Everything posted by daveslc
Failed connection to one of two Roomba 980
Hi & thanks, that seems to have fixed the login issue. It now connects to both robots and indicates that it is connected to two (title says Roomba (2), in Polyglot). But, I don't see the nodes appear either in Polyglot or in eisy Admin Console. From reading the help, I think these should be added during discovery and can find in the log where it says it is adding a node, but nothing appears. Can/should I add these nodes manually in eisy with the names from the log file?
Hi there, It looks like it's been a minute since any activity, so I'm hoping whatever issue I'm getting may have been resolved already? Anyway, I have two Roomba 980s ("Roomba" and "Roomba Floor 2" @ IP addresses 192.168.1.24 and .23 respectively, by DHCP reservation. The Roomba node server connects to .24 just fine, but it errors out on .23, eventually giving me "connection refused" messages. It does discover the device, but when it attempts to get the password, it appears the response is different between the two. It generates the following python error: Traceback (most recent call last): File "/var/polyglot/pg3/ns/0021b90263ed_2/roomba-poly.py", line 795, in getPassword password = str(data[7:].decode().rstrip("\x00")) ^^^^^^^^^^^^^^^^^ UnicodeDecodeError: 'utf-8' codec can't decode byte 0xf0 in position 0: invalid continuation byteIt looks like it doesn't get the password because it is expecting a continuation of the packet? (I don't know how much data is returned in this call, but I can't image if we're starting at position 7, and I know the password happens to be 7 characters - we shouldn't need another packet to get the password. I'm attaching the log file. Both devices have the same "Product Software" (I assume this is the firmware version), 2.4.17-138. The only difference is about 3 days in the product software update time (the working one on 8/15/23 and the one with the error 8/18/23). Thanks for any help/insight you can offer on this. Dave Taylor Roomba_9-19-2026_105225_AM.zip
Developer Registration for Private Use
Hello, My HA system is a combination of things, Insteon lights, outlets, and some sensors, Opto22 PAC controllers for HVAC, irrigation, and some other sensors, Hue for some lights with ON/OFF provided by Insteon switch, Numi door lock, Blue Iris camera server. I would like to possibly develop a plug-in to communicate between the Opto22 PAC controller and the eISY. I currently use REST API between them, but it could be done much more efficiently if were able to create nodes in eISY for example. Since I don't expect many people will have Opto22 gear for home automation (I do know of a few but they work for Opto22 of course), I'm not looking to publish (i.e. make money) from creating a node server. Just for my own personal use. The UD Dev Program looks to be oriented only toward those who want to make money developing these tools...do they accept developers doing this for fun too? :-) Thanks, Dave
Package Upgrade killed my EISY
The support ticket was the way to go. They sent a link to the device image and clear instructions on how to re-image the EISY and now it is up and running! Thanks U-D.
Hello, I have an EISY that I bought a few (maybe several) years ago to upgrade my ISY994i. Now that I'm finally getting around to the upgrade, I tried putting the EISY online and initially had some issues with UDMobile connecting to it correctly. I was able to get it to bootup and connect finally by manual entry of the address and port 8443. I then connected to it via the Admin Console on my Windows PC and found the "Upgrade Packages," clicked it and the Admin console shutdown immediately. I read it could take up to 30 minutes up update, so I waited about an hour. The device never came back online after that. In order to see what was happening, I hooked it into a monitor/kbd/mouse. FreeBSD boots and I can login, start.win command does not work (it asks for agreement to licensing then generates a lot of errors eventually failing to load. It no longer connects to the network (ifconfig shows only a loopback address, not an assigned DHCP address from my router. No amount of rebooting or even power cycling seems to bring it back to a usable state. Any thoughts on how to get this to work? Thanks very much, Dave Taylor Salt Lake City, UT
Insteon Open/Close sensor status
Interesting to know a bit about the history of the SmokeBridge...it makes a lot of sense to me, particularly for cell phone notification. What I absolutely despise about most current HA offerings (including things like the Nest smoke alarm) is everything wants to be tied to a web/cloud service - it makes absolutely no sense to me that devices should rely on an internet connection (this is the reason I tossed the Insteon Hub and went to the ISY). Give me an internet connection and a DDNS entry so my phone can go directly to my house and not be based on some web service. I bought a Honeywell thermostat awhile back that was supposed to support WiFi...it wouldn't connect to local WiFi without a web service account - it subsequently got tossed into the garbage too.
Probably if I was really concerned about security, I would go with an off-the-shelf system. But considering I've lived in Salt Lake City for 25+ years and three different houses and never had a security system in any of them - this is more of a tinker project than life or death. And of course I'm going to self monitor My house can send me text messages if the fire or security alarm go off. FWIW...I did not roll-my-own fire alarm....that I am concerned about!
The SmokeBridge, like the Open/Close sensors, does not send the current status of the smoke or CO sensors. It updates the status on a state change, but does not report without a change. I'm reading these states via REST calls from the Opto22 controllers to the ISY....and it comes back as value=" "
Yes, I won't even mention the price we sell the sensors for LOL (and no, I wouldn't pay that for a home sensor - but they do a lot more than an NC/NO operation). You are right about the PLM (I did write my wishlist but forgot to "Like" it - I'll go back and do that). With 46 Insteon dimmers, switches, and keypads (and more to come as I work on the basement), I really don't want them to just "go away." I am rolling my own security system (and HVAC, Irrigation) primarily with Opto22 PAC-R1 controllers, so other than the devices being UL/CE/cUL/CSA rated electrically, the system won't be certified as such as an alarm system - that's okay. Fortunately, this house had an old late 70s/early 80s Honeywell security system in it...so there are wire runs to virtually every door and window except a few in the basement (hence the thought of using the wireless devices - which really go against my grain, one of my mantras for my HA system "if it's not meant to be moved, it's not meant to be wireless")
Well that's not quite true...I'm working on a project currently, where we have battery operated sensors that mount to the discharge of particle size separation equipment (mining industry). These sensors use XBee chips for wireless transmission and transmit 34 bytes every five seconds. We get four to six months of battery life before they need to be replaced. What we are talking about with an open close sensor is less than one byte of "data" ...pack the heartbeat and sensor status all into one transmission, send it every 30 seconds (and of course send it immediately on a state change). It is simply bad design on their part. There is even less of an excuse for the SmokeBridge - it doesn't use batteries. And while I agree testing, things on a regular basis is a good idea - it shouldn't be required on after reboot.
I am just now running into this same problem. I cannot believe an open/close sensor, for which security is an obvious application, does not have affirmative reporting of its status without manual actuation. Thankfully, most of my open/close sensors are standard, wired mag switch inputs to an Opto22 PAC-R1 controller that always report the status (and even have a confirming LED on the I/O rack), but I have three places where there is no wiring so my thought was to add these open/close sensors in those locations and have the Opto22 controller read the status from the ISY via REST-API calls...when I got the JSON data, it had value=" ". Of course, manually actuating the sensor caused it to set value="0" or value="255" accordingly. Same for the SmokeBridge too, Fire and C02 both report value=" "...do I have to have an actual fire before it will report it's value? My ISY (and PAC-R1, and Windows Server) are all on a UPS - but going around to reset these devices every time there's a reboot is a bad workaround for an even worse design.
