alambertus
Everything posted by alambertus
  1. alambertus replied to alambertus's topic in Blink
    Unfortunately, I suffered a power outage, and am also getting a 'login failed' message.
  2. alambertus replied to alambertus's topic in Blink
    Okay, I was able to install the plug-in, and it works! The steps I took were as follows: 1) Install the plug-in. Pop-up appears requiring username and password. Entered username and password in the fields, Then had to restart the plug-in.. 2) When the plug-in restarted, it needed a 2FA token that Blink texted to me. I entered it in the correct spot in the configuration. 3) Notifications popped up telling me the networks that were detected. I followed the steps, creating the custom configuration parameters, and enabling them. 4) I waited, but I had to restart the plug-in (and enter the 2FA token that was sent again). 5) The plug-in pulled in all of the Blink cameras in the system, and they were able to be controlled as before! Nice work!
  3. alambertus replied to alambertus's topic in Blink
    I know, and we appreciate you giving your free time to work on it!
  4. alambertus replied to alambertus's topic in Blink
    I am not an expert by any means, but let me know if I can help with testing or anything.
  5. alambertus replied to alambertus's topic in Blink
    @Panda88, I understand that it takes time to crawl through these, and I've heard that Blink is particularly annoying, as they don't have an official API. We really appreciate the work you've done on it. I attached the debug log, with my credentials redacted. If there is anything else that I can provide to help with the debugging, let me know! Adam Blink debug.log
  6. alambertus posted a topic in Blink
    The Blink plugin was working.....then my Polisy got corrupted during the upgrade to version 14. Now I can't get my Blink system to successfully login. I am assuming it has something to do with the 2FA...... I've tried using my MFA app code, and I've even tried logging on on the web to grab the authorization code that gets sent via text message, and also tried going into the app --> Account and Privacy --> Manage Mobile Devices to swipe a code from there. Is there any chance this plugin is ever going to work? @Panda88 , is this plugin still alive? 2025-11-01 09:55:25.606 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {'LOGIN': 'Login Failed - Try again'}2025-11-01 09:55:25.607 Command udi_interface.custom DEBUG custom:load: CUSTOM: -- checking LOGIN / Login Failed - Try again
  7. I have a really weird thing occurring with my Ecobee PG3x node server. Whenever my Ecobee changes the comfort setting (Home to Away, Home to Sleep, etc), one light in my house (kitchen three-way, Insteon) turns off. It doesn't matter if I send the command via the Ecobee app, via a schedule, or through the Ecobee nodes, the light always turns off. I do not have any programs or scenes that tie my Ecobee nodes to anything. For the life of me, I can't figure out why my kitchen lights always shuts off any time the comfort setting changes! Does anyone have any ideas? Adam
  8. Chiming in......can log into my local console, can't connect with the UD Mobile app (ERROR: Could not get credentials (11):("code":503,"error":"server_error","error_description":"server_error") oAuth Error Cannot connect to ISY portal. Http error 500. When I connect locally to the admin console, i see Portal Integration - UDI Offline.
  9. I have the IP address reserved, and it shows up properly in my Address Reservation table, and shows up in the Connected Devices. Screenshot shows that ISY Finder sees nothing. I've used both the https://polisy:8443/desc (and 8080/desc) and the IP:port/desc methods, but ISY Finder always shows "Not Found". I can log in to my Polyglot V3 through my web browser, and it shows the same IP address as in my router settings. However, none of my Polyglot nodes are being updated (as per UD Mobile). UD Mobile shows it at the reserved address, and shows 8080 for the port. When I try to connect locally through UD Mobile, it shows the following error: java.lang.Error: Error (IO Exception) java.net.SocketException: Connection reset
  10. Yup, tried that too. Only thing I've got left on my idea sheet is full reset (including network settings)
  11. Everything was working normally. I noticed the update to 5.4.4 was available, so I clicked to automatically update in the Admin Console. Since then, ISY Finder can't locate it automatically, nor if I go to https://polisy:8443/desc or even https://IP ADDRESS:8443/desc Everything still works correctly (except for any attempts to connect to it), and it works via the UD Mobile app for Android through the ISY portal settings. Please help!
  12. @Javi, Yup, that took care of it. Looks great!
  13. @javi, I downloaded the update, cleared the cache and storage, and am still getting "Error: Email and/or password is not valid."
  14. I downloaded the app, and tried to log in. I also have a password that is 16 random letters, numbers, and symbols. The password works on the ISY Portal, but when I try to log on to UD Mobile, I get "Error: Email and/or password is not valid."
  15. It works for my Ecobee3, without any additional setup. In fact, it added all of my sensors so I can ask what temperature it is in each room......
