sdcrane
Everything posted by sdcrane
  1. Has anyone upgraded their Alexa to Alexa+? I've been getting emails from Amazon to "Upgrade to free Early Access" (of Alexa+). I don't want to have any issues with the "ISY Optimized for v3" Alexa skill that I use to control my ISY devices -- so want to make sure everything will work fine before I update (which I assume might be difficult to go back to regular Alexa). Thanks. Stuart Crane
  2. Sorry my post was a duplicate of the same issue (posted first by MBrzeski). I did not see his message due to the numerous "pinned" messages at the top of this Alexa topic. Probably time for a cleanup -- not sure all those pinned messages are still relevant.
  3. Alexa responding with "Hmm, couldn't reach the <device_name>" for my ISY devices. I cannot log into my.isy.io -- getting "HTTP error 429" Cannot submit ticket because I can't login. (DOS attack?) Please advise.
  4. It is back up -- thank you!
  5. https://my.isy.io/index.htm Cannot login -- getting HTTP error 429. Alexa skill no longer linked -- when trying to re-link, cannot log in -- HTTP error 429. See attached.
  6. sdcrane replied to sdcrane's topic in Amazon Echo
    Got it working -- either something in our network or the reboot of the ISY got it back online. Thanks for the replies and thanks to Benoit via support ticket. You guys can delete this thread. 🙂
  7. sdcrane replied to sdcrane's topic in Amazon Echo
    Does not expire until June of 2025. ISY is working fine locally, and the Alexa connection was working fine at 9:00pm last night, and all other internet functionality is working fine. (I opened a ticket with UD, but it's very early in CA).
  8. sdcrane posted a topic in Amazon Echo
    Amazon Echo commands to ISY are not working because "the hub that device is connected to is not online". Is there something down at UD, or is it on my end? (I haven't changed anything -- this just started when I got up this morning). Thanks.
  9. Working fine now -- thanks!
  10. Michel replied to my support ticket and said there was a portal outage last night and should be fixed now. However it's still not working for me.
  11. My ISY is also "Offline" as of last night around 11:38pm. It works fine locally, and it has internet connectivity -- so must be something with the portal on UDI's end. I opened a support ticket. Stuart
  12. Back up for me. Thanks!
  13. Any updates on this??
  14. For any Alexa commands that I am using (with the ISY Skill), Alexa is responding with "I'm not quite sure what went wrong" after several seconds of spinning. All other Alexa smarthome commands work fine (talking to other NON-ISY Skills). When I try turning on/off/dim the devices using the Alexa app, the App says "Contacting UDI..." for awhile, and then comes back with "Server is unresponsive". Seems like some issue on the UDI side. Please advise. (See attached screenshots)
  15. It is now about the time that the UD folks waking up would be saying "Alexa, turn on the lights"... no?
  16. Ok, thank you rahnee.
  17. Unable to access ISY portal -- is this on your end or mine? I have not changed anything. (See attached screenshot).
  18. Ok, thanks. Still happening here, but only from one Echo and one ISY "device" (actually a Scene). If anyone else is getting this, let me know. Also, Benoit, reach out to your Amazon/Alexa contacts and see if they changed anything and why I am getting this. Thanks!
  19. Starting this morning, when I say "Alexa, Brighten _____ ", instead of immediately brightening that device, Alexa responds with "You want me to TURN UP _____, right?" and then I have to say YES to have her brighten that device. Anyone know why this is happening? Amazon change something? UD change something? I am using this Skill: ISY Optimized for Smart Home V3 Thanks, Stuart Crane
  20. Yes, exactly @michel, I was "migrating" from V2 to V3 (to attempt to fix the "Device Not Responding" error), and the instructions in the Wiki say to find the V2 skill in your Alexa "app" ... however, the V2 skill is NOT listed there (see my previous posts about this issue -- I spent half a day trying to "migrate" from V2 to V3 because of this problem). So, we were suggesting that you change the Wiki instructions to add the fact that the V2 skill may not show up in your Alexa "app", so you can find it at this link instead: https://www.amazon.com/ISY-Optimized-Smart-Home-V2/dp/B01FGS66D0 Let me know if you need further clarification on this issue. If this information had been in the Wiki, it would have saved me many hours of troubleshooting, duplicated devices, and plenty of frustration. Thanks! Stuart
  21. Yeah -- seems like a tweak is needed, to this: https://wiki.universal-devices.com/index.php?title=ISY_Portal_Amazon_Echo_Integration_V3#Instructions_for_Existing_Users Where it tells you to disable the V2 Skill (and original ISY skill), you might want to mention that the V2 (and original) ISY skill may not show up in the user's Alexa "app" (web or phone), and to find it here instead: https://www.amazon.com/ISY-Optimized-Smart-Home-V2/dp/B01FGS66D0 That is the only way I was able to find it and disable it. Once I found that, everything in that "Migrating to V3 - Instructions for Existing Users" Wiki document worked as described. Stuart
  22. Yes, good question, and I should clarify ... First, correct, it (ISY V2 Skill) was NOT showing up ANYWHERE in My Skills or Smart Home Skills or ANYWHERE in the Alexa "app" (web or phone app) -- so at some point later, on a WHIM, I GOOGLED "ISY skill", and it came up as a Google result for the listing on amazon.com! I clicked the search result link and it was the Amazon.com shopping item (under "Skills") when you use the Amazon shopping store. And sure enough, that ISY V2 Skill WAS ENABLED for my account (of course I use the same account for my Amazon shopping as my Alexa stuff -- which was crucial for me to see that it was enabled for my account, and for me to disable it). So then it was just a matter of clicking the "Disable Skill" button, then forgetting all devices, then doing a discover devices, and after that my duplicate devices under "Smart Home" in the Alexa "app" were gone -- I just have the new "V3" device listings, with the new Proper Case format, Device ID Address, etc. And YES, the "Device Not Responding" is NOT HAPPENING anymore! -- at least not a single one today -- and I got it hundreds of times yesterday (we use Alexa to control stuff in our house a LOT). Thanks!!
  23. Gary and Larry, Thanks -- that all makes sense, because there's nothing I can find that is an issue on my end. Everything works fine within the ISY / ISY portal, etc. -- so it's gotta be something on the Amazon/Alexa side that is out of my control to fix. So far today I have not gotten any "Device is not responding." error messages -- so hopefully it's resolved! Stuart
  24. I found the V2 skill, disabled it, got just V3 enabled, and now I no longer have duplicate devices. Yah. However, I am STILL getting "device not responding" all the time. So I'm back to Square 1 -- I have no idea how to fix these errors -- seem to get them 2 out of every 3 commands -- Alexa keeps saying "Hmmm, <device> is not responding". But I will ask again and it will work fine. What is the difference? Help!
  25. Eric, Thanks for the info. It seems like I still have the V2 skill enabled/installed in my Alexa account, however it's NOT listed ANYWHERE in my Alexa "app" -- it's not in my list of the Smart Home Skills, and nowhere in my entire list of skills either -- it's like it doesn't exist, yet it's still enabled on my account! But, even when I manually "forget", individually, the old (duplicate) devices that are discovered after Discovering Devices, and I only have ONE INSTANCE of each device in my list of smart home devices, I am STILL getting "Device is not Responding" about half the time. And if I ever do a discover devices again, they'll all come back in. I think the fact that I still have V2 "enabled" is what is causing the error. I need to disable it somehow, but can't figure it out. Thanks again -- will keep you posted. Stuart
