc might be a solution but I never liked the idea of having to change batteries. any thoughts or suggestions are appreciated and welcome.
  11. Can anyone tell me what the attached JPG event viewer entries mean. Thanks
  12. Eclypse replied to Eclypse's topic in ISY994
    Well after poking around I decided to try Nsteins App ISY Ajax and to be honest its an improvement over what I had so I am going to convert to that. It does give me control over my x10 devices. Although I would love to know what I did. Michel..... I am sure your got better things to do thanks for trying.
  13. Eclypse replied to Eclypse's topic in ISY994
    This is how it looked before
  14. Eclypse replied to Eclypse's topic in ISY994
    Michel thanks for the reply. Its actually a 404 error. User ID and Pass work..
  15. Eclypse posted a topic in ISY994
    Many months ago someone posted a neat web interface for the isy which they shared. I have used that interface for my ISY for many months with no issues. While I am knowledgeable enough to edit some HTML and make it work for me I can't seem to fix what’s wrong with it now. I am hoping one of you guys might steer me to a solution. When I log on to my ISY's IP I get this The files that I load on the webserver are located here: http://www.gigasize.com/get.php?d=2j2ygxo49zf I have compared all my HTML files that I edited as I was getting to the final look and can't find anything different. I also loaded the original authors creation (I think) and still can't get it to work. I can't figure out what’s gone wrong. This interface is not perfect but it works on my android and shows all my X-10 devices. Which is something some of the other solutions out there don’t do? Any suggestions are greatly appreciated.
