Neighbor got solar, I got problems
Short version: Right after my next door neighbor put in solar power, I began to have random light flickering issues. Both of our homes are fed off the same transformer (it is located between us). Is it possible that his equipment is "dirtying" up the power on the secondary side of the transformer? Longer story: For context, my house (and Insteon switches) are five years old, and I never had a problem. Eight or nine months ago, when the flickering first started, I assumed it was something going on in my own house. I scoured this forum looking for similar issues and tried everything I could find here. I replaced the PLM, I disconnected/replaced UPS units, etc. I kept a notebook of everything I tried. Every branch circuit breaker in the house has been turned off at one point or another without any changes. So I know it most likely isn't any of my appliances or anything else internal to my house. I also watched the logs on the Admin Console when flickering would occur and nothing showed up there. Needless to say, it was maddening. I never even considered that it could be the neighbor's solar set up until a couple of weeks ago. The solar company came out to replace some parts and had his system shut down for a few days, at least that's what the neighbor tells me. But for those few days, everything was rock solid in my house. As soon as they replaced the parts and started the system back up, the random flickering began again. Is there some sort of whole-house filter I can install to potentially clean up the incoming power? Or any other suggestions of what I should try?
Version Question
On each of my Insteon dimmers/switches there is a small sticker with the device's address and a Rev number (ie Rev 7.8, Rev 8.2, etc). There is also a version number shown on the AC page for each device. But these are totally different (ie V.44 or V.45, etc). I don't seem to be able to figure out a correlation between these two numbers. I have some Rev 7.8 devices that show V4.4 and some that show V.45. What to these numbers mean?
Only seeing zones 1-8
You are absolutely correct. It has been more than a year since I originally set it up; I forgot about the numzones parameter. I had gotten a replacement eisy about a month ago. The PG3 backup I had was old and didn't have this node server. I had to set it up again, and obviously failed to read all the instructions. That's my bad. Thanks.
Let me start by saying that this was working perfectly. I'm not sure exactly when this stopped, but I noticed today that the plug-in is only seeing Zones 1-8 and not 9-16. When I look at the Nodes on the PG3 page 9-16 are not listed or included. It used to show 1-16. Obviously they are not showing up in the IoX Admin Console either. I deleted the plug in and installed into a different slot and got the same results. On the PG3 page, it is showing 10 nodes: Node1 = Alarm Panel Node2 = partition 1 Node3 - Node10 = Zone 1 to Zone 8 But yet when I log directly into the EvisaLink I see 16 zones and it tells me if open or how long closed. I have not changed any of the settings since I got it working several months ago. Could a recent PG3 or IoX update be the culprit?
Support thread for: PG3x v3.2.21 (April 15th, 2024)
Updated and rebooted. All seems fine. Great work, as always.
PG3 stopped
UPDATE: I started a ticket, and after a few back-and-forth messages with Michel, he decided that a remote session was needed. After about 20 minutes of poking around in the eisy, he showed me there were 2 directories that were showing 49GB in size. He said not only should there nothing that size, he was also unable to open those directories. He said that was signs of the harddrive failing. I had also experienced 3 or 4 strange glitches in the past month, but I was able to reboot and go on as normal. I now wonder if this was the early signs of the drive failure. UD is sending me a replacement eisy, and hopefully in a couple of days I can have things back to normal. I cannot say enough good things about the service and support I received. A big thank you to Michel and the UD staff.
PG3 stopped
Thanks. I did try the button presses, but no luck. I also cannot load the sysconfig.txt file. I will start a support ticket.
PG3 stopped
I awoke to a notification that PG3 had stopped during the night. Made sense since none of the early morning routines didn't run. I tried to reboot it via the app. I got a notification that the eisy went offline, and then crickets. I waited about 20 minutes but could not access it via the app or the AC. I could, however, ping it on my network, but could not establish an ssh connection. I then unplugged it for 15 minutes and reapplied power. It's been 25 minutes now and still no response. I do have the blue light though. Is there some button combination I can do? Fortunately, I did back it up 2 days ago, so if I end up wiping it, hopefully I can easily restore everything. Any help is greatly appreciated.
Solar Noon
Regardless of DST, solar noon is 6 hours after sunrise in your examples. DST does not increase the times between sunrise and sunset. We as humans just offset our clocks from those times.
Solar Noon
How are you getting those sunrise/sunset numbers? Are you converting the times somehow?
Solar Noon
That's exactly what I'm trying to do. Open up the east side shades, wait an hour and close the west side shades. I currently have the program run at 11:45 am, but I have to change to 12:45 pm when DST kicks in.
Solar Noon
Does anyone know of an easy way to compute the time of day for Solar Noon? (midpoint between sunrise and sunset) I know there are variables for sunrise and sunset, but I can't average them together successfully. Or is there a node server that does that? I use the Timedata NS which has lots of info, but not solar noon.
Backlight LEDs
That's exactly what I was thinking. I have 2 other dedicated circuit outlets in that closet. I can try shuffling things around if need be. I'm hoping this was a one-time event.
Backlight LEDs
None that I noticed. The PLM is plugged into a dedicated circuit outlet in the AV closet. The only other thing plugged into that outlet is a small UPS unit for my router.
Backlight LEDs
Of course the one thing I didn't do fixes it. Thanks Interesting thing is that right after I plugged it back in, all the LEDs returned to their "daytime" levels. I didn't need to do anything.
dakall
Joined
Last visited
