peekay
Everything posted by peekay
  1. peekay replied to peekay's topic in IoX Support
    The browser actually blocks the connection (silently) after clicking "trust anyway" on either the iPad (Safari) or Linux (firefox). Thanks for confirmation it works.
  2. peekay replied to peekay's topic in IoX Support
    If the certificates are signed by UDI then it is not that hard to allow a FQDN (xxxxxx.isy.io or something) that resolves to a private IP address and properly uses PKI. You don't have to have a server publicly resolvable to use certbot, you just use DNS txt file authentication. It is a solved problem. Sure, it might not be for everyone, but it is a completely valid approach. Compared to the complexity of working with the admin console and all its quirks, setting up certbot really is trivial. I'm starting to feel like the complexity of managing links directly for Insteon is also worth the pain compared to design decisions that have stuck around with UDI for over a decade that still limit usability for me today.
  3. peekay replied to peekay's topic in IoX Support
    That doesn't work with a FQDN or from a separate VLAN. As is common security practice, my IoT equipment is in a dedicated VLAN (actually a few different ones), and communications between VLANs controlled by the firewall.
  4. peekay replied to peekay's topic in IoX Support
    That should be easy enough. Wow, that is a major design flaw! Requiring communications via an insecure communications method?!
  5. peekay replied to peekay's topic in IoX Support
    That doesn't work because many browsers force https and fail silently or with obscure errors.
  6. I keep coming up with errors on my iPad and Linux/Firefox desktop trying to run the Polygot_v3 dashboard that really appear to be issues with the self-signed certificate. Are there any guides or known problems with running certbot on the Polisy with DNS verification? My Polisy has a proper FQDN (only accessible via VPN). Is the certificate used the one in /etc/ssl, or are there multiple locations that need to be linked?
  7. peekay posted a topic in IoX Support
    Something was happening between my Insteon serial PLM, my ISY994i, and my house. I've had a Polisy Pro laying around for a couple years with no practical use, so I decided to try it instead. Michele gave me the link for the updated SSD firmware and I installed it. After getting IoX loaded I tried the serial modem, but likely had screwed up the DB9-RJ45 adapter pinout. Don't know now because I broke it trying to troubleshoot. I removed the serial modem and deleted it from IoX. Now the USB PLM has arrived, and I tried to plug that in to Polisy and restore. IoX reports a DHCP error and 0.0.0.0 v0 not found when checking PLM status. I don't know if it is related, but I also cannot reach the Polygot V3 dashboard, although the admin console works fine. The login page appeared once or twice out of many attempts, but I was never able to log in. My IoT VLAN is locked down by the firewall, and IPv6 traffic is not routed. Polisy is allowed full access to the LAN and WAN. Any help on what to try next?
  8. I have tried different cables, but I will open up the ISY and see if there is anything odd (corrosion) inside, and also see if I can hook it up to the Polisy instead-- forget if I still have the cable/adapter for it.
  9. When I just re-restored the PLM I got this error message: The previous time I got the "no network connection" error as well, but communications were fine over the network. Not sure if it is relevant. After the restore completed the communications is still broken.
  10. Well, back on this. I got the PLM refurbished by Insteon, and there is no change in the behavior. Not sure if they just replace the bad capacitor that used to be problematic or if they do more work. When I was updating the modem from the ISY there were no surprising errors-- just stuff that had been removed from the system, plus one exception of an active device when refreshing status. (The two adjacent Insteon devices, physically and electrically, were fine.) Then, as before the PLM stopped responding.
  11. If it lasts me until March then I can get a new one... the problem is Insteon won't front you a refurb before you send in your unit so you are down until it is repaird. So, highest Wife Approval Factor wins...
  12. @kclendenThank you so much for the detailed breakdown! I'll try to watch for the corrupted messages tonight and see what I can glean from the data. Unfortunately though it looks like this will end up being the nail in the coffin for my Insteon system unless the PLMs come in stock soon.
