pagerr
  1. Is there a timeline for this.? Thank you for answering.
  2. I am very interested in being able to modify programs, monitor device status, etc on my iPad using the admin console . Is there a plan on porting the admin console to IOS creating a way to modify programs etc on an iPad, or iPhone. I do not want to use MobiLinc primarily due to its extreme cost. If so, is there a time line? Thank you for your time.
  3. Hello everyone, I have an ISY994i PRO the firmware and UI is v.5.0.16B, I also have a Polisy runing V:2.2.9- I am contemplating upgrading my ISY software to V.5.2.0. I purchased my ISY994i ZW in June of 2016. I find that I don't use any z-wave devices. Do I need to have the z-wave board to upgrade to V.5.2? If i want to remove it before updating my software, do I just kill power to the ISY and remove the current chip? - side note: I just read that the series 700 chip is being released. If I do decide to later install the 700 series chip will the current software recognize it? https://aeotec.com/z-wave-home-automation/z-wave-700-series.html, the specs area pretty cool. Robert Page
  4. Hello everyone, I have an ISY994i PRO the firmware and UI is v.5.0.16B, I also have a Polisy V.2 I use Alexa to turn on my lights and ceiling fan. I am using a KPL (6 Button KeyPad Link) SKU: 2487S from smarthome to remotely control my fan and ceiling light through the Fanlink. I am using a FanLink SKU: 2475F from smarthome to control my fan and ceiling light. When turning on the ceiling light or starting the ceiling fan through Alexa the KPL indicates the correct fan speed and if the ceiling light is on. When requesting Alexa to turn off the ceiling light, the ceiling light goes off, and the KPL ON indication for the ceiling light extinguishes and the OFF light comes on. But when requesting Alexa to turn off the ceiling fan the on indication on the KPL goes off, but the off indication does not light. I understand why, but how do I get the off indication light on the KPL to light when asking Alexa to turn off the ceiling fan. Thank you in advance for your assistance Robert Page
  5. I am interested in having my ISY control my Whole House Fan. I would like it to come on if the outside temperature is less then inside temperature, and the outside temperature is between 68 and 80 degrees. In your examples above; 1. What version of the ISY software are you using? 2. You said to create a State Variable under the Variables tab and call it in your example "Room_Temp_Hold". In the first example, you then referenced "$HVAC_Outside_Temp". I believe the '$' indicates a variable, was this intended to be the "$Room_Temp_Hold" variable? 3. Could you please go into more detail on how to assign a value to the variable? I am attempting to pull a temperature from the local forecast (Module 'Climate' Temperature ) and if that temperature is lower then the house temperature, have the house fan come on. I created a State Variable "Outside_Temp" but I am unable to assign it the temperature. Thank you in advance for your assistance. Bob
