fman47
  1. fman47 replied to fman47's topic in ISY994
    does it work with the Mobilince App
  2. fman47 replied to fman47's topic in ISY994
    have not purchased anything. system just crashed last night. Hope the EISY is simple transition. where can I learn more about it
  3. fman47 replied to fman47's topic in ISY994
    not familiar eisy
  4. fman47 posted a topic in ISY994
    I need to replace the ISY 994 with the Polisy system. My devices are insteon switches and outlet. The questions I have are as follows: 1) once I install Polisy, can i restore the ISY Backup to the Polisy? 2) will my Mobilinc app work with Polisy? 3) will the Insteon device works?
  5. Thanks - I assume the Micro on/off would be wired in to what they refer as latching mode
  6. fman47 replied to Kentinada's topic in ISY994
    I have the same problem, what did you end up doing
  7. I have encountered a wall switch without a common wire. It looks like the line side cable was brought to the receptacle box in ceiling with load line going down to the switch for turning light on & Off. Without re-wiring, I am looking for a smart switch that works without a common wire or controller i put in the ceiling box. I have the ISY994i controller with Zwave. The smart device has to work with that