  13. Tried that much and not much remarkable during the day. I think the most I had to repeat a command was 4-5x for the farthest devices. Not quite sure how to read the balance of the events and errors Closest device Thu 01/19/2023 14:18:08 : [INST-TX-I1 ] 02 62 57 65 64 0F 11 4D Thu 01/19/2023 14:18:08 : [INST-ACK ] 02 62 57.65.64 0F 11 4D 06 LTONRR (4D) Thu 01/19/2023 14:18:08 : [INST-SRX ] 02 50 57.65.64 40.53.13 2F 11 4D LTONRR (4D) Thu 01/19/2023 14:18:08 : [Std-Direct Ack] 57.65.64-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Thu 01/19/2023 14:18:08 : [D2D EVENT ] Event [57 65 64 1] [ST] [77] uom=100 prec=0 Thu 01/19/2023 14:18:08 : [ 57 65 64 1] ST 77 (uom=100 prec=0) Thu 01/19/2023 14:18:15 : [INST-TX-I1 ] 02 62 57 65 64 0F 13 00 Thu 01/19/2023 14:18:15 : [INST-ACK ] 02 62 57.65.64 0F 13 00 06 LTOFFRR(00) Thu 01/19/2023 14:18:16 : [INST-SRX ] 02 50 57.65.64 40.53.13 2B 13 00 LTOFFRR(00) Thu 01/19/2023 14:18:16 : [Std-Direct Ack] 57.65.64-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Thu 01/19/2023 14:18:16 : [D2D EVENT ] Event [57 65 64 1] [ST] [0] uom=100 prec=0 Thu 01/19/2023 14:18:16 : [ 57 65 64 1] ST 0 (uom=100 prec=0) Least reliable Far Device Thu 01/19/2023 14:28:09 : [INST-TX-I1 ] 02 62 54 A0 07 0F 13 00 Thu 01/19/2023 14:28:09 : [INST-ACK ] 02 62 54.A0.07 0F 00 FF 06 (FF) Thu 01/19/2023 14:28:10 : [INST-SRX ] 02 50 54.A0.07 40.53.13 2B 00 FF (FF) Thu 01/19/2023 14:28:10 : [Std-Direct Ack] 54.A0.07-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Thu 01/19/2023 14:28:22 : [INST-TX-I1 ] 02 62 54 A0 07 0F 13 00 Thu 01/19/2023 14:28:35 : [INST-TX-I1 ] 02 62 54 A0 07 0F 13 00 Thu 01/19/2023 14:28:35 : [INST-ACK ] 02 62 54.A0.07 0F 13 00 06 LTOFFRR(00) Thu 01/19/2023 14:28:37 : [INST-SRX ] 02 50 54.A0.07 40.53.13 2B 13 00 LTOFFRR(00) Thu 01/19/2023 14:28:37 : [Std-Direct Ack] 54.A0.07-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Thu 01/19/2023 14:28:37 : [D2D EVENT ] Event [54 A0 7 1] [ST] [0] uom=100 prec=0 Thu 01/19/2023 14:28:37 : [ 54 A0 7 1] ST 0 (uom=100 prec=0) Thu 01/19/2023 14:29:09 : [INST-TX-I1 ] 02 62 54 A0 07 0F 11 FF Thu 01/19/2023 14:29:24 : [INST-TX-I1 ] 02 62 54 A0 07 0F 11 FF Thu 01/19/2023 14:29:25 : [INST-ACK ] 02 62 54.A0.07 11 FF 00 02 62 54 A0 07 0F 11 FF 06 02 50 54 A0 07 40 (00) Thu 01/19/2023 14:29:29 : [D2D EVENT ] Event [54 A0 7 1] [ERR] [1] uom=0 prec=-1 Thu 01/19/2023 14:29:29 : [ 54 A0 7 1] ERR 1 Thu 01/19/2023 14:29:37 : [INST-TX-I1 ] 02 62 54 A0 07 0F 12 00 Thu 01/19/2023 14:29:50 : [INST-TX-I1 ] 02 62 54 A0 07 0F 12 00 Thu 01/19/2023 14:29:50 : [INST-ACK ] 02 62 54.A0.07 0F 12 00 06 LTON-F (00) Thu 01/19/2023 14:29:50 : [INST-SRX ] 02 50 54.A0.07 40.53.13 2B 12 00 LTON-F (00) Thu 01/19/2023 14:29:50 : [Std-Direct Ack] 54.A0.07-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Thu 01/19/2023 14:29:50 : [D2D EVENT ] Event [54 A0 7 1] [ERR] [0] uom=0 prec=-1 Thu 01/19/2023 14:29:50 : [ 54 A0 7 1] ERR 0 Thu 01/19/2023 14:29:50 : [D2D EVENT ] Event [54 A0 7 1] [ST] [255] uom=100 prec=0 Thu 01/19/2023 14:29:50 : [ 54 A0 7 1] ST 255 (uom=100 prec=0) Thu 01/19/2023 14:29:57 : [INST-TX-I1 ] 02 62 54 A0 07 0F 14 00 Thu 01/19/2023 14:29:57 : [INST-ACK ] 02 62 54.A0.07 0F 14 00 06 LTOFF-F(00) Thu 01/19/2023 14:29:58 : [INST-SRX ] 02 50 54.A0.07 40.53.13 2B 14 00 LTOFF-F(00) Thu 01/19/2023 14:29:58 : [Std-Direct Ack] 54.A0.07-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Thu 01/19/2023 14:29:58 : [D2D EVENT ] Event [54 A0 7 1] [ST] [0] uom=100 prec=0 Thu 01/19/2023 14:29:58 : [ 54 A0 7 1] ST 0 (uom=100 prec=0) I'll have to wait until tonight to try to get better data and likely tomorrow before I can power cycle everything.
