Hi,
I just had a problem adding a new 2420M and kept getting the following errors:
[-200000]Node not added-failed removing links[11 9F 17 1]
[-200000]Failed writing the highwater mark[n/a]
I just added a 2466SW ToggleLinc with no issues, so at first I thought I had a bad 2420M, but resolved the problem by disabling the climate module then adding the 2420M. Once the device was added I could enable the climate module and add the sensor to new scenes and programs with no further issues. Any ideas what is going wrong?
Thanks,
Jim
Failed device add:
2009/06/29 15:43:04 : ---- Initializing the linked devices ----
2009/06/29 15:43:04 : ---- All Linked Devices are now initialized ----
2009/06/29 15:43:04 : ---- Add remaining devices ----
2009/06/29 15:43:04 : [ 11 9F 17 1] Removing all links
2009/06/29 15:43:04 : [11 9F 17 1] Querying engine version
2009/06/29 15:43:04 : [iNST-ACK ] 02 62 11.9F.17 0F 0D 00 06 (00)
2009/06/29 15:43:04 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 0D 01 (01)
2009/06/29 15:43:04 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 15:43:04 : [11 9F 17 1] Retrieved engine version is i2
2009/06/29 15:43:04 : [11 9F 17 1] Calibrating engine version ensuring support for i2
2009/06/29 15:43:04 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:05 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 15:43:05 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 15:43:05 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 15:43:05 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 15:43:05 : [] Using engine version i2
2009/06/29 15:43:05 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:07 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 15:43:07 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 15:43:07 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 15:43:07 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 15:43:07 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:07 : CLI-WBug: Connecting to http://datafeed.weatherbug.com/GetXml.a ... UnitType=0
2009/06/29 15:43:07 : CLI-WBug: Successfully Processed WBug Response
2009/06/29 15:43:08 : [MOD 2 2 1] 000F2AD0 Weather/Temperature = 99.4 °F
2009/06/29 15:43:08 : [MOD 2 2 5] FFFFDCD8 Weather/Temperature Rate = -0.9 °F
2009/06/29 15:43:08 : [MOD 2 2 7] 00000000 Weather/Humidity Rate = 0
2009/06/29 15:43:08 : [MOD 2 2 10] 00099CF0 Weather/Dew Point = 63 °F
2009/06/29 15:43:08 : [MOD 2 2 11] 00004E20 Weather/Wind Speed = 2 mph
2009/06/29 15:43:08 : [MOD 2 2 13] 0000C350 Weather/Wind Direction = E
2009/06/29 15:43:08 : [MOD 2 2 14] 0000C350 Weather/Wind Average Directi = E
2009/06/29 15:43:08 : [MOD 2 2 18] 0000EE48 Weather/Light = 6.1
2009/06/29 15:43:08 : [MOD 2 2 19] FFF82448 Weather/Light Rate = -51.5
2009/06/29 15:43:08 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 15:43:08 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 15:43:08 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 15:43:08 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 15:43:08 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F FF 08 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:17 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F FF 08 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:26 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F FF 08 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:30 : [ 11 9F 17 1] ** Not added ** Remove Device Links failed
2009/06/29 15:43:30 : ---- All Remaining Device Added ----
Successful device add:
2009/06/29 16:40:58 : ---- Initializing the linked devices ----
2009/06/29 16:40:58 : ---- All Linked Devices are now initialized ----
2009/06/29 16:40:58 : ---- Add remaining devices ----
2009/06/29 16:40:58 : [ 11 9F 17 1] Removing all links
2009/06/29 16:40:58 : [11 9F 17 1] Querying engine version
2009/06/29 16:40:58 : [iNST-ACK ] 02 62 11.9F.17 0F 0D 00 06 (00)
2009/06/29 16:40:58 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 0D 01 (01)
2009/06/29 16:40:58 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:40:58 : [11 9F 17 1] Retrieved engine version is i2
2009/06/29 16:40:58 : [11 9F 17 1] Calibrating engine version ensuring support for i2
2009/06/29 16:40:58 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:40:59 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:40:59 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:40:59 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:40:59 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:40:59 : [] Using engine version i2
2009/06/29 16:40:59 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:00 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:00 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:00 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:00 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:00 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:01 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:01 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:01 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:01 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:01 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F FF 08 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:02 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:02 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:02 : [ 11 9F 17 1] Adding device to ISY t=10.01.0000
2009/06/29 16:41:02 : [11.9F.17-Sensor] Start : Adding device to ISY
2009/06/29 16:41:02 : [11.9F.17-Sensor] Finish : Adding device to ISY was Successful
2009/06/29 16:41:02 : [11 9F 17 1] Querying engine version
2009/06/29 16:41:02 : [iNST-ACK ] 02 62 11.9F.17 0F 0D 00 06 (00)
2009/06/29 16:41:03 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 0D 01 (01)
2009/06/29 16:41:03 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:03 : [11 9F 17 1] Retrieved engine version is i2
2009/06/29 16:41:03 : [11 9F 17 1] Calibrating engine version ensuring support for i2
2009/06/29 16:41:03 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:03 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:04 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:04 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:04 : [11.9F.17-Sensor] Making PLM a Responder to group 1
2009/06/29 16:41:04 : [MNG-LNK-RSP ] 02 6F 41 A2 01 11 9F 17 10 01 00 06
2009/06/29 16:41:04 : [11.9F.17-Sensor] Using engine version i2
2009/06/29 16:41:04 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 12 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:04 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
2009/06/29 16:41:04 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:05 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:05 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:05 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:05 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:05 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F FF 08 E2 01 0E D9 8A 00 00 01 00 06 (00)
2009/06/29 16:41:06 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:06 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:06 : [11.9F.17-Sensor] Making PLM a Responder to group 2
2009/06/29 16:41:06 : [MNG-LNK-RSP ] 02 6F 41 A2 02 11 9F 17 10 01 00 06
2009/06/29 16:41:06 : [11.9F.17-Sensor] Using engine version i2
2009/06/29 16:41:06 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:08 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:08 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:08 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F F7 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:08 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:08 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F F7 08 E2 02 0E D9 8A 00 00 01 00 06 (00)
2009/06/29 16:41:09 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:09 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:09 : [11.9F.17-Sensor] Making PLM a Responder to group 3
2009/06/29 16:41:09 : [MNG-LNK-RSP ] 02 6F 41 A2 03 11 9F 17 10 01 00 06
2009/06/29 16:41:09 : [11.9F.17-Sensor] Using engine version i2
2009/06/29 16:41:09 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:10 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:11 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:11 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F EF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:11 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:11 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F EF 08 E2 03 0E D9 8A 00 00 01 00 06 (00)
2009/06/29 16:41:11 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:12 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:12 : [11.9F.17-Dusk/Dawn] Start : Adding device to ISY
2009/06/29 16:41:12 : [11.9F.17-Dusk/Dawn] Finish : Adding device to ISY was Successful
2009/06/29 16:41:12 : [11.9F.17-Low Bat] Start : Adding device to ISY
2009/06/29 16:41:12 : [11.9F.17-Low Bat] Finish : Adding device to ISY was Successful
2009/06/29 16:41:13 : [ 11 9F 17 1] Device added to ISY
2009/06/29 16:41:13 : ---- All Remaining Device Added ----
