Larry C
  1. I Figured it out, I had somehow not deleted some links and that was messing up what should have been simple. Once I deleted everything and re discovered the KPL's everything worked like it should. Thank you Gary and stusviews for the input.
  2. I had already tired that, but just to be sure I deleted everything in the scene and started from scratch and tried again just to be sure. Both times when I pressed the Kitchen Button A nothing happened but when I pressed the living room button A All the lights turned on then they turned off and kept cycling on and off until I disabled the scene. the strange thing is more lights were turning on than I had set in the scene. I'm new to this and have been playing around with different programs and scenes to figure out how to do different things and I think I might have old remnants that are messing me up. Is there a way to check or clear the slate and start from scratch? Thank you in advance for any help you are able to offer. Yes, I created a scene with 2 KPL's (My plan is to make it 5 KPL's sometime down the road) where All Button A's turn on or off a scene "whatever lights are in that scene"
  3. I created a scene with (Light 1) (Light 2) (light 3) (Living Room Button A) and (Kitchen Button A). When I push (Living Room Button A) Light's 1,2 and 3 Come on. When I push (Living Room Button A) again nothing happens. But when I Push (Kitchen Button A) Lights 1,2 and 3 Turn off. What I would like to happen is to be able to push either button A to turn the lights on or off. I probably should have mentioned that in my first post.
  4. I've been looking in the forum for the last few day's and have not been able to find a solution to my problem, Hopefully someone can steer me in the right direction. I have 2 KPL's (I plan to install a few more around the house) I would like to have all the Button A's act as a 3 way switch and turn on a Scene when pressed and turn the Scene off when pressed again and the same with Button's B, C D, ect.... What is the correct way to accomplish this?
  5. Thanks, downloaded the app last night and it worked flawlessly. I'll be purchasing the full version. The app has a very good solid base can't wait to see the new features you were talking about. Do you have any plans to work on the GUI and make it more Apple Like (AKA Fancy). Thanks for taking up the task,
  6. What does $2.50 - $99 mean, What is the breakdown that is a pretty wide spectrum.
  7. Could you go into more detail about the 4 sub accounts, I have dots in other rooms and was just having a conversation the other day on how great that would be to just be able to say Alexa turn on the light and not have to specify the room.
  8. Thank you Benoit for your response I think I understand now, you use the connected home for simple things like lights and a skill for more advanced things. I guess I was hoping with the power of the ISY the connected home would be able to do everything by just asking Alexa without having to ask Alexa to ask Izzy. thank you for clarifying that.
  9. Michel/UDI I just purchased my ISY a few weeks ago and I am happy to say that everything my research told me about it was true and more, and that the only limitation to it's functionally is my imagination. I have just spent the last few days reading and getting caught up on everything I could find about Echo integration with the ISY. I am anxious to get the new Skill as soon as it is certified. Please correct me if I am wrong but from what I have read so far it seems like direct access like the (Hue, Wemo, Instion Hub) would be much Superior to a Skill. Is there any talk about this becoming a reality in the near future. and if so what are the chances.
