heardc
Everything posted by heardc
  1. heardc posted a topic in eisy
    First, the eISY is an excellent upgrade from the ISY, not for the faint of heart, but worth every effort. I have about 100 devices of all Zwave generations. They all started out working very well. Some had to be excluded and included, no big deal. However I am finding that over time a device will stop responding to queries and status ON/OFF commands. The fix is to turn Validation Off and Compatibility On. Immediately after that change, a device will start responding again. Anybody else seeing this and know why it happens? Second, I really like the MQTT capability in PG3. I am using it as a bridge between Home Assistant and eISY. This one feature has opened up infinite possibilities by allowing the use of HA when needed, for example using Reolink Doorbells or Frigate NVR events. The documentation for MQTT hides everything you need to know to get things working though. Reverse engineering is needed to figure out the text formatting required for sensors to show up as nodes in eISY. Would be way better if that info could simply be shown. example sensor text string that was reverse engineered from AM302 sensor research: { "ep1": { "Temperature": 69.8, "Humidity": 56.3 }, "TempUnit": "F" }
  2. I have an mqtt topic in frigate set as a switch: - id: "drivedet" name: "driveway detect" type: "switch" sensor_id: "detect" status_topic: "frigate/driveway/detect/state" cmd_topic: "frigate/driveway/detect/set" I can set this to True or False in the admin panel or a program, but when I query the node, the message gets deleted in MQTT Explorer and the setting in Frigate goes to False. For now this is the reason why I am not going to use or rely on the MQTT Node Server and use python network resources instead. Can't risk the eISY running a query and wiping out all the topics. Is there a way to not allow this to happen?
  3. Pushover is totally worth it. Keeps your notifications separate and is much more reliable.
  4. Latest version of 5.9.1 behaves way different and largely far better than previous versions. 12 hours in after launching migration, I am up and running with eISY. Nice to have a FreeBSD box to work with. Half of my battery devices required exclusion and inclusion. Rest commands to configuration parameters do not work due to https protocol, which is sad but not vital. Zwave response is shockingly fast. Time will tell on stability.
  5. heardc replied to heardc's topic in eisy
    Found the problem. An "Access Control Alarm [S0]" got added to the node list and was buried. This Node allows for programs to use status that includes manual lock, keypad lock etc.
  6. heardc posted a topic in eisy
    I installed three of these deadbolts 10 years ago, they have been working with the ISY 994 nicely. Just installed the EISY today. The Yale deadbolts are showing up as status only. No settings for the difference between manual lock, key lock, or keypad. Anybody else see this? I am hoping that an exclude, and include will solve it. Sent from my iPhone using Tapatalk
  7. Has anyone tried using Aeotec or similar USB Zwave stick in the eISY instead of the $120 combination dongle that I purchased? I’m starting to wonder if that thing is totally incompatible with my 10 yr old zwave network comprised of mostly 300 and 500 series devices.
  8. Update on this: I heard back from Tech Support to Update Packages, did that, firmware stayed at 5.9.1. Got much further in the process, but still all wired devices disabled and non functional. Battery devices stuck in a never ending Network Heal / Finding neighbours loop that I had to kill after 6 hours of no progress. Why try to find neighbors of battery devices if they are likely asleep? Each device has 4minutes allocated to find neighbors, I tried waking them up after seeing status to that effect, still didn't help.
  9. I did not ask and will do that.
  10. No offer has been made by UD to send the unit back. I’m stuck with it and am praying that UD figures it out with new firmware. Not being able to roll back to a previous firmware is pretty bad. Peplink routers are spectacular for this single reason. In the meantime I will be turning a Lenovo Tiny PC into a Home Assistant box for at least an NVR and at most, a replacement to my dead eISY.
  11. After 10 years with the ISY994, I decided to get the eISY and give it a shot. Had multiple hardwired computers spread out on the table, printed my migration instructions, fully rested with 8 hours available to do the work. Assumed that 15 battery devices would require Syncing, and was hopeful that the new unit would recognize the other 100 wired devices. I made one critical mistake which bricked my eISY. I clicked the “upgrade packages” button not knowing that this was actually a big firmware update from the stable 5.8.4 to 5.9.1. Apparently 5.9.1 doesn’t allow for migration with zwave for some reason and if I was made aware that upgrade packages meant a massive re-wiring of the firmware, I would have declined the offer. After Restoring IoX from the ISY994 backup, every zwave device is disabled with a red circle/slash. After enabling a device, syncing fails for all of them. The eISY is back in the box and I have submitted a ticket. Apparently I am not alone. Do not “upgrade packages” before doing a zwave migration!
  12. Update is now available on the App Store and appears to work!
  13. Hey I love my 10 year old isy994 too but am getting tired of having to reboot it every 3 weeks, fighting with Java and windows admin access and UD Mobile synchronization unpredictability. Does any of this stuff get better with eISY? If not, I may take the massive leap to Home Assistant.
  14. I experience the same thing last night as well. Rebooted, resynced, no change. Submitted a ticket and got a reply saying that a new update to UD Mobile is about to show up on the App Store.
  15. With Adding Secure Devices set to Yes.
  16. Can’t get the device to include successfully. Sent from my iPhone using Tapatalk
  17. Can’t get the device to include successfully. Sent from my iPhone using Tapatalk
  18. Dear Old Surfer Dude, I have been unable to add/include the Zooz ZSE18 motion sensor to my ISY994, running 5.3.4. Do you know of any settings or tricks required to get this to work?
  19. Having trouble adding/including a Zooz ZSE18 Motion Sensor. Getting security errors. Running firmware 5.3.4, Zwave 21100. Has anyone out there done this with success? Sat 01/29/2022 03:44:39 PM : Listening for Z-Wave devices to add to the network Sat 01/29/2022 03:44:58 PM : Z-Wave device detected, retrieving info 2 Sat 01/29/2022 03:44:58 PM : Z-Wave device detected, retrieving info 3 Sat 01/29/2022 03:44:58 PM : Z-Wave device detected, retrieving info 5 Sat 01/29/2022 03:44:58 PM : Adding Z-Wave devices stopped Sat 01/29/2022 03:44:59 PM : Z-Wave device detected, retrieving info 6 Sat 01/29/2022 03:44:59 PM : Exchanging data with secure Z-Wave device 124 of type 4.7.1 Sat 01/29/2022 03:44:59 PM : Adding secure Z-Wave device Sat 01/29/2022 03:45:09 PM : [ZWAVE-ADDSECURE] Error 3 Sat 01/29/2022 03:45:09 PM : Failed to include secure Z-Wave device 124 of type 4.7.1
  20. Just curious if there are fundamental improvements over the series 300 chipset vs the series 500 chipset. If money is no object (for discussion), wouldn't be better to buy the new ISY994i ZW+ running the latest 5.0.x firmware? This way you have a series 500 chipset in the hub and mostly series 500 chips out on the network (for my current setup). Will I see a performance improvement or better compatibility etc?
  21. Great question. Did you buy another ?