  14. Just a clarification-- I call it "unreliable" in that I need to initiate the control 3-5 times for it to have an 80% chance of success.
  15. I'm having issues with my ISY994 not being able to consistently communicate with my Insteon devices. It started when I put up Christmas decorations, which included pulling an old insteon outdoor plug from storage, and adding 7-10 new SonoffS31 wifi switches (running Tasmota and not on the ISY994). Initially it was just a couple devices and only occassionally... including the outdoor plug, but over the course of 2 months it has gotten to the point where the system is unusable. Some things go on but not off, some occassionally go on or off, but not consistently, and every night all insteon devices shut off at once. The serial powerline modem is about 4 years old, and the devices range from maybe 8-10 years old to a few months. Troubleshooting steps: Unplugged all Christmas decorations and controls. No impact on operations. Re plugged in all the SonoffS31 controls. Moved ISY and powerline modem to different outlets and circuits in the house. No impact on operations. Deleted and re-added a device via the admin console. Potentially improved operation, but still not reliable. Unplugged the second device that showed errors in error log (see 1 below). No impact on operations. Additional debugging: Reviewed log and identified patterns; log shows initial error with outdoor plug, and consistent pattern to what I was experiencing with additional error rate over time. Checked ISY insteon device communications count. Count was consistent (91 devices) over 10 tries. Random thoughts: Time of day impact seems to be significant; it is better during the day and worse at night. House is pretty big, but no two insteon devices are further than 20' away from another one. A number of the devices listed are motion sensors that aren't really used (not reliable enough), but are still active. House has a main panel and two sub panels, along with Enphase solar microinverters connected at main panel. I do not believe any neighbors use Insteon. Electrically, closest neighbor is about 120 line feet away, next-closest is about 320 line-feet away. Transformer is shared across ~25 homes. Air conditioning doesn't run during any of these issues and there are only two small motors that run (water feature pump and hot water circulator) during the day. PLM is not plugged into a surge supressor, and there are no whole-house surge suppressors. I am now at a complete loss on what to try. The PLMs are out of stock which would be my next debugging strategy. Thanks for the help!!
  16. peekay replied to peekay's topic in ISY994
    Seems to have worked itself out. I followed the PLM reboot/reset procedure, rebooted the ISY again, "installed" the admin console from the device web page, and saved all changes and things started to work properly again, with all UIs and info showing 5.3.0 on my Raspberry Pi. HOWEVER, the start.jnlp ISY (https://isy.universal-devices.com/start.jnlp) still does not work-- only admin.jnlp (https://isy.universal-devices.com/994i/5.3.0" href="admin.jnlp). I'm not sure if I missed something with start.jnlp being depricated, but I thought the purpose was for it to select the correct applet.
  17. If you are retrofitting a home, you might also want to consider what types of LED lights you have or will have. Dimming LED replacement bulbs does not work the same way as incandescent, and when you want a warm, dim feel it is really a compromise. For 1% dimming (which is pretty important for many spaces), 0-10V dimming is one option, but it requires the extra control wires; "smart" fixtures add $50+ cost to each fixture, but can generally work with your existing wiring. I bought a house that has a LOT of MR16 lighting, which is very hard to get nice retrofit LED dimming without replacing the 12V transformers in each fixture.
