dennisric
  1. Took awhile for me to have time to check again. I did the reset/restore on one of the togglelincs that are flashing on and off and it did not make a difference. I found four of my togglelinc switches doing same thing. These four also are no longer being recognized when doing a query they come up with ! symbol and can't be controlled by the ISY 994i. I think these switches are dead or on the way out. They still work if you use them directly to turn on or off the light. What is bothering me that all my switches are togglelincs and I don't like or want to use the paddle ones. I wish the company that took over insteon would bring back all the products. I am going to look into some other brand that has regular toggle switch for home automation. Insteon seems to be going the way of X10. If anyone knows where I can get some new togglelinc switches please let me know. Thanks
  2. Thank you for suggestions. I haven't done the reset/restore but will try that next when I can find some time.
  3. More checking I have found that it is three togglelinc switches that are doing the on/off flashing when something else has been turned on or off. It is random and not all the time.
  4. Its not just the motion sensor. I have a couple insteon multi button remotes that do the same thing just randomly flashing some lights on and off. I have two togglelinc switches for my hall light for stairs going upstairs and when I turn those two on or off they also make other lights flash on and off. This is all random. I have not made any changes to the programming in the ISY 994I for a couple years, this just started a few weeks ago. I have checked all the settings in the 994 and nothing looks different. Are all my togglelinc switches failin? They were all purchased and installed in the same year or so, 10 - 12 years ago
  5. I am using the ISY 994i and up until a few weeks ago everything was working great. Now if I turn lights on or off other lights that are on will flash on and off. I have several motion sensors to control outside lights and when those are activated and the light outside comes on and then turns off after programmed setting in ISY 994 some of my inside lights that are on will flash on and off then back to on. Do I have a bunch of switches going bad? All my switches are the Insteon togglelinc type. Anyone have an idea what is happening. Thamks
  6. Thanks all for the quick replys to issue. I was able to connect to the ISY using Putty and USB connection. Could not make change to DHCP in that way but was able to see IP set on ISY and set my Laptop to same subnet/IP. Then was able to use Java console to admin in and made change to DHCP. Working back to normal again. Thanks so much for everyones help
  7. Just a thought I noticed problem seem to start just after June 1st. I had already been switched over to new internet provider.
  8. I did all that. When I open the https://isy.universal-devices.com/start.jnlp from my desktop shortcut there is no option to choose to login. Doing a refresh does nothing. No Cloud option no LAN option
  9. I recently had to change my Internet service to another company and now I can't login using the admin console. When it work before it always came up with option for LAN connect or thru UDI service. I always selected LAN. Now when admin console comes up it shows nothing for connection option. My ISY was set with a static IP of 192.168.0.108 and I think that is my issue now with the new internet service. The new service is using IP range starting with 172.16.X.X. I took my old router a DLink that still has my old setup on it which showed my ISY with 192.168.0.108, I set my Laptop to that same subnet of 192.168.X.X and connected my ISY direct to an ethernet port on the router hoping I could connect that way. No luck and I am giving up. This makes no sense for this ISY to be so hard to connect to. Has anyone had this issue pr know how to fix it. Thank you for any help you can give me. I
  10. Is there anything out there that shows exactly how the Email settings should be for different providers? If I remember right when setting it up originally it was a guessing game until it worked. I never changed anything but did the firmware update. I still believe that if it isn't broke don't fix it. A firmware update should not change anything in the setup you have.
  11. Sorry I haven't send any other info on this issue but I do not have time to constantly be checking the ISY for errors. It seems most of my problems started after doing a firmware update. At that time I also lost email notifications but gave up after wasting a lot of time trying to figure it out. I am currently running 5.3.3. When I do a test for the email notifications it gives me a mail server error. I use hotmail.com for my email. This really bothers me because I spent a lot of money and time setting up the Insteon water sensors and an expensive ELK water shut off valve. Now if there is a leak I won't know until I get home. I did find some lines red out in my programs after the firmware upgrade and had to figure out what it was to get those working again. I do not have the time to spend on this and am ready to rip it all out to make my life easier. I have never used the mobilinc app.
  12. This is most recent in log
  13. Never thought of looking in the error log. Here is what has been going on for a long time.
  14. I have to keep rebooting my ISY 994i to get to to continue working. Currently using version 5.3.3 of the firmware. Also had same issue with 5.0.16. All my programs will stop working or will suddenly flake out. I disconnect the power wait 10 sec then plug back in and good for about three days, then have to do same all over again. What could possibly be causing this, is my ISY failing and need replacement.
  15. Posted my problem too soon before doing more investigation. Looks like my PLM is bad. Wow it's just over a year old. These things don't last long. Smarthome needs to design these better. After having this happen a couple of times in the past I purchased two last time and have one as a spare. Just a pain in the you know what to be switching it out.
