JP
Everything posted by JP
  1. I got my FP300 a couple of weeks ago but I have unable to do much with it yet because of my time. UDI only detects it as a temperature sensor. So for immediate future it is not much use in a EISY environment. However I do have a Smilewolf device which does work with the EISY (zigbee). The only problem I have with it is that it requires a USB power source. It works pretty good with only an occasionally negative response (1 out of 200). I also have to block the side of it with a book because it goes off sometimes when you walk by in the hallway.
  2. I have several Zigbee devices and they work fine with my Eisy. I received my FP300 today but I won’t be able test it until Tuesday or Wednesday at the earliest. JP
  3. I notice that since I upgraded to either 0.7.0 or 0.7.1, I am getting numerous messages on the console for the EISY. They read as follows: eisy syslogd: last message repeated 14 times I was not receiving these messages before and now I get about 6 messages a hour. I looked at the syslog within EISY-UI and the only messages there are regarding PG3 not finding any nodes which I don't know why it is checking because I don't use Polyglot. Anyway, I thought I'd posted this here in case anyone has an idea as to what is happening before I submit a ticket. BTW, I run EISY headless but I have a mini KVM connected to it in case anyone is interested.
  4. JP replied to JP's topic in UD Mobile
    Thanks guys! That did it after I restarted the app.
  5. JP replied to JP's topic in UD Mobile
    OK but I’m not finding that in mobile app or the phone’s settings. Is it in the eISY?
  6. JP posted a topic in UD Mobile
    I would like to make a request or suggestion to place the current value of a variable on the screen whenever the variable is shown. This would make troubleshooting much easier as I have my favorites page set up to display several variables at the same time and to would eliminate my having to select each one in order to display the all values.
  7. JP replied to teverk's topic in eisy
    I have several 3 gang boxes and had no problem with fitting in Insteon switches, both the older ones and the I3 switches. I also use Zigbee sensors with them and again with a learning curve, have had no problems with them. They cannot be use in Scenes, but their program speed is almost as good (better than Insteon ones).
  8. Thanks to all the help you gave!!!
  9. The preliminary test looks good. It was the WAIT command. It was confusing because the program summary screen was not showing the program as Running for the 30 seconds that the sensor was holding On condition high. I am in the process of replacing my Insteon MD-II devices with Zigbee ones. With the Insteon devices the CONTROL statement work fine but the Zigbee ones do not. With the CONTROL I could have the WAIT in the first program and it did not care that the status was, but oh well. With the Zigbee devices I have less work to do in the Admin System, they do not work with Scenes but their program reaction time is almost as good as Scenes and a lot quicker than Insteon program reactions.
  10. paulbates the program already is split between two programs. I'll moved the WAIT command to the second program and see if that helps.
  11. Techman the answer is that CONTROL does not work with Zigbee devices (as far as I can see). When I use CONTROL the sensor does not show in the drop down list.
  12. Mmmm, never had to deal with this possibility. This is occurring with the Zigbee sensors only. I’ll be surprised if this is the problem because the sensors hold their value for 30 seconds and the set command is only 1 second or less and the WAIT times out immediately. I’ll try some different methods tomorrow to test this theory.
  13. Howdy, I am having a problem with a program. It runs fine (triggered by Zigbee sensor) as it executes the first instruction in the THEN clause (a SET command which works fine) and when it hits the second instruction (a WAIT) it goes to end of program without executing the WAIT or any subsequent commands. Any ideas?
  14. JP replied to JP's topic in Insteon
    Thanks Techman, it is not the write up that I was looking for but it may help as well. Thanks again! JP
  15. JP posted a topic in Insteon
    A while back (think in terms of years), there was a write up of the options for the Motion Detector II. It was an unofficial write up from UDI and not Insteon or SmartLabs. It detailed out what each option controlled whether it was supported or not. I can't find the writeup searching the wiki or the forum. Can anyone point me in the direction of it? Thanks, JP
  16. JP replied to JP's topic in eisy
    I was unable to submit this ticket for support but I was able to open another one. Problem resolved.
  17. Problem was resolved, apparently to USB to serial cable was bad and I was sent a replacement. I had some additional problems but I worked with UD support and they were handled.
  18. atomicboy. I do not use MobiLinc HD, just the simple, non HD, version. Thanks for suggestion.
  19. I removed power from the eisy for over an hour and it did not work, the PLM is not connected.
  20. I doubt that it is a bad PLM because I can swap it back to the ISY994 and it works fine as it has for years. The status of the PLM is not connected. As for the error log, here it is:
  21. Yes and done, no change!
  22. Yes, the Insteon Support box is checked.
  23. I am trying to migrate from my ISY to EISY and it is not talking to the PLM. I have the EISY loaded with my current ISY software and I can communicate with it via the Admin Console. but it is not getting anything from the PLM. I have the UDI serial interface cable. I have tried every USB port on the EISY just in case. Just for kicks I tied to Restore the PLM and I get the following message: Sat 03/11/2023 01:14:10 PM : [PLM ] PLM not initialized, command not sent Any suggestions? JP
  24. JP replied to teverk's topic in eisy
    Ahh except that the serial to USB conversion cables are Out of stock......
  25. JP replied to JP's topic in eisy
    No this isn't a browser issue, I had to click on reCAPTCHA boxes in other web pages yesterday without a problem. Thanks for everyone's suggestions but I figured out my problem so I don't have to open support ticket now.