  18. peekay replied to peekay's topic in ISY994
    Everything was re-saved in the older UI, but I cannot access any UI now.
  19. peekay replied to peekay's topic in ISY994
    It appears I did have a mismatch between firmware and UI versions. Unfortunately, after clearing the cache, re-downloading start.jnlp, and running the launcher the admin console does not work at all for me. On my "desktop" raspberry pi 4, it will allow one click of either dashboard or admin console, but nothing happens. On my Macbook Air the launcher will not even start. (Current versions of java everywhere.)
  20. Do you have a trusted certificate for the device?
  21. peekay posted a topic in ISY994
    Sun 2020/11/29 10:24:12 System -170001 [Auth:-10104] 172.16.70.117:62032->80, Num=7 Sun 2020/11/29 10:24:12 System -10108 Check log Sun 2020/11/29 10:24:12 System -170001 [Auth:-10104] 172.16.70.117:62032->80, Num=8 Sun 2020/11/29 10:24:12 System -10108 Check log Sun 2020/11/29 10:24:12 System -170001 [Auth:-10104] 172.16.70.117:62032->80, Num=9 Sun 2020/11/29 10:24:12 System -10108 Check log Sun 2020/11/29 10:26:05 System -100 [DHCP] state=RENEW Sun 2020/11/29 10:54:10 System -100 [DHCP] state=RENEW Sun 2020/11/29 11:02:05 System -5012 31 Sun 2020/11/29 11:21:48 System -100 [DHCP] state=RENEW Sun 2020/11/29 11:49:55 System -100 [DHCP] state=RENEW Sun 2020/11/29 12:18:02 System -100 [DHCP] state=RENEW Sun 2020/11/29 12:45:17 System -100 [DHCP] state=RENEW Sun 2020/11/29 13:12:55 System -100 [DHCP] state=RENEW Sun 2020/11/29 13:39:18 System -100 [DHCP] state=RENEW Sun 2020/11/29 14:05:39 System -100 [DHCP] state=RENEW Sun 2020/11/29 14:33:44 System -100 [DHCP] state=RENEW Sun 2020/11/29 15:00:04 System -100 [DHCP] state=RENEW Sun 2020/11/29 15:27:04 System -100 [DHCP] state=RENEW Sun 2020/11/29 15:54:48 System -100 [DHCP] state=RENEW Sun 2020/11/29 16:15:26 System -7153 ID 0024 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 16:22:44 System -7153 ID 0024 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 16:22:45 System -7153 ID 0029 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 16:22:58 System -100 [DHCP] state=RENEW Sun 2020/11/29 16:26:06 System -7153 ID 0004 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 16:28:29 System -7153 ID 0026 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 16:51:03 System -100 [DHCP] state=RENEW Sun 2020/11/29 17:10:44 System -7153 ID 0004 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:12:28 System -7153 ID 0004 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:22:31 System -5 Start Sun 2020/11/29 17:22:41 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:22:52 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:23:03 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:23:14 System -5 Start Sun 2020/11/29 17:23:24 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:23:35 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:23:46 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:23:58 System -5 Start Sun 2020/11/29 17:24:08 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:24:19 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:24:30 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:24:42 System -5 Start Sun 2020/11/29 17:24:52 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:25:03 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:25:14 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:25:25 System -5 Start Sun 2020/11/29 17:25:35 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:25:46 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:25:57 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:26:09 System -5 Start Sun 2020/11/29 17:26:19 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:26:30 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:26:41 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:26:43 System -110022 /CONF/INSTENG.OPT Sun 2020/11/29 17:26:43 System -110012 /CONF/INSTENG.OPT Sun 2020/11/29 17:26:47 System -110022 /DEF/F6/I1/NLS/EN_US.TXT Sun 2020/11/29 17:26:48 System -110022 /CONF/UXT.BIN Sun 2020/11/29 17:26:48 System -110012 /CONF/UXT.BIN Sun 2020/11/29 17:26:48 System -7153 ID 0002 :err=0, tag='/group', num=20, nest=5, o Sun 2020/11/29 17:26:49 System -7153 ID 0004 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:26:49 System -7153 ID 0026 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:26:49 System -7153 ID 0024 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:26:49 System -7153 ID 0029 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:26:49 System -7153 ID 0012 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:26:49 System -7153 ID 0022 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:51:56 System -5 Start Sun 2020/11/29 17:52:06 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:52:17 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:52:28 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:52:40 System -5 Start