cheezit73
Everything posted by cheezit73
  1. Ok thanks I will look at that. I have discovered so far it is only in auto mode that it has the problem, if it is on cool or heat only then it makes the changes.
  2. Thank you for the response! I understand what you are saying but it wont change the temp at all. Alexa just replies and announces the current set points. Any further thoughts?
  3. Hello! I have the ECHO setup with the ISY portal skill v3 and have been controlling a pair of insteon 2441 thermostats for quite some time. Recently I can no longer change the temperature. The thermostats are programmed through the ISY to always be in auto mode. I used to say Alexa set the downstairs to "x" and it would target the proper set point. Now it just responds and announces that the thermostat is keeping the temperature between the high and low set point as a status update. Any ideas? Thanks
  4. cheezit73 posted a topic in ISY994
    Hello, Does anyone know a way to monitor a gas meter? I recently had the valve to our outdoor fire pit left open for some time and was thinking it would be great to be able to have an alert if Gas is flowing through the main for an extended period of time. I searched and couldn't really find anything.
  5. Does anyone know if this should/will work with Insteon thermostats throughout the ISY skill?
