kamikaze
Everything posted by kamikaze
  1. Disabling it will be a bit problematic, since my home automation system relies on that Homeseer link, but I'll give it a shot overnight. It was locked again when I got home... dropped off the network again at 9:57am EST., about 5 hours after I reset it this morning. There was nothing new in the error log from this morning, but the log has been sent as requested. One other question.. I believe I saw in another post that the ISY has DoS protection?? Do you know what the threshold is? Is it any network traffic, specific types of traffic?? The same HomeSeer system that links to the ISY also polls it on the network to make sure it's still available. Could that do what I'm seeing?? Barring a nearterm resolution to this issue... can I downgrade the firmware?? Can I go back to an older version?? I think I was on 1.7.x and I never had a lockup..... Thanks for your time. Brian
  2. Well, it locked up again shortly after midnight. How do I get the log to you?? I don't seen an option to upload a file to this post.... The plugin is the one available for HomeSeer. Here: http://store.homeseer.com/store/X-P751.aspx Brian
  3. Unfortunately, I have. Do the error logs survive a normal power-cycle?? If so, and it locks up again, I'll send it. BTW, do you recognize these messages: 5/31/2011 7:21:07 PM ISY Insteon COMM: Failed to get response from ISY (The remote server returned an error: (501) Not Implemented.). 5/31/2011 7:21:07 PM ISY Insteon COMM: for command: [DOF0A AD CE 30] 5/31/2011 7:21:07 PM ISY Insteon COMM: Failed to get response from ISY (The remote server returned an error: (501) Not Implemented.). 5/31/2011 7:21:07 PM ISY Insteon COMM: for command: [DOF0A AD CE 40] 5/31/2011 7:21:08 PM ISY Insteon COMM: Failed to get response from ISY (The remote server returned an error: (501) Not Implemented.). 5/31/2011 7:21:08 PM ISY Insteon COMM: for command: [DOF0A AD CE 50] 5/31/2011 7:21:08 PM ISY Insteon COMM: Failed to get response from ISY (The remote server returned an error: (501) Not Implemented.). 5/31/2011 7:21:08 PM ISY Insteon COMM: for command: [DOF0A AD CE 60] This is in response to pressing the main "off" button on KeypadLinc 6. It's supposed to turn off all my basement lights. Not sure if this error is from the ISY, the ISY plugin, or the KP6 itself. Thanks. Brian
  4. Michel, 1) I do not believe I have a certificate installed. When I go to "Request/Manage Certificate". my only option is to install a cert. Do I need a cert now?? 2) I've got a good backup. I'll reset it this evening and report back in a day or two. So far, I've not made it 24 hours without it dropping off the network. 3) It presently says "F.D4.D3 v85 / Connected" (I haven't reset it yet). Just in case you're expecting it to change..... Update: I did the factory reset. I guess we'll see what happens. Brian
  5. I am still having issues with IP connectivity. Is anyone else having these problems? I noticed that I still have ISY programs that are working, I just can't browse to the ISY, ping it and my Elk integration is totally broken. Only comes back after a reboot of the ISY. I have verified the network side of things. I'm having a similar problem. I can ping my ISY, but I'm unable to navigate to http://isy or http://ip-address. I reboot the ISY and connectivity is restored, but will stop working after a while. -- David I too am now having the trouble. I just upgraded this weekend. Everything had been fine before. I upgraded last night, and I've had to power cycle the ISY twice since. This last time, it was only online for 2 hours. When I reset it and login to the admin console, I see about 5-10 min. of "System Busy" progress bars coming and going. It eventually settles down. There's nothing in the system error log..... HELP! Brian
