Everything posted by Paul Straten
Snooze RING cameras via the PG3 node?
I would like to be able to SNOOZE my RING cameras via the API/PG3 node based upon a state of my home alarm system being in the DISARM state. I can produce the DISARM state for the alarm but don't see how I can use the RING node to SNOOZE my cameras. Does it exist?
"snooze" Ring notifications
Did you ever get an answer? On a similar question: I would like to be able to SNOOZE my RING cameras via the API/PG3 node based upon a state of my home alarm system being in the DISARM state. I can produce the DISARM state for the alarm but dont see how I can use the RING node to SNOOZE my cameras. Does it exist?
TotalConnect Nodes Not Loading
UPDATE: I just separated the 2 accounts with ADT so that now I have only 1 system per login. I am still receiving errors but could you take a look at the attached logfile to see if something look awry please? TotalConnect_7-5-2024_125438_PM.zip
API Errors
I have also: Restarted EISY Cleared cache Un-installed and reinstalled AW nodeserver from PG3 Installed in different node slots What to do?! Ecobee and RING nodeservers work great
API Errors
API Errors
API Errors
I have checked and re-checked several times. I cut and pasted exactly as it was presented to me. Here is a screenshot from the PG3 node:
API Errors
I was able to updates my nodes (only once) and now it is failing every time. The app (upon restart on PG3) will load 15 node updatings but also error out with an AIP key error. See screenshot below. I am trying to pull data from 3 weather stations. Also, attached debug file as well. AmbientWeather_7-5-2024_93624_AM.zip
Thank you Benoit, and again, we are working with a SINGLE TotalConnect account with 2 homes attached to the same login . . . . . if that makes any difference??
Debug file attached this time TotalConnect_7-4-2024_82547_PM.zip
Also, I have 2 homes using the TotalConnect app under a single login. Could this be the issue? I would be surprised if it was because this is nothing new as I was able to login fine into the single login in the past. This started after I performed a migration from 994 to EISY, and in my preparation I unloaded and reloaded all nodeservers in hopes this would make it a cleaner migration. Apparently not the case 😑
I can install and log in to TotalConnect PG3 okay but NONE of the nodes are updated. I have uninstalled, reinstalled, and even changed sockets but it still renders the message "Discovery failed, please check logs for a more detailed error" system_7-4-2024_25813_PM.zip
TotalConnect Error - "Discovery failed please check logs for a more detailed error"
So now I see the 2.05 version of TotalConnect is PG3 . . . . . and I am still running the TotalConnect version on PG2 Mainly because I have been reluctant to migrate all my PG2 and ISY products over - - - in fear of creating more problems to a fairly stable system on my ISY (hardly nothing is on my POLISY yet) But I guess unless i perform the migration to Polisy and PG3 I am stuck regarding TotalConnect, is that reasonably accurate?
Thanks so much! I will attempt the update when I return to this site. Thank you sir!
Attached is my logile - anyone have a solution? TotalConnect_5-31-2024_65500_AM.txt
