SRS
  1. I submitted a ticket.
  2. I have lock edits set in UD Mobile on a family iPad. I've replaced some devices and want to update the iPad user experience, which I have done successfully in the past. However, when I go to global user preferences to unlock, Lock Edits says "False." When I click it I get "Error Could not get preference list." I cannot tell you what app version I have installed because, well, locked. There are no outstanding AppStore app updates. Suggestions?
  3. Back up and running. Re "safe": nothing was screwed up other than the off-line issue. Support had me up and running quickly and simply. (Highly recommend NOT installing packages late on a Friday.) SRS out.
  4. Roger that. No goofing here. Was just trying to determine if ssh connection possible. Ticket rules.
  5. Thank you for the read. I had skimmed through that and related. I think a ticket is the ticket. I did submit one on Friday #26592. I just thought I'd try connecting via ssh just to see if I could. I replied YES to the ssh question and received: ssh_dispatch_run_fatal: Connection to [IP addr] port 22: Unknown error
  6. I read someplace on this forum that I should try to connect using ssh. I found a discussion of how to do that via the Windows command prompt and I receive the message "The authenticity of host [IP address] can't be established... Are you sure you want to continue connecting?" Am I sure? FYI the UD Mobile error message is "Error. Connection Type: oAuthPortal. 03 Controller not online or not communicating with Universal Devices Portal... Try reboot." I did try reboot... It seems connected to my network, see ssh post prior.
  7. I shall. Thank you.
  8. I purchased eisy with zwave dongle May 2024 and migrated from isy. All well. Today the admin console notified me of available package updates. I clicked on the button to upgrade packages. I received 3 notifications of upgrade in progress then nothing for over 30 minutes. I logged out of admin console and tried to reconnect but Eisy not found. I tried adding http://192.... discovered using arp -a. Eisy not found. UD Mobile reports offline. I single-clicked the multi-function button on the eisy thinking it just needed a nudge. Nothing. After an hour since start, I powered down, unplugged, counted to 30, and plugged back in. Power button turned from red to green. But still offline. I cannot view logs through the portal because, well, offline. Am I going to have to do a hard reset and reload everything? I do have a recent backup so it would be the very end of the world but if there are other ideas I'm all ears.
  9. SRS replied to SRS's topic in ZMatter
    That's what I have as well, same Honeywell ZWave experience. Yeah, I've had no problem from UD Mobile (nor from the Alexa integration) and, in fact, now that I have that all up and running I've forgotten to go back and see if I still have the issue in the admin console.
  10. The update came through and fixed the issue. Thank you!
  11. Thank you! I'll let you know...
  12. I don't see an update available yet through the App Store (iPhone). I guess I can't unlock until it's available? (Right now, clicking on the Home Tab top menu just tells me I'm locked and to go to the Settings tab.)
  13. I had set a lock on edits via Global User Preferences in the Settings tab. Now I want to unlock but the only option displayed in the Settings tab is Systems. That's it. Should I just re-install UD Mobile and, if so, any tricks/tips to ensure I don't delete everything in the process?
  14. SRS replied to SRS's topic in UD Mobile
    Aha! "Display Status." Thank you.