Sun 2020/11/29 17:52:50 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:53:01 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:53:12 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:53:24 System -5 Start Sun 2020/11/29 17:53:34 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:53:45 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:53:56 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:54:07 System -5 Start Sun 2020/11/29 17:54:17 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:54:28 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:54:39 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:54:51 System -5 Start Sun 2020/11/29 17:55:01 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:55:12 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:55:23 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:55:35 System -5 Start Sun 2020/11/29 17:55:45 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:55:56 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:56:07 System -100 [DHCP] Failed Starting Client Sun 2020/11/29 17:56:09 System -110022 /CONF/INSTENG.OPT Sun 2020/11/29 17:56:09 System -110012 /CONF/INSTENG.OPT Sun 2020/11/29 17:56:13 System -110022 /DEF/F6/I1/NLS/EN_US.TXT Sun 2020/11/29 17:56:14 System -110022 /CONF/UXT.BIN Sun 2020/11/29 17:56:14 System -110012 /CONF/UXT.BIN Sun 2020/11/29 17:56:14 System -7153 ID 0002 :err=0, tag='/group', num=20, nest=5, o Sun 2020/11/29 17:56:14 System -7153 ID 0004 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:56:15 System -7153 ID 0026 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:56:15 System -7153 ID 0024 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:56:15 System -7153 ID 0029 :err=0, tag='/node', num=28, nest=5, of Sun 2020/11/29 17:56:15 System -7153 ID 0022 :err=0, tag='/node', num=28, nest=5, of I have had an ISY994i for a long time, but it had been spin storage for a year and a half and just got everything back up and running in a new house recently. The ISY, PLM, and one Insteon device are all that remains from the original system, and I have purchased and installed a number of new Insteon devices, including the MS-2. I have the network module, but am not currently using it as everything has changed on the Sonos side and that is going to be a heavier lift for me. Programs have not been running; at first I thought it was bad devices or PLM, or programming errors on my part. Checking an ancient forum post, I realized the programs were not loaded with “out of memory” status on the programs summary pane. I have tried deleting all obsolete programs and devices, rebooting, upgrading firmware (now at 5.3) and anything else I could find to no avail. The error log is not especially helpful for me; there are dhcp client errors, but nothing else that is obvious in meaning. Attached below. Any advice on what to try now?
  22. Does the SOAPACTION for SetRelativeVolume still work? I can't seem to force my system to change volume relatively, only to absolute levels. It makes for a bit of a pain without feedback about current status until 5.x I currently only get actions like the following: X-SONOS-TARGET-UDN: uuid:RINCON_5CAAFD187A9501400 SOAPACTION: "urn:schemas-upnp-org:service:RenderingControl:1#SetVolume" <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <s:Body> <u:SetVolume xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1"> <InstanceID>0</InstanceID> <Channel>Master</Channel> <DesiredVolume>16</DesiredVolume> </u:SetVolume> </s:Body> </s:Envelope>
  23. I have tested with loads unplugged as well; consistent results throughout, including bypassing the plugstrip. My ISY (/Java) keeps crashing as I try to update to the current release; installed is 6-8 months old. For a while I had the firewall blocking internet access for all IoT devices, but I disabled that to try and upgrade. The device model is the outdoor plug-in on/off control. When status changes via the local switch, it is reported immediately, but I cannot control it via the web (or Java) interface.
  24. The switch link is just controlling some (LED) Christmas lights. When running diagnostics, I get a "Failed reading device link [-200000/-5] No network connection [[DHCP] state=renew - and then the admin console crashes. Different errors seem to come up each time, with a focus on communication issues. The picture does not seem to change, even when I plug the switch link directly into the outlet strip with the PLM.
  25. I have an outdoor SwitchLink that I get status messages immediately (on/off), but cannot control via the ISY994i. The local switch functions normally. The modem is connected to a plug strip, and has no issues with the ~10 other devices in the home. I moved the modem to a different location, and eliminated the surge suppression plug strip, but it does not impact performance. Any ideas on how to fix? (The unit used to work properly, I think a few weeks ago, but last year for sure.)
