SMiller
  1. I had a similar problem last night with my brand new eisy trying to replace a perfectly good ISY994i that's run my Insteon system for years. I tried for a hour or two using the UD Mobile app on my iPhone to get the eisy wifi to say it was properly connected to my local wifi. I never did get that, although the responses were really opaque and for all I know it was connected. I then plugged in an ethernet cable and used a new copy of the IoX Finder on my PC, which instantly located the eisy and was able to load in the backup I had made of my ISY994. As of today the eisy is working fine on the directly connected ethernet and I have not tried to unplug it to check wifi. Now, I need to figure out what to do with the old ISY994. Seems a waste to let a reliable little computer just sit on the shelf. If anyone knows of a forum topic about repurposing the older boxes please let me know.
  2. Thanks for the suggestions. In the end I just deleted all of the affected keypads, factory reset, and then re-added them back into the ISY with all of the associated scene maneuvering. Because the included scenes tied into three different mini RF remotes, and everything is physically distant, this all took about 6 hours to make work. All to eliminate 5 ghost responder links. It would have been cheaper to just throw away the old resurrected keypad. It also would be really nice if I could figure out what the save and load commands on the link tables windows are for. That would have been a lot quicker. The good news is that in the process I did update to the newer ISY firmware, without any issues I know of. I also figured out the battery powered mini remotes should never be a permanent part of a system and I'll either eliminate them or add actual powered wall stations in those areas. They had seemed like an easy way to add control to a 50 year old section of the house. I had already sort of learned this when I gave up on the motion detectors, but for the most part the remotes actually did work while I could never make the motion detectors reliable (and had to deal with batteries). I think I've also learned I should get a backup ISY and PLM. As far as I'm concerned, the ISY is the only reason Insteon is even close to a viable product. I can't imagine keeping more than a few devices straight using hubs or manual linking. Even though it took a while, the ISY was perfect in pushing all the configuration changes across a very large property (3 subpanels, refrigeration motors, and hundreds of feet of separation).
  3. Thanks, unfortunately these links don't seem to be part of any scene AND the ISY certainly knows about them as they are reintroduced even after a factory reset/restore. I'll go see if I can match it up some existing scene, but I've tried adding the old keypad back into the system, and then telling the ISY to remove it. Even added all the buttons into scenes the responders are part of. I notice the group ID never matches and am guessing that's what makes the old links so sticky. It's a 2486D KeypadLinc Dimmer with 6 buttons, and I don't recall ever converting to 8, but it's possible.
  4. I would like to disable a responder link in an Insteon device using the Admin console from my ISY994i running v.5.0.15A, but have been unsuccessful in getting an edited and loaded XML to be used instead of the internal copy of the ISY or device links table. I started by editing the XML to remove and knit the index/address values back up, and then retreated to merely changing the record flags. In no case have I been able to do a device restore with my changed values, which seem to be ignored in favor of an internal copy, even though the reloaded values show in the Links Table windows until I re-query the device or ISY. I'm presuming there's extra integrity, or a security step involved to actually write the reloaded table back to the ISY, but I see no such control and the error log doesn't show anything. I also see no place where a CRC or auth phrase would be exercised, and so now I very much wonder what the "Load" control is for on those Links Table windows? I guess the bottom line is that I would like to purposefully get the ISY out of step with what's in the devices, and then restore the devices to what the ISY knows. It's on me about how much collateral damage is caused (hopefully none, but not UDI's problem). FYI: the links I need to remove are many years old from when I first was testing communications in the house (even before buying the ISY). The ISY has faithfully maintained the state it originally read, but the controlling keypad has been out of the system for years and just now resurrected from a box of spares. Yes, I now know I should have done a factory reset on everything the ISY acquired, but it feels like the system should be a bit forgiving and allow for repairs. My old keypad is now unusable since devices all over the place respond to it. At this point removing and re-adding a large number of perfectly fine keypads and relays is not easily done since there are probably 100 scenes involved. It seems wrong to throw away a good keypad because the ISY is being stubborn about retaining links I don't want. Since I know for a fact this particular device has no current use in the system I thought it would be simple to just sweep away any link containing its address. Unfortunately, what should be easy doesn't seem to actually be. Is there another way? Perhaps editing the ISY backup? That seems much more risky than messing with a bit of XML.
