bkwolf
  1. I resolved my issue - it was my firewall/anti-virus. I use Zonealarm and after turning that off completely it works - now to t/s the config issue so that it works in conjunction with it. ** Update - no longer works, windows just disappears. I played around with disabling parts of zone Alarm and also turning it off completely, no luck. It is in a trusted network (I added the IP as a trusted IP as shown in the wiki) - I worked on another PC with same version of Java and it fails as well (also has ZA). I am able to use a laptop (win 7) with Java 6 Build 81 and it allows me to login and use the console.- the problem version is Java version 8 Build 91 -I have both 32 and 64 bit versions installed on windows 10 machine - both PCs failed both have zonealarm. Now interestingly enough I was able to run it on a Windows XP machine (also running zonealarm) with Java ver 8 Build 91 no issues and also running Zone Alarm. not sure what I've been able to deduce from this, but it is what it is....Windows 10 seems to be the common factor, Zone Alarm is no problem.
  2. I am having the same issue, I just plugged mine in out of the box. I am running windows 10 with Edge, Explorer and Chrome - I cleared the cache, I am able to connect to the ISY 994i ZW but nothing works with the admin concole, after I login the window dissapears and closes- even the desktop icon does this. I do have the latest & greatest Java....Edge & Chrome do not support Java Plug Ins. Thanks, Brian
