TJF1960
  1. A little late to this party but there is a PG3 plugin called Ping that will monitor IP addresses of your choosing. I have it monitor Lan and Wan and our cell phones. Ping - Universal Devices Forum
  2. TJF1960 replied to Techman's topic in eisy-ui
    I am not sure if this will help but I created an All Off scene with all devices and all kpl buttons buttons for just such a case.
  3. Thank you.
  4. Yes I am on the latest. Thanks, I think I will open a ticket. -Tim
  5. @DennisC, thank you for the heads up. I am not sure that is what is going on though. I can open any of my 20ish plugins in system>plugins except for the one. Once I try to open that one is when I get the error above. -Tim
  6. Good morning! On UDM, current version on android (I couldn't find the version number), IoX 6.0.4 and PGx 3.4.11 If I go to Settings>Plugins>YolinkLocal, the 4 dots just keep spinning, after about a minute I get this popup: After this I cannot access any plugins for maybe 5 minutes. Once I go back in, if I click on any plugins before trying to access YolinkLocal, I can gain access to any but not YolinkLocal. I looked for a way to download any logs in UDM but didn't find any. What should be my next step? -Tim
  7. Mine too! I noticed yesterday morning it was running fine. I rebooted eISY yesterday afternoon and vue did started working right away after it initialize! I haven't tried again though, didn't want to push my luck..
  8. Things have been working pretty darn well with the Yolink local hub. Since installing it I have never tested the local function. Well, we suffered an internet outage Saturday and yesterday. None of my devices reported while service was down. What I did find weird is that thru the admin console I turned a few of the plugs on and or off, just testing to see if it was working. None responded. But after the internet was restored, some of those plug then responded by turning on or off. Weird right? So, I would like to check myself to make sure I have the hub and app configured properly. In the app, I selected the local hub. At the bottom of the local hub page, I select Local network. Then select Devices. Then I select + and add each device I want to report during an internet outage or power outage, correct? Or another way to put it Local Hub>Local Network>Devices>+ then add devices. After adding all the devices, pressing the set button on each device to seal the deal. In the plugin (YolinkLocal) I add the keys along with Hybrid and the lan ip address for the hub. Like I say, its been working the way I expected just fine with internet. Does this all sound correct?
  9. Well, so much for my luck. I postponed rebooting eisy so I wouldn't lose vue. We lost internet for most of the day yesterday. When it was restored, vue was throwing the same error as the op. I am down now also. So its not only a reboot but also a loss of internet that will kill it. I am not complaining, just putting it out there. -Tim
  10. I am sorry you both are going thru this. But thank you for posting. I was planning on doing some work to eIsy later today which would require a reboot but I will now wait for the update. Thanks again! -Tim
  11. TJF1960 replied to TJF1960's topic in WeatherFlow
    @Techman Are you saying that I can have another tempest in my area that I can tap into to feed the plugin for the time being? I did find a station close by but I am not sure how to retrieve their data with my plugin. I found their station id in the url but I don't have their token. The plug in says "Failed to get station units.
  12. TJF1960 posted a topic in WeatherFlow
    My Tempest battery when bad. It is going to be a while before I can get a replacement. I thought I understood that if I chose remote that I would receive rainfall amounts? But I am not receiving any. Did I misunderstand? Is there a plugin that I can use for short term that will provide rainfall for my area. I though and purchased NOAA plugin, but it doesn't provide percip.
  13. I happened to reboot yesterday after deleting and installing a few insteon devices. I did not hit update iox. When eIsy came back up and I opened the A.C. I was notified that I was running a version of launcher that was out of date. After doing the java thing and downloading launcher is when I discovered I was in 6.0.3
  14. Hey guys! I don't mean to butt in however I thought I would mention another possible contender for energy monitoring. Emporia Vue. They make small smart plugs like Yolink but I have found them to be much more responsive, and they report quickly to the Vue plug-in. They are pretty inexpensive like Yolink and are also made just as well, in my opinion. The Vue are all I use anymore for device energy monitoring. I do like that all Yolinks report to the hub and you only use one IP address whereas Vue requires each to have an IP address. Here is a link to a 4-pack for $35, but you can buy them Singley to. Emporia Energy Monitoring Smart Plug, WiFi Smart Outlet Plug Works with Alexa and Google Home - 15a WiFi Outlet with Timer, Mobile App, Home Energy Monitor, Scheduling - 2.4ghz WiFi Only (4 Pack) - Amazon.com -Tim
  15. Hi @Panda88, I know you are busy working the rest of the kinks out, and I really appreciate your dedication! The following is definitely not an emergency situation but it is something I would like to fix eventually. Since I switched from the stock hub to the local hub I have noticed that sometimes there is a delay from the time motion is detected to when the plugin reports it. It varies. Anywhere from a few seconds to maybe 20 seconds at worst. This began with your first non-production plugin and has continued thru to yesterdays updated production plugin Same set up with same number of temp sensors, switches and water leak sensors. Never experienced it at all with the old hub. Started with the new hub and new plugin. I was able to finally figure out that the Yolink app received the motion detected signal almost immediately but sometimes that delay occurs for the plugin to detect. It is so random that I don't even know how to go about troubleshooting any further. I think my next step is to pull one of the motion detectors and put it at my bench for further testing. Finally, to my question, what would you recommend I do or test for when I do this. Thanks again, _Tim
